Results 1 to 1 of 1
    Feb 2013
    What size adapter to fit DT Swiss rear shock to SL frame?
    Trawling thhrough the SL build topic I see a few SL frames with DT Swiss rear shocks, as opposed to t he more usual Fox RP23.
    Can anybody tell me if the mounting hardware i.e. the bolts is the same for both and also what size adapters are needed to fit the DT Swiss shock to the frame.
    TIA.
    ok, found the answer 21.8mm and 40 mm, 8 mm hole; same bolting heardware is used.
