Results 1 to 39 of 39
    Reputation: Trackho's Avatar
    Warning: Change Fork Oil in FOX Often
    I thought I was pretty good about doing this. FOX service just called and said my uppers (stanchions) were wasted on my mojo SL.
    Fork is a FOX float RLC FIT. Since oil migrates to the oil spring about every 3 weeks, I change is often-not so much on the FIT side. I put the SKF seals on about 9 months ago.
    Anyway- I'm getting new blinging kashima lowers, but its also costing me $150. I had no idea that the forks were this sensitive. Looks like I need to replace seals every 40 hrs which is every other month.
    So my front end looseness wasn't just the lower headset bushing after all.
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    Best thing to do with your fox is to use the lowers as bottle openers. That's how my Talas gets used. It actually does that pretty well. Better than the whole, working as a fork thing.
    I wish I was joking.
    Hope it gets fixed and you get back on the trails though!
    Sep 2012
    I just took apart my Talas 160 and there was NO oil left in one of the sides. "Squishy" ring was dry.
    Glad I opened it up when I did!
    cough Marzocchi cough lol
    MTB Monkey
    Reputation: Jefe74's Avatar
    Mar 2006
    Quote Originally Posted by nzl62 View Post
    Nothing is perfect. Just had an oil seal blow up on a 9 month old 44 RC3. Otherwise, pretty decent fork.
    Parts are on order. Oil seals are not covered under the Marzocchi warranty.
    But yeah, on the Fox thing, recently rebuilt a friends 32 Float RL that he had ignored for a couple of years. Uppers were toasted, with deep groves that lined up with the bushing seams, even on the open bath side.
    Sep 2012
    But I just got the cool $290 Fox shorts + window stickers!?!?!
    Reputation: vikb's Avatar
    I didn't service my Fox Float 36 [~2009 product] for the first 3.5yrs of regular riding [my bad!]. No damage. Fork works great. I'll be more on top of the service from now on.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: miles wadsworth's Avatar
    Nov 2006
    Why can't they make a fork that lasts as long as a car or truck shock(without service)?
    milesW
    Quote Originally Posted by miles wadsworth View Post
    They can. You aren't gonna want to strap a 10lbs fork on your bike though...
    Safe riding,
    Vik
    www.vikapproved.com
    bike rider
    Reputation: Lelandjt's Avatar
    It takes me 5 minutes to change the oil in my Fox fork*. I do it every couple months. I swapped to SKF seals a year ago and they show no signs of needing replacement. The TALAS cart seems to suck up chassis oil so when it feels too progressive I turn it upside down and depress the schrader valve to shoot that extra oil out of the cartridge. Let a little oil stay in.
    *Remove foot nuts, pull lowers down a centimeter, allow oil to drain. Flip bike upside down and use a syringe to refill with oil, re-install nuts. Could probably be done in 2 minutes if you don't wait for every drop to come out.
    Keep the Country country.
    Nov 2006
    Quote Originally Posted by Lelandjt View Post
    Thanks, will do. Now that sounds easy.
    milesW
    Reputation: Betarad's Avatar
    FWIW, If you have your Fox fork Push'd, they actually recommend against regular oil changes, or any oil changes for that matter.
    Not endorsing the practice, just sayin'.
    Reputation: Murchman's Avatar
    Quote Originally Posted by Betarad View Post
    Well that's silly, what's the logic on that one?
    bike rider
    I bet you're confusing chassis oil with damper oil. The damper is sealed and if they use a high end oil it won't need changing for long intervals and if it were changed you'd have to use the same oil they did to maintain the feel they went for. FWIW in 2 years I haven't changed my damper oil and don't feel any breakdown or change in damping.
    After reading about the 40 hour chassis oil bath change interval earlier this year, I inquired with Push since I had my 36 Talus Push'd and converted to a float a year ago. They told me unless oil is seeping out the top seals significantly, there's no need to change the oil bath.
    I interpreted their logic as a combination of two factors: The materials they use (oil, seals, etc) are apparently superior to Fox factory materials to some degree, and they feel any high performance fork should be completely rebuilt at an interval of about a year or two, depending on performance degradation and owner preference. So they basically instructed me to run it hard without worrying about a thing, and when I feel a drop in performance, it's time to re-build.
    I've run it for almost a year now....no issues yet.
    Reputation: getbusyliving's Avatar
    And as you guys probably know, the Talas fork is even more sensitive than the Float. I toasted mine by waiting a bit too long for oil change. And I had nothing but problems with that fork from the beginning, so I swore I'd never buy one of them again. There is hardly any oil on the Talas side and the Talas mechanism is just too fraught with issues.
    Everyone I know has moved away from Talas to fixed travel fork (various brands) which tend to be more reliable and better performance. I do miss it on the occasional long super steep climbs, but it's just not worth it.
    On the Push topic, I was told the same thing by Push...that you shouldn't have to change the oil after their service for a year for even pretty frequent riders, and by that time the fork needs a full service anyway.
    I have always ridden my forks until oil is leaking and then get a rebuild, I have never had a problem with Talas or Float
    Sep 2012
    I installed Enduro seals from Real World Cycling. Easy and awesome. No more leaks, smoother action.
    Easier to dial in the air pressure without all the stiction.
    The material of the stock seal/wiper is not that great based on the way it ripped apart while removing it.
    so I too have lower leg oil going into the air chamber ('12 Float FIT 36) - was wondering why i never gotten full travel - and ended up with busted left seal with Northstar very fine powder dust - no oil in the left air spring whatsoever and lots of dirt. doooohhh.... right side has a sludge - so I was overdue (used bike).
    but I attributed to filling in the lowers upside down when the air pressure was out (which I did once) as I got no oil a second time (and likely ~60ml in the air chamber once I figured out where it went). I wouldn't think oil could migrate into the air chamber without first loosing air... only time will tell if it stays in the lowers... but yeah it's much easier to change Fox lowers than my revelation was, though every 30h seems like often. Hopefully the oil stays there now, if not that's a pretty bad design.
    bike rider
    The guy who likes Enduro seals probably had the old Fox seals. The new ones made by SKF arw great.
    Chassis oil definitely gets sucked into the TALAS air chambers and apparently also the Float. Now and then flip the bike upside down and depress the schrader valve to squirt some oil out but not all of it.
    Reputation: Chris442's Avatar
    I am looking to replace the seals in my 2011 Fox 32 Talas 150 FIT RLC and am trying to figure out the amount of oil to replace. I have been looking on the Fox site and and am little confused. The Fox Dust Wiper & Oil Chg page says to add 7 wt oil which has to be wrong but the amount it says is 10cc on the Talas side and 160cc to prime the cartridge side. Then if you look at the oil volume page is says Red 35.2cc (damper) then Green 30cc & 10cc for the damper and spring side oil bath. Any help is greatly appreciated.
    Oil Volumes
    32 mm TALAS III RLC
    "Some people live an entire lifetime and wonder if they have made a difference in the world. Marines don't have that problem.
    bike rider
    I like 10 or 15wt to lube the chassis. About 40cc in each leg will do.
    Sep 2012
    43) 2010-2012 TALAS 150
    (FIT RL & RLC dampers) FOX Red 10 wt. Damper 35.2
    FOX Green 10 wt. Damper-side oil bath 30.0
    Spring-side oil bath 10.0
    FOX Float Fluid Main Chamber 3.0
    Negative Chamber 3.0
    So, if you're just changing the oil baths, 30ml and 10ml
    Dropshot Champ!
    this.
    I've rebuilt dozens of fox forks, and the enduro seals were decent. Certainly better than the old fox seals. But the new SKF fox seals are really nice. Stiction is down and they're a beefy damn seal. I'd recommend them to anyone doing seals, they're worth it and way better than the enduros.
    bike rider
    Quote Originally Posted by invictarocks View Post
    Yes 10ml is the spec for the air side, even for my much larger volume 36 180. This is very little oil and I've had good results running much more. If you're concerned about air volume and progressiveness you can check by compressing the fork to bottom-out (with no air in the cartridge) after re-assembly and if it does ramp up noticeably let a little oil out. I'd say a safe starting point is matching the damper leg's oil volume.
    Reputation: nightops's Avatar
    Dec 2004
    Quote Originally Posted by Trackho View Post
    they tried to tell me this when i sent my talas rc2 in an offered me a crash replacement to the new 180mm model. Not wanting to spend 550 i just waited and had them do the regular maintenence. The fork is riding as good as ever and no oil leaks...are you sure your getting kashima 'lowers' wouldnt that be the uppers including a new crown? for 150 thats pretty cheap. I think the RLC Fit design isnt as robust as the RC2 imo thats why so many people end up ditching the talas from this platform
    Sunshine Coast, B.C.
    Dec 2011
    I too ruined my stanchions on my previous bike with a Talus 36 fork. The bottom line is the 15ml of oil bath in the air spring side can easily leak out over time with you noticing. I religiously change the oil bath AND clean and lube the foam rings for the Talus on my current bike. I also store it upside down to help the oil bath seep past the bushing to the top of the fork.
    Jan 2013
    if anyone reads this
    Quote Originally Posted by DetailsMonster View Post
    Look guys if you have these nice forks, you better brush up on service, you can do it in 20 mins for almost nothing.
    for shocks that just use float fluid. Use a pump with a release valve to purge the old oil through the pump, it will not hurt the pump.
    do this by leaving the shock upside down while removing the old fluid
    now remove the Schrader valve core
    add the oem listed amount of float fluid by depressing the shock and slowly let it extend while adding oil through the Schrader valve.
    it gets sucked in
    you may have to do this a few times to get all the oil sucked in but its super easy.
    I use the same syringe for my brake fluid, just clean it.
    takes me 8 minutes going slow.
    clean up, set psi / sag
    your good
    fluid change under 10 minutes
    you can do the same thing for the air chamber on forks that use float fluid.
    the lowers will need to be disconnected to change the lowers fluid.
    but hats it
    May 2017
    Hi, i'm running on fox talas 32 fit rlc 150, changed the oil last year and now back to service, 100$ for complete service (oil, seals, bushings)
    I'm considering to move on the rockshoks fork...
    Quote Originally Posted by razvanu View Post
    Good idea, I hear you never have to service a RS.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    Reputation: Bigjunk1's Avatar
    Sep 2016
    Rockshox
    May contain nuts
    Reputation: Haggis's Avatar
    A manufacturer of bicycle parts
    Well Biked
    Reputation: scepticshock's Avatar
    Jun 2005
    A trick from Push: Flip your bike over for a few minutes before each ride to let the oil soak the foam ring and seal area.
    Reputation: Vespasianus's Avatar
    Quote Originally Posted by TwoTone View Post
    They are fantastic. I have an old Judy that I have had to do nothing with. Push down on it and it is solid as a rock.
    On MTBR, the reputation is infamous.
    I dig trails!
    Reputation: Mr.P's Avatar
    Feb 2005
    Quote Originally Posted by scepticshock View Post
    Yep. It works. Fox recommends this minimum of 15 minutes before a ride.
    P
    Quote Originally Posted by Vespasianus View Post
    Well played sir
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    DLd
    DLd is offline
    Feb 2005
    I did that unintentionally during my last race, and I could really hear the fork working a lot better afterwards. It really works! Funny, but also actually true.
    Fall is here. Woo-hoo!
    Well Biked
    Jun 2005
    Whenever you go OTB you can just say you were intentionally lubing your fork seals! ;-)
    Jan 2017
    And now the NEW one-piece Enduro Hy-Glide seals are at least as good as the SKF ones. More choices.
    Quote Originally Posted by redmr2_man View Post
    this.
Members who have read this thread: 30
