Results 1 to 9 of 9
    The Crow
    Reputation: Iwan's Avatar
    SL-R vs HD Head Angle - All things being equal
    So all things being equal what is the HD's head angle vs SL-R? Let's say 150mm fork standard headset with HD in full 160mm mode.
    There's a feeling I get
    When I look to the West
    And my spirit is crying for leaving
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    All the various HA configurations are on Ibis' website/manual
    The Crow
    Not all things being equal. HD quoted with 160 or 180 fork, HD140 with 150 and SL-R with 140.
    Dec 2005
    Each 20mm in increased axle to crown height equals approximately one degree slacker head angle. You can back into each angle using this rough math. Bear in mind, different forks have different crown heights so a 36 160mm fox is not a 10mm increase over a 32mm 150mm fox, it is greater. You can find axle to crown heights for all forks searching this forum.
    Iwan - 68.5 for the SL-R, 67.5 for the HD assuming a Fox 32 150 on the SL-R and Fox 36 @150 on the HD
    Geometry calc app geometryCalc
    -Shane
    Quote Originally Posted by Iwan View Post
    Any sufficiently advanced technology is indistinguishable from magic
    - Arthur C. Clarke
    Commit or eat sh!t
    Last time I checked the manual had HA by 10mm increments for all their models. Page 15 of the manual. Basically, every 10mm increase is about 0.5 degree, although HD 160 was about a degree.
    It also depends on the fork you are using, as axle-to-crown measurements are different for each manufacturer. So you will have to adjust for that too.
    The Crow
    Quote Originally Posted by seleniak View Post
    -Shane
    Thanks. (For the answer and understanding the question! )
    www.derbyrims.com
    Reputation: derby's Avatar
    -Shane
    To further equalize, using Shane's numbers....
    Using the same fork, pick the Fox 36 @150 on both the SL-R (140) and HD160:
    68 for the SL-R, 67.5 for the HD160
    And to further equalize with the same fork, and the same rear travel, the Fox 36 @150 on both the SL-R (140) and HD140:
    68 for the SL-R, 67 for the HD140
    The Crow
    Quote Originally Posted by derby View Post
    And to further equalize with the same fork, and the same rear travel, the Fox 36 @150 on both the SL-R (140) and HD160:
