Results 1 to 3 of 3
Thread: Stem questions
    Dec 2004
    Stem questions
    What is the standard stem length that Ibis uses? I have a medium SL and feel pretty raked out on it. Considering going shorter, but not sure where to start.
    If I buy a shorter stem, any suggestions on brand or type? - i'm in Texas so the typical riding is aggressive XC. Lots of rocks and roots with some smallish drops.
    Thanks for any input.
    Happy when not-last.
    Reputation: MinskyBA's Avatar
    I've recently asked a similar question. The general consensus is to go with the Ibis stem over Thomson if that helps. They're plenty durable (no one reported a failure in previous thread), lighter and cheaper than the competition.
    AND IT'S IBIS!
    All your base are belong to ME.
    www.derbyrims.com
    Reputation: derby's Avatar
    Yes Ibis stems are very nice and reasonably priced, $40 I think. Go to the Ibis web site and they can be ordered direct, from 70mm to 100+ mm.
    Although when trying shorter stems I found some decent cheaper ones for about $20 on line.
    If you go very short like to 70mm, consider getting a wider bar than the 26.5 inch wide Ibis bar, about 27.5 inch and lowering it a half inch to maintain stability and climbing forward lean, and together with the shorter stem improve downhill balance, braking power, cornering feel, and standing pedal power.
    I don't know what the standard issue stem length is now if you don't specify when ordering. 4 years ago it was 120mm. I was coming from using an 80mm on my previous bike so I specified the shortest Ibis option then which was 90mm. Now you can get 80mm and 70mm also.
