Results 1 to 76 of 76
    So my HD feels nervous on the steep stuff...
    ...I am currently waiting on my back ordered KS seat post dropper to help with this. But I am wondering if upping the travel on the front fork from 160mm fox air to a 180mm fox spring would fix the issue?
    Thoughts.
    Dec 2005
    It should help the issue by slacking the head angle, and lengthening the wheelbase, but it also raises the bottom bracket.
    If your fork steerer will permit, try using an angleset which will slacken head angle, lengthen wheelbase and lower the bottom bracket. This could be the better option of you don't need the longer travel in the fork.
    You could also look at your cockpit setup. Sometimes running a shorter stem and wider bar can help on the steeps as well. If you are running a 90mm or 100 stem and narrow bar, it can make handling skittish compared to more "modern" all mountain setups.
    Here, diagonally!
    Reputation: JACKL's Avatar
    I've slacked out my bike significantly, and I really like it thus far. Totally different bike though - a GT Sensor 29er. I removed a spacer in the fork to go from 120 to 140, which slackened the HA by about.8 degrees (measured on my digital level). This also raised the BB about .5 inches. I then installed Burgtech offset shock bushings which dropped the BB by .25 and slacked the bike another .5.
    I lowered the bars and adjusted the seat so that my position on the bike is about the same. Contrary to what I expected, it seems to handle fine on the tight stuff. It feels a little better going fast, and it's definitely more secure on steep bumpy downs. Overall, I really like the way the bike handles now. I picked up a little flop in the steering, but I can live with that.
    You might want to try a test run with the rear shock sagged more than normal, and the front sagged less than normal, just to see if you can live with the change. Try some switchbacks and steep climbs, as that is where the higher front-end may put you at a disadvantage.
    You can also run the change through this geo calculator: geometryCalc
    Wow, you learn something new every day.
    Thanks for enlighting me to this new invention, the angleset.
    It seems to be a great solution , judging by the google results of previous posts ( mtbr) on the subject.
    My LbS says it should go on my bike without a hitch and I am upgrade to the stock headset it came with. Win win!
    66 degrees seems to be a good angle for the HD and it won't raise the BB. Height like a taller fork would.
    Dec 2005
    Glad I could help.
    The other thing to consider is sag and low speed compression. Too much sag and / or not enough LSC will make the fork feel like it's diving. Check your sag and get that right first, 20-30% depending on riding style. After that, try adding a click or 2 of LSC.
    Singletrack Addict!!!
    Reputation: Relayden's Avatar
    Jun 2005
    What do you mean by nervous? does it feel twitchy? at speed? too responsive? I think in order to give you suggestions we need to know what equipment you have, stem length, handlebar width, wheels, tires, etc. Your riding background, preferences, how steep is steep for you, etc.
    Don't make the mistake of going slack for the sake of it, 67 deg is more than enough for the HD's intended purpose if you attain the skills needed. Hell the faster the bike goes the better she feels.
    The world needs a huge socio-economic change...be it. We all need to ride more....
    Well, I can't really add low speed compression. My fork is a FIT( float 34,160). I do run it in the middle soft setting ,if that makes any sense.
    As for the sag, that is set up right-ish( close 30%).
    I think the biggest issue , for me, is that the Ibis is a little steeper in head angle and shorter in wheel base than my trusty old Ventana.
    This angle adjust head set sounds like a great t
    Great tool... U
    Thanks, I think I have the question answered but here goes.
    Stem: 80mm
    Handle bar is all mountian size ( haven carbon? )
    Wheels: the ones that came with the bike .
    Tires are 2.35, big knobs.
    The nervousness only happens on the steep sections.
    Feels like my weight is too far forward. To remedy this I need to lean way back off the rear of the bike . My old bike never had this twitchyness to it.
    By installing the angle set, I can lengthen and slacken the head tube to match the comfortable feeling that my old bike had . I think one degree and and a half inch to an inch in wheelbase willmatch my old bike.
    Your old bike may have put your bars a little taller, the integrated HS lowers things a reasonable amount.
    I runn a touch more sage so the bike sits in its travel a bit more. I run a Roco TST air
    Reputation: Brisco Dog's Avatar
    You may want to consider a shorter stem. 80mm seems a bit longer for a bike that will have a 66 degree HA once the angelset is installed.
    Reputation: elsinore's Avatar
    Jun 2005
    Shock Shim
    Quote Originally Posted by saidrick View Post
    Stem: 80mm
    There seem to be some great suggestions in here, and your headed in the right direction with the angleset.
    Id also try putting a shim from the fox shim kits in your shock. I'm assuming that you have the fox. If you put the large shim in it should allow you to run a bit more sag (hopefully without bottoming out) which would help significantly.
    All of this stuff will help remedy that pushing you forward over the bars feeling in the steeps. In my opinion, the HD will still feel a lot more nervous on steep nasty DH tracks at speed compared to most 6" rigs out there. There is so much anti squat built into the design that you get that weight over the front feeling all the time. The trade off is that the HD pedals better than almost any 6" bike available, and its really, really precise so you can make super quick direction changes to pick your lines. When I made the switch from an SC Nomad that I was on for a few seasons, I sort of had to learn how to ride the HD. That is, the technique I used on the Nomad did not work on the HD for really Chunky, DH tracks. Once you get the feel for the frame and change how you ride a bit you will feel fine. Good Luck!
    Feb 2007
    Quote Originally Posted by elsinore View Post
    i changed my nomad 1 to a hd four months ago and i think exatly the same , i needed several days to adapt at the new ride , at the moment i' m very happy whith my purchase but next spring i will get an angleset ,ithink is the way to find a more stable ride. Some friends here in spain go with it and they say that the bike is a lot better.
    Nov 2007
    u're going to slow buddy. let go of the brakes and rip that "steep" section.
    Sounds to me like you are running way too much sag in the fork. 30% is a lot especially with the way that Fox forks like to dive. Try upping the pressure in the fork to around 20% sag.
    Also remember that the HD was designed around the 36/Lyrik with a 545mm A2C height. If I am not mistaken the 34 is around 535mm which would put your HA at 68 instead of 67.
    Wow, thanks for all the advice.
    I think that the shim kit for the shock would also be a good idea.
    Sales punk, your answer about the fork length would explain a lot of what I am feeling. The angleset seems to address this pretty well.
    As for the sag. As a 200lb rider my front fork seems to work really well with 85lb in it.
    My rear is a 185lb. The only time my bike dives is off of drops and jumps, which is when it should , right?
    As for going too slow. On tight, twisty, rocky single track, I am not sure how you speed up without flying off the trail. Which I done many a time, I call it coming in to a corner too hot.
    Again, I can ride the steeps, but I feels like I have exaggerate moving my weight rearward.
    I am curious what Hans or Scot think about the angleset?
    But thanks again for the helpful tips.
    Cedric
    holding back the darkness
    Reputation: subliminalshiver's Avatar
    Angleset + 50mm Stem FTW!
    **** censorship
    Yep Sales punk is correct. The fox 34 fork is shorter (7.5mm-ish) than the 36. The angleset is the cheapest solution to a problem caused largely by Fox.
    Can't wait to have my mojo with the correct 67 degree head angle.
    Thanks for the help.
    Lightly salted
    Reputation: fuenstock's Avatar
    Your issues sound more like being a problem with how the bike is setup. Like others have said, an 80mm stem is a bit long with this type of bike. Most are running 50-70mm stems on the HD's. I run a 50mm stem on mine with wide 31" bars. The short fox 34 is not helping you either, since it's effectively making the head angle steeper than it would be with a fox 36 @ 160mm.
    A good way to set up the HD is with 30-33% sag in the rear and 20% sag on the fork. Try messing around with settings to get a balanced feel front and rear. Don't worry so much about trying to run a certain psi in the fork - shock and go more by sag. To much sag will cause fork to dive deep into travel on steep sections and if it doesn't have enough sag the fork won't track very well and feel like it's skipping bouncing off rocks instead of absorbing the terrain.
    It can take a while to adjust to a new bike, just give it some time and mess with the setup to get it feeling good to you. The hd is a great bike.
    The stem shouldn't be the issue. The reasoning behind this is that my old bike never had this issue and it had a 90mm stem. Plus, the new handlebars are wider than the old bars, so that shouldn't be an issue either.
    I run the stem that long because I have long arms, so a large Frame size and a medium stem length make for a comfortable up and down bike.
    As for the sag. Numbers. I tried various psi combinations on the ride route before deciding on those numbers.
    Now, if I get the angle set, seat dropper, installed AND I am still having problems then I will try out a 70mm stem.
    I am running a 90 mm stem and have no problems riding the steeps such as Telonics and the like. People are fascinated with short stems, but it is all what you are comfortable on.
    Jun 2005
    Short Stem
    Quote Originally Posted by Salespunk View Post
    I would not discount the short stem thing right away. The reason people are fascinated with short stems is because they work, really well in fact for aggressive descending. There is not a modern DH bike out there with a stem longer than 50mm.
    Sadrick, just because your old bike handled well with a longer stem, does not mean the HD will; especially if you widened the bars a bit. The short stems are a compromise in terms of trading off a bit of climb-ability in the sense that you don't have as much weight way over the front of your bike on steep ups, but its not really that hard to get used to. The payoff in terms of descending, in my opinion is HUGE. If you ride modern trails with Berms, you will notice the difference even more. The bike will be more agile and you can really jam it in and out of turns harder. In short, it is less nervous, which I think is what you are looking for. Id seriously try a 70mm and give it a good 5- 10 rides and some time to change your technique a bit because it will not feel great at first if you try to ride it like your old rig.
    Stems these days are not all about sizing, maybe on road bikes but the HD is a 6" travel machine designed to do it all. I'm 5'11" with a wingspan of 6'2" and run a 50mm stem on a large frame. Having said that I used to run a 90mm stem 8 years ago but have gradually shorted my trail bike setup over the years. I really think an angleset and a 90mm stem sound like a bad idea, but again that is just my opinion.
    No offense meant Salespunk but a 90mm stem on the HD just makes me nauseous
    Thanks Voob. The video featured one of my mountain biking idols: Richard Cunningham.
    The FSA seems to be a good option ( pun intended ) but seems to also require a very detail oriented install like the Canecreek.
    So I follow Occam's Razor: the simplest solution is usually the most correct one.
    With that in mind, it seems that if my bike is Not feeling great on the super steep stuff because of a non- designed steeper head angle. Then it follows that the solution should be to remedy the change in geometry before doing anything else.
    This gives me two options:
    1. Is to replace the fork with a longer a2c or more travel. This would cost around a grand.
    Option 2. Change the head angle with an adjustable head set. This would cost about 200 bucks
    As for my old bike: I bought the mojo HD because it seemed very similar but better in every way. So far the mojo is better , except for this little issue that I hope to resolve very soon.
    For reference : my old bike was a Ventana El Chamuco.
    Thanks again for the insights.
    Some headsets have a plus 5-20m stack that goes below the head tube. I ran one on my Foes FXR and many of the top Enduro DH racers run these such as Rene Wildhaber.
    Cheap option, and better with the 34 than running an angleset I believe, which may have the effect of lowering the front a touch.
    www.derbyrims.com
    Reputation: derby's Avatar
    T.....
    The HD160 has a slacker head angle than the Ventana El Chamuco (67' vs. 68').
    HD's longer travel fork's deeper dive than the Ventana when braking hard may be what the difference is you are feeling.
    The least cost steep downhill braking improvement would be adding a little more more air in the fork, as was first suggested. And/or lowering the seat before dropping off a steep section to more easily get your weight back and low.
    I doesn't sound like your problem is high speed stability where a slacker fork angle helps. For brake dive, a shorter stem is much less expensive and easier to replace than an Angle-set type headset or taller fork. An 80mm stem seems long for the HD unless you are already maxed out in fit on an XL size. Even 10mm shorter makes a big improvement in downhill handling. The OEM Ibis "DH" bars are pretty narrow too. A 725 to 750mm bar with short stem improves stability and control where the HD likes to be ridden.
    I'd say get a remote-dropper seat post before spending any more than the cost of a shorter stem and wider bars to improve riding steep drops. A dropper seat post is a huge improvement for trail riding where there is much climbing and drops or rocky and smooth trail mixed often on the same ride.
    A slacker Angleset type head set is great for gaining stability at high DH speeds and improve high speed cornering traction on smooth trail loose dirt or slippery sandy dirt, such as is the predominate trail surface in southern California and Arizona and many high mountain trails. And a slacker fork angle does position the same bars and stem further behind the wheel. I'd say do this if your high speed on the HD feels too twitchy, but that wasn't your issue.
    Reputation: G-AIR's Avatar
    Sell the 34 and get a 36, lyric, 55, vengeance (160) fork. You probably won't lose much money if any. I would go to the angleset as a last resort.
    And like many here have suggested don't run so much sag in your fork. This is the first and easiest thing you can do. 20-23% is what you should be looking for.
    Reputation: Yody's Avatar
    If you have the CTD Float 34 and run it on the "D" setting your fork is probably diving from no compression and not having a seat dropper all your weight is going forward. Put the fork in the Trail position and learn to shift your hips back and put your chest down, elbows bent. As well make sure the rebound is not too fast in the rear shock, and your front rebound is not too slow. I looked at your user profile and bike setup and you do NOT need a 180 fork or an angleset based off your build and feedback.
    I see youre from Petaluma, what trails, are you riding that are steep and throwing you off?
    Hey Yody,
    A couple of things:
    1. That 34 fork has a shorter a2c than the 36 that the bik was designed around.
    Per "Sales Punk" this would equal a steeper head angle. About 7-10mm shorter, which equals a + 1 degree steeper angle.
    2. I run my fork in the trail setting with a click of soft added.
    3. As for my fork sag. I am only running 10 pounds less than Fox's recommended starting psi.
    4. My rear runs no pro pedal, feels too spikey with it on.
    5. I have had the best feel with running two clicks from full rebound fast.
    6. I adjusted the suspenison settings by riding at Annadel. Climbing Richardson/ canyon and marsh and coming down both burmas(south and north). I have know issues with the bike here.
    The issues happen on cobblestone , in Angwin, and even the little rocky section at China Camp(!?).
    It seems to be the short,twisty, little steep drops that are hard to carry speed into.
    That KS seat post dropper is still back ordered.
    Add 2 to 3 more clicks of rebound in the rear, add two more clicks of compression in the fork, and get the seat dropper. You do not need an angleset to ride annadel, when you say steep, north n south burma would never come to my mind. Yeah the fork is a tiny bit shorter, but adding parts, expensive ones that are hard to set up and keep that way, especially, doesnt aound like the answer, you will likely not like the way it climbs when you slack it out.id get a seat dropper over an angleset, and id get one asap. Sounds to ke like ur rear. Shock is a pogo with no rebounc compression and you got the seat shoved up your butt, that would make me nervous too, lol.
    Right Burma's are good.
    It's cobblestone, rough go and some of the fringe outer areas (ridge?)of Annedel.
    That cause the issues.
    www.derbyrims.com
    20mm change in head tube height is about 1' head angle change.
    Yodi's tuning suggestions are good for the jumps on Upper and Lower Burma, and Cobblestone. Nothing mentioned is fast or sandy/loose enough for needing a slacker fork angle.
    BTW, Is there a rocky section inside China Camp? Sure, the south side of the ridge in the San Rafael City park's Dominican side, there's some rocks.
    Lightly salted
    Saidrick,
    I ride all those same trails you mentioned on my hd as well as my hardtail with 71 degree head angle. You really wouldnt need a slacker head angle for those trails, plus the angleset is high maintance. I have one on my dh bike. I still feel its your suspension set up. I sell my old bikes and buy new bikes every year so I have had many bikes, including a few ventana bikes. I think the hd could be tricky to setup compared to a lot of other bikes I've owned.
    2 clicks from full open rebound in the rear is to fast. You should probably be some where around 5-7 clicks from full closed rebound. To fast rebound will make the bike stink bug on down sections. A few basic tunning tips are,
    Run rear at 30-33% (.75inch) sag with around 5-6 clicks from closed rebound and no pro pedal
    Run the front 20-25% (1-1/4 to 1-1/2inch) sag with a slightly faster rebound than rear and enough compression to prevent brake dive.
    You want the fork to stay high and the rear to settle into travel on downhill sections. Don't pay attention to fox recommended psi, most will tell you that fox setup guides are way off. Set suspension by sag. Try to get front and rear feeling balanced, with the fork being slightly firmer and faster than the rear.
    Don't give up on a shorter stem either or maybe even adding a few spacers under your existing stem. Small changes can make big improvements. If your every free to ride weekdays shot me a private message and I could bring a bunch of stems for you to try. I have spares in 50,60 and 70mm.
    Good luck, the HD is an awesome bike!
    All right, due to many replies about set up and sag. I will measure my sag later on today.
    As for the compression in the front , I am very limited by the fork: I have open , closed and half and half( trail). I get to adjust these by one click higher or lower.
    So I usually run the trail setting with one click less of compression damping. A magazine said this was a good way to go.
    As for the rebound, per Fuenstocks advice, I will try doubling the rebound in the rear and adding a click in the front. So 4 clicks from full fast in the rear and 3 clicks in the front.
    I will wait on the angleset, until after the dropper is installed, but I am not giving up on it either. If the bike still feels weird, I think I will give it a try.
    Are you on an RP23 rear? 4 clicks from full open is very very fast in my exp.
    If you go through the threads you will find many references to 2-3 click out from full slow
    On good way of judging rebound is to bounce on the bike and it should rebound and compress back to and not past the sag point, so no bounce
    Moto cross guys often setup their bikes from full slow and firm and back it of until it doesn't feel too hard. MTB riders tend to rely on the spring over damping, but in an air fork / shock the spring can vary a lot based on temp, so I personally believe that running more on the damping is better (ie a touch softer with a bit more low speed and rebound)
    Often the feeling of the back end bucking around on steeps is down to spring rate or compression rather than just rebound too
    Also on many of the pro pedal type shocks, the rebound needle doesn't start to engage the port for the first third or so of its adjustment, so you can actually fool yourself that it is making a diff. On my Kashima RP23 (2012 Mojo) the rebound adjuster did nothing for the first third to half adjustment then became very progressive. This was verified on a Dyno back in the uk.
    I would set you sag then make the rebound full slow, then ease back from there. Do it on a few runs on a trail you know well, do the rebound only on the shock only before moving onto the forks
    my 2c
    Reputation: mazspeed's Avatar
    You might want to add some air to the fork as well. You said it's down 5 pounds from your weight on fox's weight chart.
    Here is how mine is at.
    2012 fox rp-23 with a med shim. one click faster from the middle on your speed rebound.
    2013 CTD 160 117lbs or half my body weight. (I'm 220 but I like a touch more air in the fork) Speed in front is faster than my rear, but not a lot, maybe 1/2 way from center to full. maybe a tad less, I would have to look at it more closely. I also keep it in the trail setting. I will move it to climb when I climb, but if I am bombing down a really bumpy or know lots of jumps on a trail, I will switch to "descend". But I don't keep it there long.
    The shim really helps the progression of the rp-23. My sag is about 22-25 percent, again a personal preference.
    I have an angelset on mine, no problems with it, but I slaked it out .5 of a degree when I took the fork from a 150mm to a 160mm. I wanted the exact set-up I had at 150 and this is what Hans told me to do. I have a dropper post, but ride more BMX style which is more back on the bike so having a dropper post doesn't help me at all. But for most it does. A lot. The advice you have on this page is very good.
    I see you're somewhat close, if you have more issues, drop by my house sometime and I will try to get you sorted. Again riding is all a personal preference on how you want your bike to act, you may like it my way, or other set ups, but the cool thing is, you will not have to spend a lot of money fixing the bike to how you want it to react. That's the great thing about the HD it is so customizable.
    And the sag results are in: I measured my sag , front and rear. I got some interesting results:
    On the rear , at 185 psi I measured 7/8" sag, re-measured it twice to be sure.
    Added 5 psi and got 6/8"(3/4") , which would be right around 30%.
    On the front things got more interesting. I was sagging at 1". Remeasured twice for accuracy.
    I took 5psi out of the fork to get the sag to 1 1/4".
    The rebound thing is still a bit of a mystery to me. The new models have between 12 ( shock) and 18 clicks. When I originally set them up, I started in the middle and kept adjusting until the suspension stopped feeling dull and packing down.
    To measure front fork sag, you want to kinda crouch over the front a little. Sitting on the seat upright with locked arms, doesn't put much weight on the front. Shoot for %30 sag front and rear. Rebound close to the middle settings. You want the front and rear to both rebound with control, not sticky, not pogo. You want them to be be somewhat similar, so bounce them while on the bike standing out of the saddle neutral body posisiton, and bounce a little and make sure it is fairly the same front to rear.
    How much do you weigh and what air pressures are you running front and , also post a picture of the bike so we can see your setup
    I will post a pic later today,
    I weigh right around 195-200.
    The front psi is at 75(sagged 1 1/4")
    I also crouched over to do this. Well as much as I could while balancing against my garage door frame. .
    The rear is at 190psi( sagged at 3/4").
    I think I need to ride the bike again, and maybe run 4 clicks of rebound in the front and 5 clicks of rebound in the rear. To see what the bike is doing.
    Also I will try the old rebound test: push the seat down and see if the rear wheel comes off the ground on the rebound.
    Reputation: wilks's Avatar
    I would run 25% front end sag 30% rear. Talk to someone like Craig at Avalanche he recommends no more than 25% for trail/am type riding on the front.
    Yeah, and %30 really means like %35 once you get on the trail. Personally I usually do front fork air springs by feel, not by sag.
    I've installed -1deg angleset together with a 170mm Marz 55 on my HD recently. The bike is more stable and still climbs very well (even with single 32t chainring). It took some time to get used to a new geometry, especially when cornering, but overall it's a step forward. You can find some pictures here Ibis Mojo HD with Cane Creek Angleset | unluckypete.com
    I also strongly recommend using short stem (50mm) and a wide bar (at least 750mm). But as guys already said, it's best to get your bike dialed in first, and play with angleset if there is no other way to achieve what you are looking for.
    wow, loads of info here, thx to whoever posted the geo calc!
    Okay people, thanks for all the help on this. I love my bike, but just need a little help to get it right.
    So I sent an email to a industry professional engineer/ former frame designer( Mantis) .
    His answer was very interesting. He recommends the shorter stem too.
    What was interesting is that he said I should try "offset bushings" for the rear to slacken the head angle without the issues or cost of an angleset.
    So I did some research and found a company in England , called Burgtec. They make titanium offset bushings that get pretty good reviews. So the threads here say that I should add a volume reducer with the bushing to help keep it from bottoming out too much
    Thoughts, experience with offset bushings?
    Btw, 70mm stem is being ordered.
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    smart move ordering the 70mm stem.
    I read you were riding annadel and thinking about an angleset and immediately got confused.
    Rough-go and the burmas are perfect for a xc hardtail!
    Mtb Guide
    Sep 2012
    Saidrick, finally you are listening re the stem!
    Though for 160mm that is still long but at-least its a start.
    Before making any other changes when it still dosent feel quite right DO NOT upgrade to offset or headset angle set until trying a 50mm stem.
    2: key reasons, this will not fix what is a bad setup, 70mm is still long with the modern geo of a long travel FS.
    3: Your body will be in a slacker position but you will be unbalancing that by being pulled to far forward, offset requires an even more aggressive bike riding style and position/setup.
    You are basically trying to ram a square peg in a round hole.
    Sort your sag out and your rebound your front is still way to soft spring rate, slow and rear too fast rebound.
    Im a ex downhiller I ride mine in 140 mode in no way do I feel the need to run offset anything, basic and correct bike setup will solve all your problems.
    I jump the **** out of it and bomb downhills.
    Offset bushings and headsets are for advanced riders on steep stuff, I consider myself more a DH Enduro guy now, def not XC and do not feel I need anything other than stock.
    I run a 50 mm stem on my bike in 140 mode!
    Theyre has been some great info here which I think you are neglecting
    Cheers happy trails dude.
    Maverick, not sure how I am neglecting the advice:
    As a result of this posting, I have researched adjustable headsets, which I didn't even l know existed.
    I reset my sag per the forums measurements.
    I watched a video that was posted, which said that my stem was not too long.
    But I am going to try a smaller one anyways.( btw, the guy in the video is the same guy that recommended the offset bushings)
    I learned that my bike is not built the way it was supposed to be.( Fox's fault, IMO)
    I slowed down my rebound , per the advice.
    As for the 50mm stem. I will see how my back handles the 70mm before I even consider going any shorter.
    Thanks again for helping me sort my bike.
    Cedric
    Try the 70 before just ditching it. Its not too long. its a personal preference. Ask Hans/ibis about offest bearings.
    Reputation: Tkul's Avatar
    Just curious why no one suggest a steer damper?
    In motorcycles everything is cured with a steering damper (some having it fitted has original equipment).
    For MTB here it goes: Welcome to Hopey.org
    PS - you could also fit eccentric bushing.
    Thatīs what I did (Yellow text - translated using Google - will correct some phrases with time... or you could try reading Portuguese ):
    https://sites.google.com/site/bttpor...ometrie_change
    Quote Originally Posted by Tkul View Post
    I dont even know where to start on this post....
    Stem length really depends on the fit of bike. 70mm is a great compromise and middle ground between climbing and descending. 50mm is likely too short.
    From the get go it has sounded like Damper tuning and riding rechnique. No need to start custom tuning and altering the bikes geo. Thats what we would call a bandaid
    Yody, please remember that my bike currently does not have original geometry. So I don' think I am band aiding when I want to get the bike to have its intended geometry.
    I find it highly unusual that my issue and the scientific evidence ( shorter a2c) are so closely related, and yet one is not causing the other.
    Never the less I am going to try different things until I get the issue fixed.
    So here is a recap and a list of what is being done and in what order.
    1. I am still waiting on the dropper ( KS LEV)
    2. I have ordered the 70mm stem. I also run about 3 spacers underneath the stem.
    3. I will be re-evaluating the rebound settings on South and North Burma. I will try softer first . If it feels better. I will stay with it.
    4. I will give the 70mm at least three to give rides to see if it works better and fits my body.
    5. Finally, IF all of the above fails, I am going to try the offset bushin idea. I will start with one and add the second I if need to .
    Thanks again, I have learned quite a bit from this.
    Cedric
    Slowing the rebound makes it harder not softer.
    your fork barely makes the HA a half degree steeper.
    Offset bushing is not gonna make that big of a difference, and will make seat tube rub even worse
    Really I think your main problem is this;
    You don't have a seat dropper. Plain and simple. The HD has a slack seat tube angle which puts your seat farther back compared to another bike with a steeper angle. I like this because when you have the seat DOWN, the seat is farther behind you so you can stay more neutral in the bikes cockpit while descending. When your seat is not down, you have to scoot back to get behind the seat to get enough room to move around. Likely you're scooting way off the ass-end of the bike making you lose control of the frontend, and the bike feels less controllable. Now match that with a 90mm stem making the bars even farther away making the reach even worse. And your rear shock is set so loose the rear of the bike is bouncing around and unloading, pitching you forward, and steepening the head angle.
    So you come online and everyone tells you to "slack it out" and do all these mods to get the latest so called Geo numbers that everyone thinks are better. They are better for some riders, riding steep stuff, or mostly DH, or just for people who feel cooler with the new era low/slack bike. I've been against you modding your bike throughout this thread because from the sounds of it your fundamentals are off on body positioning and bike setup. Throwing money in the wrong directions will only bandaid the real problem.
    Thats my opinion based on the limited information I've read here.
    Yody,
    You have a good theory on the ergonomics of trying to use the bike without a dropper.
    I just hope the dropper gets restocked sooner rather than later.
    Quote Originally Posted by Yody View Post
    Really I think your main problem is this; You don't have a seat dropper. Plain and simple.
    Didn't knew about that issue of installing eccentrics on HD.
    But this little inexpensive hardware change the bike handling as much as putting more SAG on rear suspension.
    Not having a Seat Dropper it isn't a problem, you could always drop the seat post manually - like everyone did before droppers.
    Regarding stem length,
    On Ibis website, you can check that stems goes from 70, 80, 90, 100, 110, 120, 130 (mm). Although this information is worth what it's worth, installing short stems on HD (and Nomads) can bring a fitting problem due to its short top tube.
    Do you feel stretch on the bike with the 80mm stem?
    Agree that body position can improve bike handling (don't know how you modify something without checking your ridding technique). You could buy Lopes Book - it gives some hints and tips.
    No one talks about steering damper as a solution for some instability and everyone tries to slack the head angle. The thing is: it takes the edge on medium/high speed events.
    It's something that has been accepted on dirt/road bikes, and it seems, MTB is looking at it sideways.
    If your problem is low speed, than, you might hit the thing faster.
    Regarding (again) stem length:
    Nomads and HDs are very similar in terms of geo-numbers.
    You should always fit on the bike, even if that means putting a 70 mm stem (you feel better with 70 than 50, than stick with 70mm).
    Installing short stems on bikes that originally were design on mid stem length will put the rider in awkward positions while climbing.
    PS: How can rebound makes a harder fork?
    Stem length and cockpit length --> Look what Mondraker did with the Forward Geometry:
    http://www.mondraker.com/12/imagenes...ry_PDF_eng.pdf
    Attached Thumbnails Attached Thumbnails So my HD feels nervous on the steep stuff...-apagar.jpg
    MTB B'dos
    Reputation: LyNx's Avatar
    Actually if the Reach is the same on both bikes, then you would need a shorter stem - If you move to a wider bar it spreads your arms further apart, thereby pulling you further forward, hence you should change to a shorter stem than before to be in the same position (unless of course you wanted to be pulled forward) and that's why the engineer also said get a shorter stem.
    Lightly salted
    Cedric
    Pricepoint has the 31.6 125mm and 150mm KS Lev instock right now. I buy from them often and have never had a problem. I live in the same area as you since it seems we ride alot of the same trail. Deliveries from Pricepoint usually only take 2-3 days at most since they are just in Socal. Just an option if you can't find a local dealer that has a Lev dropper.
    Kind Shock LEV Adjustable Seatpost w/Remote at Price Point
    I don't know what a steering damper is . I don't think there is room in the head tube to add anything else.
    I am hoping that the 70mm stem+ seat dropper will fix the issue.
    Proper sag( now) and a slower rebound in the front and more so in the rear should also help :
    5 clicks from full open ( rear) and 4 clicks from full open (front) .
    Zero pro pedal and medium / soft compression in the front.
    Mtb Guide
    Sep 2012
    Cedric
    Well from reading all the posts, why I haven't jumped in earlier, and still following your settings you last set your sag too, its still out of balance front to rear imo/e
    Why I have said you're ignoring the obvious, Fuenstocks first post was bang on, you're working the wrong way round in my experience.
    Before I go any further though, since my post others have posted more conflicting info and to me you have asked the question asked for help but seem and I apologise in advance if Im wrong by still not getting the basic settings right.
    Note: Stiffer spring rate(more air) slower rebound required
    Softer spring rate (less air) faster rebound.
    You have to fine tune to suit from here.
    If you don't then all other changes are irrelevant and will accentuate your problems.
    1: Fork a2c is not your issue, if is Is then you on the wrong bike any good rider can handle a few mm in a2c changes with suspension setup.
    2: Im concerned on the size of your frame if you still need a longish stem.
    As I said I run a 50mm on my HD at 140 mm travel which has a steeper HA than yours using the same fork.
    3: They're is nothing wrong with the 34 chassis, the dampening or std valving for CTD is poor imho in its first generation and, for a high end user and expensive fork, Fox have screwed this up, provide basic controls for budget forks, high end forks should be tuned or allow simple tuning for aggressive riders without going to a FS specialist.
    I mention this as with proper static sag measured with you and your gear on the bike the fork will be too soft for dynamic sag requirements while riding.
    I run mine in trail mode but full hard setting on the black dial and its still too soft.
    I cant go harder in stock mode e.g more air as this extends the air spring lengthening my travel, Im going to get a custom spacer made to handle the internal negative spring and up the oil from stock height by 25cc to make the fork more progressive and see what happens.
    To counter my issues Im running very fast front rebound to keep my fork higher on the downs and my rear is 3 clicks out from full slow bike rips but still not perfect up front.
    To give you an example on my shock fox ctd note: its shorter than your HD 160 so this also affects spring rate and rebound, so you cant directly compare, I run 200 psi in my rear shock, Im 210 lbs all geared up, I have no mid stroke issues or bottom out, I regularly jump 4-5 m gaps big drops and black diamond trails not DH trails but hard core. Note Im talking shock here.
    Fork I usually run harder than the shock Sag is just a beginning point, I go by feel,
    slightly harder 5-10% depending on terrain, I don't go for balance front and rear especially on bikes with built in anti sag this compounds the issue you have in my experience.
    I run 90 psi in my fork as fast rebound as possible while still maintaining traction, eg not kicking me in the face over roots rocks etc on on hard jumps heavy compression.
    Size of frame, I'll stand by my argument and experience on longer travel bikes for climbing long stems are band aids, if climbing like a XC lycra rider is your thing what are people doing on 6" bikes, you compromise the all round performance of modern light long travel bikes, the HD is an easy bike to ride but its still a high performance frame.
    Size right, cockpit right you should be able to ride uphill all day on the HD without a long stem.
    Bar should match stem, shorter stem wider bar within reason of your own body dimensions.
    As Yody said slack seat angle, even Ha a longish stem compounds the balance point on a LT bike like the HD especially in 160 mode, what you can do on a hard-tail or even short travel FS those rules do not apply in longer travel.
    You must unlearn what you have unlearned, get the basics right is all I"m saying as others have said earlier before trying advanced!!! And expensive modifications that will make it worse.
    Good hunting.
    STEERING DAMPER
    Basically, steering damper is a device to control uneven shake of the handlebar on rough surface or on a dump, giving control and "releasing arm force" for "other things" rather than thinking and forcing to control the bike.
    It is something used on Off-road and on-road vehicles - 2 or more wheels.
    Personally I only have experience with motorcycles, and the steering damper, gives you an edge on rough surfaces, or over bumps (like the ones you find in track circuits).
    Me and my brother did an experiment and used a racing motorcycle (road) on Braga's Track that had a S turn, that could be cut if we passed through the berm jumping on the red/white stuff.
    Without steering damper, the handlebars, would shake like crazy making it near impossible to hit it without mental stress and risk of falling of!
    With Steering damper, the handlebars would stay ok, you would feel the bump, but nothing extraordinary, and could easy repeat every lap, without any stress. Something like: pointing... shooting!
    4x4
    Quads
    Road Bikes
    Dirt bikes
    MTBs:
    Thatís a Hopey steering damper you can see up front. Even with his brace, Tomís right arm only provides limited support and control so the damper helps to stabilise the steering and keep his wheels straight, especially in the rough
    A personal touch on Ragot's bike is this moto inspired steering damper. In heavy cornering, it stiffens up the steering feel of the bike. Zero offset stem for the Summum.
    There could be another solution and it's much simpler than a steering damper...
    If you death grip your handlebars all the time, your whole upper body is stiff and all the vibrations and trail feedback goes through your arms to your chest and head, generating this sketchy feeling regardless of how your bike is setup. Try out the "Heavy feet, light hands" approach that Lee McCormack teaches Lee Likes Bikes
    It really worked for me
    I also think that improving bike technic is better than spending money on bike parts.
    I've got Lopes/Lee book, and although I ride bikes for a long time, I've learn something or get conscious of things that I were already doing.
    The book:
    Book+time to practice = lot's of fun on trail
    Well , I have rereading the posts: here I my revised update.
    Maverick: I think you're right about the wider bar making the reach longer. Hadn't considered that part of the equation. But it makes a lot of sense. So 70mm stem it is.
    I am going to buy the lopes book, sounds like a good read.
    I have my bike sagged, but I don't understand the difference between trail sag and street sag. Aren't the weights the same? Assuming that I use the camelbak for the street test.
    I think I should start over on the rear shock rebound. Go back to the middle setting. To see what the bike is doing.
    Fuenstock, thanks for the price point link.i called a certain LBS ( corner of college and Mendocino ) and told them
    They need to find one quickly or I will have to buy the one on price point. They have since made a call to their buyer.
    As for the steering damper. I don't think that's the issue. I think its a perfect storm of tricky bike to set up, not keeping the changes to the cockpit consistent ( wider bar but not a shorter stem)
    , rear rebounding to exacerbate the issue and and having to go way back to get behind the seat post. I think this last part is part of what is making the arms stiff, too straight , not enough bend.
    Thanks to everyone for showing me a multitude of options to help me with my new ride!
    P.s. Hans, after Reading Bike Magazines bible of bikes review, I am thinking that head angle issue can be overcome with minor adjustments instead of major ones.
  67. #67
    see if you can borrow a 50mm stem from someone too and have a few runs with that.
    leelikesbikes.com has a really good piece about stem/bar width but you may have to skip back though older entires. He's the author of the Mastering Mountanbike book.
    The way I see it, this is a 160mm bike, so it's focus should be on the descents. I don't spend too much time setting it up for climb, hence 50mm stem and 760mm wide bars on a Large (I'm 5'11 - long legs and arms - shortish torso). The compromise is with climbing - I make it as comfortable as possible but I won't compromise what I like for the descents (inc Minion Tyres, flat pedals etc)
    Look at what Maverick says about rebound - 3 clicks from full slow. Thats where I had mine when I had the RP23 too. 2 clicks from full slow on my old mMojo classic. Its not bad but not nearly as slow (nor consistent) as many people run their DH rigs.
    I'd say put it there, do some runs on a steep section you know well.
    There was a great piece from a guy called Chris Porter from Mojo suspension UK (Fox dealer fro uk) where he pretty much debunked all the current consensus on men suspension setup such as
    - must have rebound fast to return bike for next hit
    - must use as little compression dampening as possible
    etc
    I'll see if I can find a link. He is very outspoken but makes a tone of sense
  68. #68
    To me a sterring damper on a bike is trying to correct a problem that's not even there. Not for a Mt bike anyways.
  69. #69
    here ye go. Comes across as a bit of a cock but ...
    Attached Thumbnails Attached Thumbnails So my HD feels nervous on the steep stuff...-porter_pg1.jpg
  70. #70
    Dec 2004
    By a short stem and wide bars. It will be cheaper than an angleset too.
    Im running a 150mm fork on my HD 140 and it rails. Angleset, 70mm stem, and 780mm wide bars. With the angleset on my HD140, its the same HA as a reg HD.
  71. #71
    Reputation: Ethan F's Avatar
    My .02
    I've been on a HD for over a year now and these are my findings.
    My ride: 145lb, aggressive (but still only 145lb!) Colorado front range, steep ups, fun downs major terrain changes. Medium HD frame, 50mm stem (20ish mm of stack), Vengeance 170mm (66.4d), Roco TST air (no less than 33% sag) ....
    Frame: These short link, mulit-link bikes do some strange things including VPP! The anti-squat thing is very noticeable on this frame and is not helping your situation, If you we're to be on a similar travel single pivot bike, you may not be experiencing this issue.
    Overall frame stiffness is not an issue, it's pretty damn good for a 6.5lb frame.
    Head angle: I agree with one poster, do not change HA for the sake of changing it, 67d is quite reasonable for the bike and what its intended use is. Using a slack angle only makes the bike climb with less ease and its general all round-ness of a frame.
    With the 565mm A/C on the Vengeance, its a tough climb, lots of body position comprise, but OK for a 6+" bike, use the lock out on the back for smooth climbs.
    But making the fork more compliant helps suck up small bumps in technical climbs.
    Having a 6+" bike that doesn't move some when pedaling is not a good bike to me, that means it won't move as well when it should move!
    Rear shock: This is part of the real culprit in your handling issues. The stock Fox, or any Fox shock is so over damped for this bike, in conjunction with the anti-squat, keeps the bike in a more upright position. Sag IS your friend on this bike, but that has its detriments as well. Most shocks (air) that do not have an externally adjustable IFP pressure chamber, run very high (400-500psi) in the IFP's. Because of this you will never be able to adjust the shock well enough to accommodate a good feel/compliant ride with appropriate sag. This bike needs a smaller air canister, low compression damping and an adjustable IFP chamber for bottom out control. IMO of course.
    As another poster mentioned, using the Marzocchi Roco TST air (this is what I use) and the X-Fusion Vector HLR with "DW tune". "DW tune" is the removal of a couple internal compression and rebound shims to lighten it all up. Both of these shocks and similar ones use high volume, low pressure IFP chambers, greatly increasing the sensitivity of the shock. Careful of fast rebound as well, this frame is sensitive to this control, slightly slower is better Go MARZ ROCO, all the way!!!
    Fork: Same darn situation, forks are over damped and under sprung making them unable to absorb small/mid bumps and making the fork deflect off bumps rather than sucking them up. This "stock" theory on damping is supposedly to make the fork track better...? Hmmm not in my book! I'd rather have the opposite with well controlled rebound. Air is easier to compress than oil thru shims and orifices...
    CTD forks start to work well with a little more fluid in the air chamber and WAY lighter oil. This way you can run them with more psi, less compression damping for less dive and better small/mid bump compliance... CTD forks are easier to work on then they appear!
    I think you are experiencing some fork downfalls that are exacerbating your "over the front" sketchy feelings! I know i went thru that learning curve!
    Set-up: This becomes personal preference, 50mm, 70mm, 80mm... stems are to fit the riders needs, size and terrain. I have to run a 50mm stem in order to fit my smaller 5'6" height and shorter arms...! I'd rather have a slightly longer stem to gain better front end control by having more weight on the front tire to drive rubber into the ground! But being vertically challenged and small frames are too small, so go the short stems!
    Technique: As another poster said "let go of the brakes" how true in many situations! But most of us are not pro DH'ers and the need to use brakes comes from self preservation and wanting to ride the next day! Ride techniques plays such an important roll in the handling of bikes. Lee McCormack's book, as shown above in one post, is awesome, teaching great techniques for even the most seasoned rider. Just dropping your ankles may help tremendously. It's the little things!
    The linkage bikes do provide us with pretty good do all frames, but they have there pitfalls, many of which can be overcome by one thing or another. But as written by the UK moto dude, he mostly states its all a bunch of hooey! Single pivots do the job, we just think we can do better, reinvent the wheel!!
    Anyway that's my .02. Good luck, just keep riding, that's the main thing!
  72. #72
    Mtb Guide
    Sep 2012
    Fork update 34ctd
    Got my spacers sorted out to counter the negative spring pictured.
    Used the blue spacer plus a smaller grey on so effectively too rubber spacers, the blue on its own was being squashed by the negative spring.
    Getting 148mm travel now 68 deg ha perfect 100 psi no extending now hopefully.
    Also added 20cc to the air chamber feels great progressive no diving or mid-stroke wallow bike is balanced with the front slightly stiffer than rear how I like my front and rear balance she feels super fast now.
    So see how it goes over next few days, I have no issue with the Fox chassis superb.
    Negative spring.
  73. #73
    Mtb Guide
    Sep 2012
    Well the new 34 ctd setup has been weighed, it has been measured, it has been tested, it has NOT been found wanting.
    Performance wise the above mods now have my bike riding as I like it.
    Now it just remains to be seen if the spacers can hold back the neg spring over time.
    The fork rides high, no more saggy sketchy downhills runs because I couldn't run the spring rate needed for my weight and riding style.
    HD now corners and holds the line naturally, no under or over steer, just rails. Jumps and lands as well as the rear, stable planted no unwanted instability and climbs like a demoniser so all round very happy camper.
    Pretty simple fix but seems ctd is still new and people unsure how to tackle it, just need have good lbs to help experiment and understand your riding style abilities.
    Simple I got what I wanted and it worked, just as it always has on any other fork Ive ever owned. Yay
    Ps my LBS did this for me at no charge as well, cheers team, thats service, even though I would have been happy to do so.
    Also adding a few cc to the air cartridge if you find the compression to weak, I would highly recommend especially if you suffer a bit of this threads problem after you have he basics sorted first, e.g proper setup. You will be pleasantly surprised by the performance gain and stability such a simple tune will do.
  74. #74
    So everything is installed on the HD. I will be testing it out at China Camp this weekend.
    I put a 70mm stem on.
    Got the five inch KS from price point( thanks fuenstock).
    Got the bike sagged.
    I am going to try out 3 clicks from full slow on the rear shock( zero pro pedal ).
    I am going to run the front at 4 clicks from full fast. With a Trail soft compression setting.
    Thanks to everyone for teaching me about my new ride.
  75. #75
    just make sure when you're coasting along and you stand off of seat, stay neutral, and bounce on the suspension, the front and rear rebound feels fairly the same. Okay to deviate a little front to rear based on riding style, but I've bounced some peoples bikes and the front fork will be super fast and the rear really slow. You don't want to be too far off from one another.
  76. #76
    EJC
    EJC is offline
