Results 1 to 5 of 5
    Apr 2013
    seat post shim....
    Hi Folks...My Crankbrothers hydraulic seat post died. Is it safe to use a 30.9 hydraulic seat post with a shim to 31.6 to fit my Ibis hd? The actual shim is 100mm and is much shorter than the length of the kronolog. Happy racing!
    You need to know the min insertion that Ibis recommends for that bike.
    Being using a shim on myHD since the day I bought it. 2011
    i use shim too, no problem at all.
    www.derbyrims.com
    Reputation: derby's Avatar
    100mm should be fine. 4" is commonly recommended for minimum seat post depth and post shims, 100mm is nearly 4".
    Posts slip down while riding easier when using a shim. Use a friction grease, such as FinishLine Fiber Grip. This will avoid the need to over tighten the seat collar.
  1. Replies: 68
    Last Post: 10-01-2013, 06:31 AM
  2. Use seat post shim good idea?????
    By gonzo in forum Frame Building
    Last Post: 04-28-2012, 12:20 PM
  3. shim for 31.4mm seatpost, to fit 31.6mm seat tube
    By chimpanzee00 in forum General Discussion
    Last Post: 02-15-2012, 07:53 PM
  4. Seat post shim
    By shift96 in forum Transition Bikes
    Last Post: 09-02-2011, 09:39 AM
  5. seat post shim
    By older and slower in forum Scott Sports
    Last Post: 06-01-2011, 10:10 PM
