Results 1 to 19 of 19
    Tyre clearance Ripley
    Hello,
    does anybody already tried a 2,35" or 2,4" rear tyre on a wide rim like the Flow EX in the Ripley? Is there enough clearance?
    If yes. Posting a photo or measuring the clearance would be great. Thanks.
    Chris
    Quote Originally Posted by HellDriverChris View Post
    Hello,
    Chris
    I put a 2.35 Hans Dampf on the rear - clearance was tight and the tire contacted the seat tube under full compression and started to make some nasty marks on the seat tube. Not recommended.
    Ardent 2.25 fits nicely and clears. Continental Mountain King 2.4 and Michelean Wild Gripr 2.25 rubbed the upper swingarm on hard corning or G outs. Hans Danfs 2.35 very tight also.
    Reputation: Colin+M's Avatar
    As mtnwater stated, it's kinda tight back there. I ran Rocket Ron's/Racing Ralph's 2.25 in Enve XC and there was no reason for concern, but I think anything much larger or on a wider rim would definitely rub.
    Ok. Thanks.
    Im not sure about the Ripley, yet. If I start the project Ill test a Nobby Nic 2,25" on the rear rim.
    2,35 Magic Mary for the front and a 140mm Pike. Hopefully a nice combination. Extra Trailstar grip for the front and low driving resistance for the rear.
    Just found this thread:
    Biggest rear tyre to fit the Ripley?
    The Ardent 2.25 EXO is a pretty good tire rolls well and has pretty good grip. Lots of room in swingarm.
    GMM
    GMM is offline
    Reputation: GMM's Avatar
    Motoguru200: what rims are you running?
    Ok. Thanks. Just found this thread:
    Thanks for the link. Interesting the Hans indicated the Schwalbe Hans Dampf 2.35" and Purgatory 2.4 would both fit. I can definitively say that neither of these two tires will fit. I have a Purgatory 2.3 on there now, and it still rubs the seat tube at full compression. I encourage Ripley owners to put a piece of protective tape on the seat tube...
    Damn, read this thread a little too late. Guess I'll be selling my new Conti X King 2.4.
    I think it makes a big difference on which rim you use. Flow ex are 18mm tall where Enve AM are 31mm. The Flows might work with a big tire. Anyone running 2.4 in the rear, let us know because I like to run Spec. Purgatory 2.4, F/R. Wide back tire helps on the loose climbs. I like traction, I'm not fast anyway.
    Not sure if rim height would matter as much as rim width, unless that is what you meant. I really don't see you having any room for a 2.4 tire on the rear of the Ripley, especially with any mud clearance.
    I was thinking about tire hitting seat tube at full travel. I should've made that clear. I don't really ride in mud so I'm going to stick the biggest tire I can back there. Just maybe put some protective tape and live with a little rub at the extremes. If I have to ride in mud to be able to ride, I'll ride my old bike.
    Overall diameter doesn't change with rim height. The same tire on a Flow and Enve AM will be the same height. A 2.25 tire will fit without problems and is about inline with the kind of bike this is. This isn't a big hit all mountain huge tire bike.
    I see that diameter should be the same with a given tire. Maybe I should be looking at the HDR 650b instead of Ripley for my do all, ride everything bike. But I do like my Rip9's big wheels, and like those eccentrics. I've got to test ride me some bikes.
    Rone Turner - Talked with one of the local riders at my LBS who's been running Butcher fr / new Purg 2.3 rear on LB rims on his Ripley for a few weeks without any problems.
    Quote Originally Posted by Rone Turner View Post
    Any sufficiently advanced technology is indistinguishable from magic
    - Arthur C. Clarke
    Quote Originally Posted by seleniak View Post
    I had an HDR on order before I went to an Ibis Demo and test rode a Ripley and HDR650. I changed my order to a Ripley. I feel like the Ripley gives you all of it on the downhill (as good if not better than HDR650) and climbs like a ****ing beast.
    Wouldn't the tire height be different with a wider rim (i.e. not as tall)? I have an XKing that has pretty low profile knobs and I'll be running Flow EX. I'll report back once this unicorn finally arrives.
    Thanks for all the info. I really want a Ripley, so nice to hear you liked it enough change your order from HDR to Ripley. 2.3 Purgatory is the biggest size they come in now, so looks like those on flows will work. Perfect
    Jan 2011
    Hi guys- sorry to resurrect such an old thread, but it's exactly on topic;
    I'm about to order my Ripley and I'm trying to decide between the Stan's Arch EX ($137 upcharge) or the Ibis Carbon 928's ($899 upcharge) or the uber-wide Ibis carbon 941's (same $899 upcharge). It's a good price, although I'm unsure about the hubs on any of these.
    But my real question is- should I be fine on a 2.2 Ro-Ro on such a wide wheel as the 941? All the reports talk about how much more volume the wide wheels seem to produce- unfortunately, the Ripley doesn't have massive clearance, so adding volume might not be a good thing.
    I'm mainly a XC rider/racer, so I tend to gravitate to the lighter 928's, but we ride in a lot of muddy, rooty conditions in the PNW, so lower psi is always welcome...
    again, sorry for the thread dredge.
    Ride On!
    Reputation: NorthSideOf50's Avatar
    Nov 2013
    Thought I would resurrect this thread, I have one on the new Ripley's and was wandering if anyone has tried a WTB Trail Boss 2.4 on the rear with a 941 rim.
    UPDATE: Ended up with a WTB Trail Boss 2.4 on the front and a 2.25 on the rear. Looks like the 2.4 may have barely fit, however in reality, there is little difference between the two mounted, with the 2.4 appearing only a little bit squarer and a bit taller.
  1. Biggest rear tyre to fit the Ripley?
    By simenf in forum Ibis
    Last Post: 3 Weeks Ago, 02:10 PM
  2. Replies: 23
    Last Post: 06-17-2014, 05:16 PM
  3. Replies: 18
    Last Post: 01-23-2013, 09:33 AM
  4. 5.5 EVP Tyre Clearance
    By JimboM in forum Intense
    Last Post: 01-22-2013, 12:09 AM
  5. A9C Tyre clearance
    By MavAndy in forum Niner Bikes
    Last Post: 03-08-2011, 04:46 AM
