Results 1 to 3 of 3
    For those of you that have mounted the bos vip'r on the mojo HD: help!
    Hello, I have a bos vip'r that I have mounted on my mojo hd frame, the problem is that this shock comes from another frame and the mounting hardware does not match completely: the upper bushing (mounted on the limbo chips) width was the same: 22 mm, but the lower one is a bit smaller, and I have to use some steel washers from the diy store...
    It's running fine but I would like to have the correct mounting kit!
    I've seen that some of you have this shock mounted on the hd, where did you get the mounting kit and which measures are needed?
    Thanks a lot!
    Can get this kit from most suspension suppliers/tuners but the std Fox reducers are available from Ibis. Shipping is very quick even if you aren't in the US, was about 3 days to UK for me
    Feb 2012
    can you use the needle bearings that bos make on the mojo hd? are they better than bushings, I would imagin they are easier to get moving, so making the shock more sensetive on small bumps,
