Results 1 to 8 of 8
    Reputation: vizsladog's Avatar
    Sorry.....but wich mojos are 650b ready??
    How old and wich mojos are 650b compatible??
    I know the hd is but are any others??
    Mar 2005
    The Mojo and SL are supposed to be 650b ready. I'm not sure if early Mojo's are, but I'm not aware of swing arm differences that would negate 27.5 wheels.
    HD 140 is the only official 650B frame, but Mojo, Mojo SL and HD160 are with a shim in the rear shock to limit travel
    Only official ? where it says ? who said ?
    Mar 2012
    Quote Originally Posted by dreednya View Post
    Just curious... Not the SL-R?
    Quote Originally Posted by AaGro View Post
    SLR clearances are said to be too tight for 650b. As it is, even a Quasi-Moto doesn't leave a whole lot of room to spare on a Mojo SL.
    www.derbyrims.com
    Reputation: derby's Avatar
    This is asked so often, maybe I should put these 650b references in my signature....
    MBM blog where Scot "Sanctioned 650b for HD140"
    Fox, RockShox, DT-Swiss, Schwalbe and Others Develop 650b gear | The Straight Dirt | MountainBike.com
    Ibis has certified 650b for the Mojo HD140 - Mtbr Forums
    Mojo HD 650b. The HD140 clears 650bx2.3 with no custom modification, and is sanctioned by Ibis. The HD160 requires custom shock bottom travel limit shims.
    650b Mojo HD ... Heavy Duty
    Mojo C, SL 650b conversions with required custom shock shim limiting bottom travel clears up to 2.3 tires. (SL-R clears only small volume 650b tires.)
    http://forums.mtbr.com/650b-69er-new...jo-438747.html
    Shock Bottom shim instruction
    650b shock bottom-out shim for seat tube clearance
    Shock mount offset bushings. Lowers the BB 1/4 inch, and reduces bottom travel tire clearance. There are other options if you search google. These were least expensive and are well made. The HD has 40mm and 22mm wide shock mounts, both with 8mm shock mount bolt holes. It took 3 weeks for the two I bought on eBay to arrive from Poland.
    Offset Shock Bushings Mounting Hardware Mount Kit All Frames Proshox | eBay
    Thank you for this. Thinking of going 650b on my Mojo SL, and have been overwhelmed by all the posts/threads on the subject. Was clear that the HD's are 650b-ready, less certain about my SL.
