Page 3 of 4 FirstFirst 1234 LastLast
Results 201 to 300 of 310
  1. #201
    HD rear triangle that allows different dropouts for 650B and 26" a la Intense. I suppose the same could go for the SL-R.
    Also, adopt the SL-R top tube cable routing on the HD. Almost everyone runs the dropper post on their HD and the current routing is not on par with the quality of the rest of the bike. They have a tendency to come loose and chew up the cables. Also makes it a pain to remove/install the dropper post.
    Also, to fit the Hope braided disc brake cables on the HD, you have to cut the thin plastic housing. Maybe a zip tie based approach for all of the cable mounts would make sense?
    Having said that, I love my HD. Best and most versatile bike I have ridden in nearly 20 years.
  2. #202
    One more thought. I wouldn't change too much on the Mojo HD in terms of the amount of suspension. 180 mm rear travel would essentially make it an DH bike and not really a trail/AM bike. If that's the case, why not just build a DH bike. I also like the head angle on the HD. It corners better than pretty much anything out there. Too much slacker (e.g., 65 degrees) and I think it would loose some of that. I think many of the people who are asking for those changes are really asking for a full-blown DH bike and not an AM/DH bike.
  3. #203
    Features:
    Internal routing for cables and 'stealth' dropper posts on relevant bikes. This is the way of the future.
    Adjustable headset/HTA as-standard on most/all bikes...
    Wheel size options. Not my thing, but some people seem to like trendy 650 wheels.
    Bikes:
    1)"Super" Mojo HD....! Really liking the sound of that...
    HD with 160-180mm adjustable travel would be ideal.
    Better yet if you can do it with a linkage/chip kit and I can 180-ify my currently-new HD...
    2) Mojo DH - proper 8"+ big bike, travel adjustable back to mini-DH travel and 650b compatible (I see a use as race wheels...)
    3) Silk SL disc...? cf. colnago.com/c59-disc/
    4) Ripley - pretty...
    5) A bad-a$s aero track frameset and bars/stem, built to fit a 6'4 sprinter...? I'd un-retire for that....
    or
    5) a STEEL (or Ti) long-travel hardtail.... been there I suppose, but nothing wrong with an homage to the back catalogue....
  4. #204
    Thanks for asking. As XC is my focus, a 650B SLR would be perfect. I'd like to think that given the work done on the HD140, hopefully this is something that could be put into production fairly quickly.
  5. #205
    That's the frame I would most like to see but I'm not sure mfg's like Ibis willing to bring a 650b SLR to the market until fox announces a 650 xc choice. Could be a deal breaker.
  6. #206
    I hope that wouldn't be a deal breaker.... I would take a Revelation EVERY TIME over a Fox 32, and RS is also coming out with a Reba.... and Ibis is already dabbling in X-Fusion products as well.
  7. #207
    Agreed. There are definitely worthy 650b fork choices if fox isn't producing an xc model and kudos to Ibis if they take the lead before fox catches up.
    Possibly a deal breaker in terms of the mfg's decision to produce the 650 xc frame due to the mkt share that fox holds. Those that use fox suspension on their high end frames may not be willing to make a switch, sales would be impacted.
    I would certainly give another fork brand a try in order to ride a frame and wheel size that I like.
  8. #208
    Jun 2010
    I noticed on Pinkbike today that Anne Caro seemed to have a Matte black/nuclear pesto HD frame... Just this would be perfect!!! I need one!!!!
  9. #209
    I make light things heavy
    Reputation: hrsjqb1's Avatar
    My 5 cents
    1. DH bike. 200mm delivered travel, 180mm Limbo Chip option.
    2. Ripley HD 150mm, slack and aggressive. Short chainstays
    3. Replace the SL with a 120mm XC racer
    4. Tranny 29er
    5. An inexpensive commuter option (sub $1k) not carbon. You could call it the 99%'er
    For all models offer the super sexy Cylon Silver you have for the SR-R.
    Internal Cable routing is neat
    Shorter chain stays on the HD
  10. #210
    Reputation: vikb's Avatar
    650B Mojo HD with full 160mm travel. I'm never going to put little wheels on it so I don't need 26er compatibility.
    Safe riding,
    Vik
    www.vikapproved.com
  11. #211
    slr compatible with a chainguide and tensioner. I was ready to pull the trigger on buying one but I dont like the idea that I won't be able to run a 1x setup on it without the tensioner. HD is good but I guess a little heavy for me.
  12. #212
    Unpredictable
    Reputation: Ridnparadise's Avatar
    Quote Originally Posted by timex99 View Post
    That is not what Hans told me - he was riding a 1x10 well before release. The advice from my shop is the same - there are options apart from just a widget and clutch rear d combination. I have a frame in the garage with that intention myself.
  13. #213
    Quote Originally Posted by Ridnparadise View Post
    I know you can setup the slr with 1x and use the direct mount chain guide but I prefer the whole system with the tensioner for those really rough ride. IMO.
  14. #214
    Unpredictable
    That's cool and I understand. The frame is certainly capable of being beaten and keeping on going, but seems like the HD has taken that crowd. For where I live the, the HD is not my choice, although the riding is rough in a lot of places (at speed).
  15. #215
    HD is nice but I think is a little to heavy for me. I only weight 125lbs and my mojo c is holding up pretty good on whatever I throw in to and my current setup is fox 36 160mm up front and I'm loving it. Just want something up to date like the slr with all the tapered headtube and stiffer carbon layup just like what Ibis is claiming. But couldn't figure out on how I can make it a 1x setup with the tensioner. Until then I guess I would have to settle with my 3 yr old mojo c.
  16. #216
    Mtb Guide
    Sep 2012
    Also like internal cable routing for stealth model dropper posts.
    Rather than anglesets option to choose or purchase offset shock hardware like limbo chips from Ibis direct for differing hta adj.
    Ibis shock tunes direct through Ibis for Fox, RS, XFusion etc that would be way cool get a shock that suits your style of riding up front.
    Too early for me to ask for much more, pretty much what I'd want from any mfg regardless of how good the base product is.
    Cheers
  17. #217
    boardguru
    HD 650B, Diamond plate downtube protector,(hint, hint Scot) and more colors.
    Mick
  18. #218
    HD160 650b
    650b tranny
    More colors or at the very least be able to choose from all colors Ibis now has, SL-R orange on a HD would rock
    Ease & Flow Where Ever I Go
  19. #219
    Can we start with a Ripley that looks like a Mojo...
    Maverick ML7 Camo
    Niner A9C SS
    Cervelo RS
  20. #220
    w/o reading through this whole thread,
    650b Mojo HD
    650b Mojo SL
    Both with internal frame routing
    1 deg more slack head angle
    1/4" lower BB
    Replaceable dropout options, ala Intense Carbine (This feature makes this frame very attractive since it's so versatile)
    We Ride In God's Country!
  21. #221
    Reputation: getbusyliving's Avatar
    An SLR w/ "chip" (custom dropout like Intense) conversion to 650b would be a home run IMO. Even if people don't use it, it would alleviate buyer anxiety over possible changing standards.
    29er or at least 650b Tranny is key as almost nobody wants a 26" hardtail anymore. (Though I'd be bummed as i already bought a carbon 29 ht.)
    I don't see a DH Ibis as a winner, as DW link is more of a strength/differentiator in climbing than descending.
  22. #222
    08 Master DH World champ'
    Reputation: ED young master's Avatar
    Quote Originally Posted by getbusyliving View Post
    Don't let your fears stand in the way of your dreams ...
    05 DH French champ'
    08 DH World champ'
    10 DH Euro champ'
  23. #223
    Jan 2005
    Tranny 650b compatible rear triangle that incorporates Belt Drive!
  24. #224
    5 new ideas
    Mojo 650b
    Tranny 650b
    Hakkalugi 29er hardtail
    Mojo DH
    Ripley Unicycle
  25. #225
    Reputation: iClique's Avatar
    Quote Originally Posted by saidrick View Post
    To Mr. Iclique,
    Your black and red request is what I was thinking on the decal sets: make the decals in different colors, so that you can make a red and black bike, a white and red bike. Etc...
    Sounds like a great idea.... More options are always good!
  26. #226
    the train keeps rollin
    Reputation: snowdrifter's Avatar
    How about they deliver the Ripley in 2012?
    beaver hunt
  27. #227
    bikes
    long travel bike that would fit some one 5ft to 5ft 6in
  28. #228
    OriginalDonk
    Reputation: OriginalDonk's Avatar
    A lot of people have mentioned modular dropouts like Intense is offering but I think Banshee's system would meet the needs of more people.
    Anybody buying their 160mm travel Rune has a chance to select 26" of 650B dropouts for whatever axle spec they intend to run (135qr, 142x12, or 150x12). You can also run the head angle as 65, 65.5 or 66 degree, paired with quarter inch changes in the bottom bracket height.
    http://bansheebikes.com/wp-content/u...o2013Rune2.jpg
    This system seems like a real winner that would allow people to set their beast up for the day's terrain whether it's more park oriented or mellower aggressive trail.
  29. #229
    Reputation: VTmojo's Avatar
    My vote...
    Hans,
    Here is my vote...
    1. 650b option for the existing Mojo HD
    2. Ripley HD 29er 140-150mm F&R, slack and aggressive. Short chainstays, Dropper post
    3. Carbon Fat Bike, 90mm rims, front suspension
    4.Tranny 29er
    5. DH bike. 200mm with180mm Limbo Chip option.
    THANKS for asking!!
  30. #230
    Is it just the Hakkalugi Disk for 2013? There's got to be some more, c'mon IBIS!
  31. #231
    Another vote for 29er Tranny with singlespeed option.
  32. #232
    The Crow
    Reputation: Iwan's Avatar
    Finally decided what I want from Santa Ibis. A Mojo "SL-R" with:
    * 67.5 degree head angle (running 150mm travel fork)
    * removable TT cable guides or internal routing. Running 1x so don't need them. Especially once the SL-R Goes...
    * ... Stealth compatable
    * dedicated 650B
    * Not a deal breaker, but initial target weight achieved would be nice
    * Monarch option ( if not will have to go frame ex shock cause there's no way I'm going CTD)
    There's a feeling I get
    When I look to the West
    And my spirit is crying for leaving
  33. #233
    mnt bike laws of physics
    Reputation: yogiprophet's Avatar
    How about a XXL Ripley?
    That would be my next bike. Probably my last bike.
  34. #234
    Quote Originally Posted by yogiprophet View Post
    I've heard (and said) that before! More than once.
  35. #235
    Reputation: Bones2's Avatar
    1) mojo 650b ( new rear triangle for hd would be great)
    2) Ripley
    3)Tranny 29
  36. #236
    Really ? So hurry up, only 9 days left before THE END.
    05 DH French champ'
    08 DH World champ'
    10 DH Euro champ'
  37. #237
    Another .5" top tube length on the XL models.
  38. #238
    Oct 2010
    1. Mojo HD 27.5, 160mm travel. And not a Ripley-fied 27.5" like some have mentioned - stay away from the angular contact composite bearing eccentric linkages of the Ripley. Novel idea and lends bike geek cred, but that bike has been in development way too long and the development effort/cost seems of questionable value. Especially when you already have a suspension linkage design on the HD/SL/SL-R that is among the very best on the market. Seems you could develop a killer 27.5 160mm bike pretty quickly based on the HD with HD-style linkages, just optimizing the geometry for 27.5.
    2. Mojo HD refresh, like the SL-R. Mojo HD-R? Lighter hardware and lighter carbon layup, other improvements like internal cable routing. Maybe a degree slacker, maybe even add a little travel to 170-180mm. The current HD pedals so well at 160mm, I cannot even see the need for a bike with less travel, and more travel = even more versatility.
    3. Somebody else mentioned a 20" kids bike. Hell yeah! There are only a few builders that make a 20" kids mtb worth a damn, and they are still too heavy and too expensive for what you get. With the first generation of hardcore mtb'ers all grown up and having kids that they want to introduce to the sport, there's gotta be a market for a good carbon hardtail or FS kids bike. No reason a 20" kids bike shouldn't be well under 15 lbs, but good luck finding one.
  39. #239
    This, apart from the bit about increasing the travel. A lighter 'HD-R' with 140/160mm travel, internal routing, and slacker geo based around a 160mm fork - that would be a huge hit.
  40. #240
    Reputation: johnny thunder's Avatar
    A bike that rides like HD with:
    1) frame weight under 6 lbs
    2) internal cable routing
    3) dedicated 27.5
    4) 150mm travel
    5) retain style elements of current ibis frames (worst part of Ripley is that it doesn't look "Ibis")
  41. #241
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    Quote Originally Posted by johnny thunder View Post
    3) dedicated 27.5
    4) 150mm travel
    +1. I'd jump on an Ibis build like this over the 2013 competition in a heartbeat. Even cooler if Lopes endorses the "tweener" wheel size
    Old enough to know better. And old enough not to care. Best age to be.
  42. #242
    3) dedicated 27.5
    4) 150mm travel
    Yeah, I'd buy one too.....though I'm not enamored with internal cable routing
  43. #243
    May 2005
    Quote Originally Posted by doismellbacon View Post
    Long as it's not the brake lines I'm ok with internal routing
    Possibly add me to that list as well but for pete's sake give the current owners a real 650 rear triangle. Does this not seem like a no brainer to do?????
    2013 Banshee Spitfire V2 650b
  44. #244
    dwt
    dwt is offline
    Whatever Brian Lopes endorses as the ultimate Trail/AM bike would appeal to me, as an average rider.
    Rumor is that Ripley cured him of 26" only bias
    How about the 650b Johnny Thunder postesd; call it the "ibis lopes"
  45. #245
    Whatever ACC endorses as the ultimate Trail/AM bike would appeal to me, as an average rider.
    05 DH French champ'
    08 DH World champ'
    10 DH Euro champ'
  46. #246
    Reputation: Yody's Avatar
    Whats up with everyone wanting a 650B Option, talk about trendy. I doubt half of the people asking for it haven't ever even ridden a 650 bike.
    Internal cable routing is for road bikes, not mountain bikes
    People want some super slack HD? I don't think half of the people on this board are ready to try and ride something 66> Headtube angle, sounds good on paper but if you don't know how to ride the frontend aggresively (which most people don't) Its not gonna do anyone any good.
    No wonder most companies don't ask people on internet forums how to design their products
  47. #247
    Lightly salted
    Reputation: fuenstock's Avatar
    I happen to like the HD just as it is, with it's geo and 26" wheels. It's perfect for an all mountain/trail bike. I hope that Ibis keeps the HD as a 26" bike and just makes a rear triangle for 650b or even better make the 650b guys a bike of their own and leave the HD alone.
    Few things I would like to see on the HD.
    1, Keep it as a 26" bike with same geo or close to same, option for 650b rear triangle
    2, More shock options
    3, Improved rear tire clearance, Hans dampf 2.35 rear fits but tight.
    4, Improved clearance for cassette/chain when in smallest cog
    5, Room for a coil shock on a small HD frame without making the seat tube any longer.
    6, molded cable mounts like the sl-r, no more rivets!
    7, Reduce hd frame weight.
    8, Updated color options.
  48. #248
    Quote Originally Posted by Yody View Post
    It's a personal choice, I'm running a -1.5° Works Components headset, and a 170mms Bos Deville forks.
    I'm next to 65° and I just love it this way.
    (Have a -1° WC headset for sale, pristine condition, cheap have a look on PB)
    05 DH French champ'
    08 DH World champ'
    10 DH Euro champ'
  49. #249
    Quote Originally Posted by ED young master View Post
    Well if you're truly the DH champ your sig lines suggest, then you are one of the exceptions.
    And for the small majority of riders who are aggresive and riding steep terrain or have mini-dh'd their rig, the slacker tube makes sense. But telling Ibis that they should now make ALL of their HD's more slack would be a terrible move for Ibis who sells much more frames to average riders than the tiny minority of super rippers.
    The slacker headtube is great for steep descents or running into things, but for trail riding, pumping, pedaling, cornering and less steep trails its more of a hinderance.
  50. #250
    Quote Originally Posted by dwt View Post
    You call it a rumor, I call it a clever marketing ploy
    As well, guys like Brian Lopes ride anything, and fast. Its nice knowing that the same bike I ride is under the feet and hands of one of the best enduro riders out there, but lets not be fooled into thinking he couldn't do the same thing on just about any of the top shelf AM/Enduro bikes out there. If he hopped on a huffy and shredded and called it the ultimate trail bike, I would not buy one because he said so.
  51. #251
    @Yody
    I'm with you, and personaly never asked for a modified Mojo HD.
    Special headsets are there to fulfill this need.
    What I asked for a few weeks ago, was a DH frame for ACC !
    05 DH French champ'
    08 DH World champ'
    10 DH Euro champ'
  52. #252
    Sep 2012
    The only thing I would ask for is a seat tube that doesn't taper so you have more range of travel on the seatpost. Forget the front der. on the HD
  53. #253
    Road bike with disc mount.
    HD like AM hardtail.
  54. #254
    1. 650b HD 160-180mm (preferably with slack HA)
    2. 650b SL-R 140-150mm ((preferably with slack HA)
    3. A "Gran Fondo" carbon road bike with a compliant ride, disc mounts, and (you guessed it) relaxed head angles would be awesome. (basically the bicycle equivalent of a sport-touring motorcycle)
    Magazine reviewers and hardcore racers seem to be big on "twitchy" handling. I prefer my bikes to have more relaxed handling so you can confidently hit the big speeds and still trust the bike to stay predictable.
    I know a lot of folks have been asking for internal routing, but I strongly prefer external for ease of maintenance. Just isn't worth the hassle.
  55. #255
    Slovakia (Europe)
    Reputation: PeterG's Avatar
    1. A SL-R with slacker head angle and slightly longer toptube (like Pivot Mach 5.7c which I had swapped to because of the reasons above), internal cable routing and water bottle cage mount as a bonus, if possible.
    2. - 5. N/A
  56. #256
    screamer
    Reputation: budgie's Avatar
    nm... Thread jack deleted.
    On heavy rotation: White Lung: Deep Fantasy
  57. #257
    The Crow
    Excerpt with Scot in new Switchback Magazine:
    "I can tell you we are going to have several new bikes in the next year
    "What I can say is that I have never been more excited about the coming nine months in the history of Ibis than I am right now with all the stuff we have in the pipeline."
  58. #258
    Lightly salted
    Quote Originally Posted by Iwan View Post
    I'm excited to see what Ibis comes up with! Hopefully dedicated long travel 26" and 650b bikes so that every one is happy!
  59. #259
    Very excited, but not sure what 9 months means in IBIS time. Hope I'm wrong.
  60. #260
    Im thinking a 650b HD with the new pivot design.
  61. #261
    May 2005
    Quote Originally Posted by Bones2 View Post
    Funny sheet right there
  62. #262
    It's 2013 now, so is it just the hakkalugi disc for IBIS? C'mon guys...
  63. #263
    Reputation: mazspeed's Avatar
    They have a lot in the pipeline.
  64. #264
    I'm quoting this so when it gets released I'ma come back to this thread and say told you so.
  65. #265
    Quote Originally Posted by mazspeed View Post
    Like what?
  66. #266
    Feb 2010
    How about a carbon fiber Klunker?
  67. #267
    As many have said before me:
    1) HD revision, slacker (66 deg), internal cable routing, ICSG tabs, Better shock options (Cane Creek, X Fusion, etc. on builds.
    2) 650B HD 150-160, updated geo, same as previous.
    3) Ibis DH bike
    4) Long Travel 29er, 140mm
    5) Aggressive hardtail, 140-150mm fork, 650B
  68. #268
    Reputation: JuSa's Avatar
    Actually you need only two models:
    - HD with interchangeable travel (maybe 160mm to 190mm) and HA for enduro and bike park riding,
    - Ripley, or some else 29er with interchangeable travel of 120 to 140.
    Why compromise with 27,5" when you can have best of both ends?
  69. #269
    artistic...
    Reputation: colker1's Avatar
    Ibis steel mojo 26in 80mm susp adjusted...
    ibis steel spanky
    ibis steel hakkalugi.
    ibis steel SS 26in
    WTB: Bomber Z2 1 1/8 steerer, in good to excellent shape OR bomber rebuild kit.
  70. #270
    yeah, why not make them out of lead while you are at it !
    I would venture they are more successful now because they are all carbon bikes (and dam good ones).
  71. #271
    Reputation: simenf's Avatar
    Nov 2008
    @Damnesny: +1
    simenf - brainwashed by the big wheel mafia.
  72. #272
    Off the back...
    Reputation: pinkrobe's Avatar
    Hmmm. Now I have to hold off on my HD purchase so I can see what's in the pipeline. Sea Otter release I hope.
    @pinkrobeyyc
    #pinkrobeyyc
  73. #273
    Carbon fat bike, Handjob cable stops. Name it CHUBBY. I'll take it in a nice inky blue finish... "blue balls". I'm seeing mine rigged with lights for midnight snow rides. Please!!
  74. #274
    Reputation: fourflys's Avatar
    May 2010
    So I guess I'll chime in here...
    I'd love to see an Ibis "Adventure" road bike, sort of like the 'Gran Fondo" mentioned above but with clearance for a true 32mm tire... and I'd love to see it WITHOUT discs... I just don't see the need for discs on road bikes... good calipers stop just fine unless you're on a fully loaded touring bike or tandem...
    Also, I think Ibis would kill it with a couple "retro" steel bikes... and for the poster that said "might as well make them out of lead"... you really have no clue how light a well-made steel bike can be... I guarantee I can build a steel cross bike that weighs no more than my carbon Lugi...
    Like is too short to grow up, go ride a bicycle!
  75. #275
    You should invent the donwhiller's road bike. Disc brakes and FUN geometry (not for the cadence meter crowd).
  76. #276
    February is almost here. Any update guys on what we can expect this 2013? Even just a teaser, c'mon Ibis guys...
  77. #277
    May 2005
    I agree. 12 pages of ideas/input it's time for some info back from Ibis. I've got a few possible 650B bikes in mind to purchase (hopefully before spring) and I'd love to see what's in the pipeline here.
  78. #278
    For sure thE DH's already in the pipe !!!
    05 DH French champ'
    08 DH World champ'
    10 DH Euro champ'
  79. #279
    Quote Originally Posted by skidad View Post
    YEAH, c'mon Ibis! This thread is now three months old and we expect you to have carbon molds done, ride samples in the works, and geo's published so we can all complain/speculate the crap out of them!
  80. #280
    Jan 2013
    So quite here, no update at all. Its like the ripley...
  81. #281
    May 2005
    Quote Originally Posted by ibismojo09 View Post
    Now that's a scary thought
  82. #282
    The_Afterman
    Reputation: Zinglespeeder's Avatar
    What should the next 5 models be?
    Well if their past announcement shed any insight on 2013's models and beyond, they probably won't say peep until the bikes are in the HQ ready to go out to dealers a-la-yeti style. Look how long we speculated over the delivery dates of the SLR and now the RIPLEY.
    Sure, it sucks they ain't saying nothing, but if they've learned anything from their announce-five-centuries-before it's ready approach, then the new bikes will punch us all in the face when they are announced and ready to go that's one delay I don't mind.
    But seriously Ibis, gimme sumthin'
    "Don't stop when you're tired. Stop when you're done"
    -Mojo HD
    -Niner AIR 9 Carbon SS
    -Zion 737 EBB SS
  83. #283
    Feb 2010
    A cross post from the PIVOT forum (maybe some clues here...):
    Looks like Dave just posted another tweet February 1. No guarantees they're Pivot products as I imagine he's got Turner and Ibis steeds in the mix.
    "So much carbon, so much 29er, so much 65027.5(.25), so much DH, so much XC, so much XC!, some AM, SO MUCH TESTING TO DO!"
    Word is that Turner has a carbon 29er in the pipeline. I imagine Pivot and Ibis are both pushing 650B projects. Wonder where the DH is coming from and I know the AM following is huge. Sounds like he's involved in a few things.
  84. #284
    Jan 2013
    we are not asking for the finish product, all we are asking is for some clues if there is indeed a lot in store in the pipeline.
  85. #285
    May 2005
    I'd like to at least know if there will be a dedicated 650B rear triangle made for the existing HD. More clearance than just a few mm's with the ability to also run the biggest/tallest 650B tires. Wouldn't kill them to chime in about that possibility even if a whole new bike is in the works.
  86. #286
    Good Idea on the dedicated 650B rear triangle, I need one for my SL-R
  87. #287
    Reputation: Accident Prone's Avatar
    1 - A full DH rig
    2 - A Ripley HD (150mmish rear travel and with threaded external bb not internal) Something to smash the SC Tallboy LTc and Spesh Enduro 29er
    3 - A HD 160mm 650b
    4 - Update the HD to have internal cable routing
    5 - Some new Ibis clothing, hats, trail riding shirts etc. The current stuff is very roady/xc looking.
  88. #288
    The Crow
    What I wouldn't give to know the answer to this question...
  89. #289
    1. 27.5 HD with a lighter frame, revised geometry, and eccentric links
    2. Tranny 29
    Would put down preorders for both bikes immediately.
  90. #290
    Keep on dreaming :-)
  91. #291
    vto
    vto is offline
    I don't know. Hillharmon might be on to something. I was about to get a turner burner but was advised to wait by a source at ibis.
    But why the mojo hd special blends. Is there a new frame coming?
  92. #292
    May 2005
    Quote Originally Posted by vto View Post
    Someone from Ibis eh? Was that it on the info?
    I was gonna order the new Banshee Spitfire V2 frame but now the new SC Bronson has me rethinking that a bit. If Ibis is gonna release a new or revised Mojo/HD or even a dedicated rear 650B triangle that could also really mess with my head and complicate an already tough decision.
  93. #293
    vto
    vto is offline
    Skidad
    I have an email transaction I promised not to post. But it said to wait and see what Ibis will unveil in the months to come. No specifics. If it helps, it was the man himself who replied to my email.
  94. #294
    Black on black Ripley. You know, naked carbon. Then I will buy it. That's the carbon bike I want.
  95. #295
    It's the axle
    Reputation: Gregg K's Avatar
    If front derailleurs are a thing of the past, and there is seat tube to tire clearance, then the chainstay length on the Ripley might be shorter than it is.
    Frames designed around no front derailleur.
    Note to self: 85% of FTP for 20 min.
  96. #296
    Yes, I agree. Design around no fd. Haven't had one in three yrs. Like the simplicity, similar to the simple Ripley design. Oh, a 140 rear Ripley would ok too.
  97. #297
    May 2005
    Skidad
    Don't have months to wait (Ibis months can = years). I needed something ASAP to ride so I ordered the Banshee Spitfire frame today and should have it in a week and will be running it 650B. The new Bronson looks really good but I believe the Banshee VPP design is better. Also the price was right for the Banshee frame @ $1800 with Fox CTD Kashima shock.
    It would be very cool to see Ibis pull a new HD out of their hat with the eccentric pivots but it's gonna cost. At the very least they should build a dedicated 650 triangle for the existing HD while at the same time working on a new model.
  98. #298
    I wonder if we'll ever see a long travel bike with the eccentrics. At some point in the travel spectrum the eccentrics would have to be upsized, perhaps to the point of diminishing returns. Those giant cartridge bearings aren't light.....not that my arm chair engineering counts for much.
    I'm still pulling for a light 140mm RiBley to cover the XC to aggressive trail w accessible water bottle end of things, and a Mojo HB for big trails w big wheels.
  99. #299
    Ride or Die!
    Reputation: CasinoKiD's Avatar
    I only have one...
    Dedicated 650B HD 140/160
    Or at least a 650B compatible rear triangle.
  100. #300
    mountain biker
    Reputation: slyfink's Avatar
    My vote goes for a 650b rear triangle for the HD. and possibly jerseys that are more relaxed and with smaller/more discreet logos. I think one of those button-up collared shirts with an Ibis logo embroidered on the left chest would be pretty cool...
    continuous growth is the strategy of a cancer cell.
