    Knomer
    Reputation: Dusty Bottoms's Avatar
    You will answer my Mojo questions RIGHT NOW.
    Hello all,
    I did a search and couldn't find this info, and was very surprised not to see it listed on the Ibis site....
    Standover height on an XL frame? Please measure straight up from the ground thru the bb, and then again thru the forward pedal hole with the cranks at 3 & 9 o'clock.
    BB height? This can be measured on any size frame.
    And.....does the seat slam to the rails unobstructed?
    Thank you! That is all.
    www.derbyrims.com
    Reputation: derby's Avatar
    Quote Originally Posted by jchembel
    Also there's nothing in the way of the seatpost until the BB shell (which is sealed, no need to drill an exit for water at the bottom of the BB shell).
    Knomer
    Hahahaha, so you're saying I should have scrolled down a little before littering this board with stupid questions?
    Moderator! Remove this thread immediately!
