Results 1 to 5 of 5
    Using an 05 MK III Expert on Mojo
    Hi all,
    I'm thinking about getting an Ibis Mojo frame and put all parts from my 05 MK III expert into the Mojo. my MK III is stock so is there anything that won't work on the Mojo? I've never built a bike before so I'm not sure which parts will or will not work. I probably will have an LBS do the part transfer. Thanks.
    It's the axle
    Reputation: Gregg K's Avatar
    Without being familiar with the bike, I can give a few possible no-goes.
    Headset
    Seatpost
    Brake mounting
    I think your bike is 30 mm seatpost. Zero stack headset. Post mount brakes. Nothing big to overcome, though.
    I'm building up my own bike. It's way too fun to let someone else do. Everything is prepped on today's components. It's just bolt and adjust, pretty much.
    www.derbyrims.com
    Reputation: derby's Avatar
    Quote Originally Posted by Gregg K
    Headset
    Seatpost
    Brake mounting
    Also, the front derailleur is 34.9 Top pull bottom swing on the Mojo. I'm not sure what the MK is, I think it's top swing.
    Brakes should mount the same I think.
    Quote Originally Posted by houseofmusic
    Hi all,
    The front D is different.
    The seatpost is, too.
    Headset also. Hope you have a long steerer tube if you plan to use the same fork.
    Disc brake mounts are the same.
    And you'll need different shifter housing lengths in some parts.
    thanks for all the info. I decided to go for it and ordered a Green Mojo!
