Results 1 to 11 of 11
    Reputation: J273's Avatar
    What size to go with??
    Thinking of going for a HD160 to replace my s-works enduro.
    Love the enduro (2010) but just can't get on with the sizing of the frames.find the medium too small and the large too big.
    I'm 5ft 11 a shade under 6ft with shoes 32" inseam.
    What size HD should I be looking at as I've heard they are a little short.
    Any input would be appreciated.
    Many thanks
    Reputation: wilks's Avatar
    I would go large with a 50mm stem
    Large with your choice in stem size.
    I am about your size, I am riding on a large. Stem size seems to be around 70mm (+\-10 mm).
    Reputation: mazspeed's Avatar
    Large
    Mtb Guide
    Sep 2012
    Had same problem, went large 50mm stem wide bar
    May 2010
    Same size as you and same inseam...go with a Large. Non setback post and either 50 or 70mm stem.
    Reputation: Dibbs_'s Avatar
    Yep large for sure, 50mm stem. Ibis come up a bit small anyway.
    Im slightly taller with same inseam-large with 60mm stem.
    Reputation: Nate3510's Avatar
    Same size as you on a Large with a 70mm stem.
    MTB Monkey
    Reputation: Jefe74's Avatar
    Mar 2006
    I am also just under 6' and my Large is perfect with a 70-85mm stem. 70 for general all mountainy type stuff. 80-85 for climbing and twisty trail. That is with a 730 bar.
