Results 1 to 5 of 5
    Zero Stack Headset, 1 1/8" Steer Tube on HD
    Not much choice out there, Cane Creek and Chris King is it.
    I want to run a zero stack headset using a Fox Van 36 with 1 1/8" steer tube. The geometry is already 66deg HA with a 180mm fork, though the Ibis website does not specify what axle-to-crown height that HA is based on. I want to keep the front end from raking out too much hence my preference for a zero stack headset. I'll be running my Van at 170mm. Seems like a good compromise.
    Prefer Chris King but they don't sell separate assemblies/top&bottom.
    Cane Creek, prone to creaking?
    Anyone?
    We Ride In God's Country!
    Are you sure the top of the CSU will not hit the downtube when turned?
    Quote Originally Posted by canuck_tacoma View Post
    Uh, good point. I don't know. I'm trying to figure out a headset.
    Can more of you small owners chime in?
    I posted this in another thread but I thought it should be here as well. Will RS Monarch Plus Fit a Small HD?
    The knobs will hit with a zero stack on the Small HD. You will need to use a regular headset.
    Best, Todd
    Will a zero stack lower cup make my 180 talas fork hit the downtube of a XL MOJO HD when turned?
    Im resorting to zs lower cup because my fork (1 1/8)is a bit short for an ec upper and lower. My 2degree works headset ec44/zs49 is on its way.
