Results 1 to 5 of 5
    Dec 2004
    Shock Ratio curve of a Mojo HD?
    Has anybody out there seen an accurate motion ration graph for the Mojo HD:
    shock movement versus vertical rear wheel movement?
    cheers
    [put something cool here]
    Oct 2011
    Here's something. Please be aware that this was created by competitor Yeti to advertise their SB66 and that it doesn't refer to the HD exactly, but to the DW link in general.
    Bottom of the page. Cut and paste into Goggle translations to get an english version:
    Linkage Design: Ibis
    -Shane
    Dec 2004
    thanks for the link, however there is no way even their Ripley data can be accurate. If they had guessed even one eccentic link angle incorrectly by just a few degrees their data would be useless. Not to mention the actual length of the eccenctricity.
    None of that data has been published, and photos would not be accurate enough given the short "link" length.
    Keen to find stuff on the Mojo HD !!
    Reputation: Vrock's Avatar
    Quote Originally Posted by robbieracer View Post
    Did you saw the Ripley video on Youtube??? If not, you should do it.
    Cad images (no distortion) and a good closeup of the "links". Linkage is never going to be 100% acurate and the Ripley is one of the most difficult frames to check, but the info in the video was pretty good.
    Attached Thumbnails Attached Thumbnails Shock Ratio curve of a Mojo HD?-ripley.jpg
