Results 1 to 8 of 8
    Is this wear normal
    Opened my lower links today and noticed that the sleeves where the bearing touches has silver rings that is a sign of wear. There is no play YET but im not sure if this will continue to wear and evetually cause the play other members have raised. Attaching pic. Is it still possible to prevent further damage? Upper pic is the driveside, lower pic is the non drive. Bike is upside down. Anybody opened theirs yet?
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Looks fine. Just check torque specs on them on occasion. When they get too loose the wear will get worse.
    You can ride the bike and have no worries.
    It will not fall apart under you.
    Yes, do big hucks.
    It will only get worse if you neglect maintenance.
    screamer
    Reputation: budgie's Avatar
    Mine show similar markings, but I think it's just the anodizing (this after 3 years of hard riding, and less-than-perfect maintenance/cleaning). I've replaced the links/bearings once in that time, but only experienced play as a result of worn shock bushings (annual replacement for those). Check w/Ibis to be sure, but like d-bug says I think this is normal.
    On heavy rotation: White Lung: Deep Fantasy
    Got a reply from Todd and said that it looks fine. Thanks as well for your feedbacks. Do you guys put a dab of grease at the sleeves' faces before reinstalling the links? Planning to do that to mine but im worried that it will only attract dirt.
    screamer
    Personally I don't -- just the surface of the shafts themselves -- but I also can't remember what the ibis setup manual says. If you haven't already, definitely download the PDF off the Ibis website since there's some great info in there about torque specs, where to use anti-seize vs Loctite, etc. I think it tells you where to grease also, but I can't recall for sure.
    Thanks for the help! Cheers!
    Sep 2013
    What bike model is this?
    2013 mojo hd.
  1. WTB Bronson - extreme wear, is this normal?
    By kyle242gt in forum Wheels and Tires
    Last Post: 09-20-2014, 09:57 AM
  2. Lefty wear and tear normal?
    By Chain-L in forum Cannondale
    Last Post: 06-13-2013, 09:13 AM
  3. Is this normal wear
    By hags707 in forum Rocky Mountain
    Last Post: 10-20-2012, 11:57 AM
  4. Is this normal wear and tear
    By sturmruger in forum Brake Time
    Last Post: 03-21-2012, 09:33 AM
  5. warranty vs normal wear and tear?
    By joyride153 in forum Specialized
    Last Post: 06-03-2011, 09:58 AM
