Results 1 to 31 of 31
    Who makes Ibis hubs? "Speed Tuned XM"
    I am sure they are joytech or novatec but would love to do a little research on them to see if they are worth keeping on my wheel rebuild
    The wheels are built by a company called Stay-Tru (Sta-Tru Wheels - Serving the Bicycle Trade for Over 25 years)
    I had to order some hub adapters for my wheelset and Ibis gave me their contact info.
    ride, eat, sleep, repeat
    Helpful - thanks! any color on how good the hubs are? the sta-tru website is a little light on details
    I'd also be interested in any information on the quality of these XM/sta-tru hubs. The Ibis bikes seem pretty expensive to be having no-name hubs, IMHO. I'd feel better about the price if I knew that I could expect to use them for a while at least.
    speed tune free wheel
    Quote Originally Posted by Jkon View Post
    Brand new speed toon free wheel failed in less than 200 miles. Pawl spring design seems inadequate, maybe a hardness issue with the pawls themselves as well. The pawls are in three pairs and all had obvious deformation and breakage. Free floating metal then damaged the hub itself. Bummer to be off a brand new bike due to failure in what should be one of the most robust components. MFG has completely stepped up with complete wheel replacement for LBS....riding old bike today with DT Swiss hubs......
    Reputation: martinizer's Avatar
    According to my local Ibis dealer, the Speed Tuned hubs are made by Novatec / aka Joy-Tech. So they are likely rebranded novatec hubs (which are actually light, good hubs). It's possible that sta-tru is handling the wheel builds, or perhaps they are also a subsidiary of Joy-Tech.
    don't know what wheels you are building, but when you can get a set for $380 shipped from UK using Hope Pro2 Evo + Stan Flow EX (which I love running tubeless, are really wide too) and even pick custom hub colors (for $100 LESS than Chain Reaction Cycle which would not give me 150x12 or color option), I decided not to bother building a set...
    I got one for my HD (110x20, 135x12 ~1850g) and using one for my Glory DH bike as well (110x20, 150x12 ~1900gr). received the wheels in 7 days to west coast (held 3+ days in NY customs) from those guys:
    Hope Hoops Pro2 Evo 26inch Front Wheel | Wheels MTB | - Cycle Sports UK
    Hope Hoops Pro2 Evo 26inch Rear Wheel | Wheels MTB | - Cycle Sports UK
    Hope Hope Hoops Pro2 Evo 26inch Rear Wheel 12x150mm | Wheels MTB | - Cycle Sports UK
    very happy with my set and that order. Wheels holding great to 7 days of Whistler abuse on DH bike so far, and light!
    (had use my Mojo HD as my mini DH last year with same wheels - 15 days not a problem).
    Update 5/15: looks like the company went out of business in Dec '14 so those links are dead now. Price was too good (must have been a mistake, I didn't ask).
    Dec 2005
    joy tech hubs are notoriously bad. why spec such cheapo stuff that it has to be "rebranded" something else?
    here we go again
    I don't know anything about the Speed Tune/Novatec/ Joy Tech relationship. However, I've had nothing but good luck with 2 sets of Ibis wheels and stock Joy tech hubs. I've also rented HD's in Sedona and Moab where their gear sees unimaginable abuse and still found them to be trouble free. They are nothing to write home about in terms of weight or engagement but I've found them to be very reliable.
    Quote Originally Posted by eleven-yo View Post
    Joy-tech is huge company that manufactures hubs for both cheap and high end companies. To label everything Joy-tech makes as "notoriously bad" is naive at best.
    Reputation: squareback's Avatar
    Quote Originally Posted by iraconn View Post
    The typical cause of this is an incorrect bearing adjustment from new. If you look at the broken pawls, and each of the three is broken in half at the parting line, that is the likely cause.
    Quote Originally Posted by squareback View Post
    This was likely my issue. My rear bearing preload was a bit loose, I ignored it and now my free hub has broken pawls.
    Does anyone know where to get replacement parts for these speed tuned hubs?
    Too Much Fun
    Reputation: benja55's Avatar
    Aug 2005
    Ping Ibis and they should be able to help get you sorted.
    There's a handy sticky thread with their contact info.
    And FWIW, I think the Speed Tuned stuff is not half bad for generic gear. It's not Chris King, but it's certainly not junk.
    - -benja- -
    Thanks. I sent them an email...
    Cleavage Of The Tetons
    Does anyone have accurate hub specs for calculating spokes for these hubs?
    (Flange diameter, center, etc)
    Got a pair cheap, looking to order spokes ASAP.
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Stupid is, as stupid does
    Reputation: spunkmtb's Avatar
    I got a question. I am sure it is answered in a thread somewhere but I am currently too lazy to search. Perhaps someone can chime in. Is the 15mm front hub convertible to 20mm? If so where do I get the adapters?
    Yeti SB95C
    Carver Ti 420
    Ibis HD3
    Quote Originally Posted by spunkmtb View Post
    Ibis web store has them:
    Wheel Parts ? Ibis Cycles Online Store
    H
    Feb 2007
    You are riding the sweetest frame design on the market, ever manu cuts corners somewhere or you would pay double for that sexy ride. Treat yourself to a set of DT swiss 240's and never look back. The bike deserves it.
    When I got my SL 3 years ago, I pulled everything not to my liking, sold it cheap and installed the good stuff. 100's of miles later no issues, not ONE.
    My rear free hub piled up after 3 months....should get some warranty but it will only ever be a spare wheel as I'm buying I-9's to replace it.
    A bicycle will take you to fantastic places....if you let it.
    Ibis fan since '08 now rolling on the big wheeled Ripley.
    Reputation: neilether's Avatar
    Quote Originally Posted by hanssc View Post
    H
    Hans,
    That link to the Ibis store says that the axle conversion kits are not for the currently used Speed Tuned hubs. Do you have any information on conversion kits for the Speed Tuned hubs?
    Ibis does not stock the parts.
    Stay-Tru link:
    The Speed Tune hubs are supplied by Stay-Tru and they can be converted from 15 to 9mm, but not from 15 - 20mm thru axle. The rear can be 135 x 10 or 142 x 12.
    H
    Oct 2010
    That is a horrible website.
    Dec 2008
    Can a Speed Tuned rear 142 bolt thru hub be converted to a 135mm quick release?
    Thanks.
    Quote Originally Posted by w1lksy View Post
    Thanks.
    Yes. We have the parts in stock. They are not in the web store though... Contact warranty@ibiscycles.com and we'll get you some!
    H
    Dec 2008
    Thanks for the quick response!
    I'm in the UK. Can I get them from somewhere over here, or could you guys supply me with the parts to convert the hub?
    Thanks again, much appreciated.
    Just email warranty@ibiscycles.com, that's much easier than involving more people.
    H
    Dec 2008
    OK. Thanks again.
    Anyone know the weight of the hubs speed tuned xm, or full wheel with hubs speed tune and rims ZTR flow ex ?
    Reputation: Myers005's Avatar
    Jan 2011
    Reviving this thread for anyone looking for parts or end-caps for Ibis speed tune (unlabelled) hubs that came with first gen 928 & 941 wheels. I needed 135 x 12 caps for rear hub which aren't available through Ibis. Got them from StaTruWheels Parts & Accessories, fit perfectly. All end-cap converters and replacement free hubs are available, hubs are called Speed Tuned Super 6. Prices a bit less than Ibis but charge more for shipping.
    Not sure what happened first, but the hub axle was broken, one freehub pawl was broken in half, and the resulting burr scratched the crap out of my maxle. We had to beat on the maxle with a drift and a mallet to get it out.
    Not a great discovery after todays ride. Can these hubs be purchased anywhere? Id lke to just get the same thing so i dont have to get different spokes. Im saving up for a nice wheelset, but need these to beusable in the meantime. Probably cheaper to buy a whole hub and relace it than to track down an axle and a freehub. Ill probably have to replace the Maxle too. Bummer.
    You should talk to Ibis, they have hubs and parts.
  1. Speed Tuned Wheels hubs??
    By guppie in forum 27.5
    Last Post: 08-20-2014, 09:19 AM
  2. Replies: 0
    Last Post: 03-02-2013, 07:53 AM
  3. Replies: 5
    Last Post: 06-07-2012, 10:18 PM
  4. Replies: 6
    Last Post: 10-22-2011, 08:13 PM
  5. Niner Jet9 RDO "vs" Ibis Mojo SL-R for 5' 4" rider
    By ollllllo in forum 29er Bikes
    Last Post: 10-19-2011, 08:17 AM
Members who have read this thread: 52
