Results 1 to 74 of 74
    YTC
    YTC is offline
    Upset Scared I bought the wrong size HD
    I'm 5'10.5" on my new HD Medium and I'm trying to remain calm. I've finally gotten comfortable enough to do some extreme riding on it and I'm just feeling like the cockpit is too compact. I'm running a 30mm spacer stack, settled on a 70mm stem and a 750 20 rise bar. Even with the dropper post, I feel like my bar is somewhere invisibly under my nose, out of sight somewhere. It's somewhere down by my knees it seems. I'm coming off an Ellsworth Epiphany so this my first AM bike so maybe it's just something I have to get used to. From my viewing experience, it seemed like more extreme bikes have the handlebars much higher/more in the picture. Please help as I'm freakin' out that I was mislead on this huge purchase. The guys at Ibis said it'll be better in tight single track, which it does seem fine, but when I start hucking it, I feel the suspension is saving me rather than I'm doing full control riding.
    Everyone's different..I'm 5'9" and ride a medium; probably fit a Large. I run a setback post and a 80mm stem on mine.
    Try this fit calculator and see what it recommends.
    Fit Calculator - Competitive Cyclist
    Weapon of Choice
    Reputation: Iceman69's Avatar
    Sounds too small for me, Im 5'11" and ride Large with 50mm stem. Fits like a glove.
    Super Unknown
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    I moved to a smaller HD and have the bars closer to me. I feel it hucks better and is way more nimble in trails. An AM bike is going to feel and fit different than an XC bike.
    When I asked Ibis about sizing a few years ago they said go with a Large, I thought I knew better and got an XL. I always felt it was too big. Years later I got a new frame and decided on an L and immediately knew it was the right size.
    6'1" on a large with 725mm bars and 70mm stem.
    I see the exact opposite. Low and wide bars are the norm. On my HD the bars are just a tiny bit lower than the seat. Extreme bikes may be pictured with the seat in a lowered state, making it look like the bars are high. Anyone riding with high bars is handicapping themselves, IMO.
    Reputation: hrdude's Avatar
    Feb 2006
    If you're over 5'9" you'll likely need a large. I'm 5'9.5" with a long torso and I fit an Ibis large much better than a medium.
    At 5'10.5" you would likely need a setback seatpost + a super long stem to get a proper fit. These days, I prefer a straight seatpost and short stems.
    Many of us went with the XL
    The ibis frames run on the small side, my XL is the same top tube size as my large giant.
    Glad you are happy on the large though.
    Quote Originally Posted by d-bug View Post
    If you're 5'10.5 on a medium, I'll bet your seat is way up there sky high as in xc sky high. Hence you get the feeling that the bar is underneath you. Me think medium is a tad too small for you. Small-ish bike is good for tricks and stunts, but I reckon that even HD owners will spend a majority of their time pedaling it.
    YTC
    YTC is offline
    Seat sky high but shoved forward
    1st off, thanks for all the posts!
    Three things:
    1. mystery: seat is sky high but shoved forward and I'm still sitting on the nose of it when hammerin to get my torsos more over the cranks. Why would that be? And how would I consider a set back post. can someone Explain this phenomenon given the frames a bit small?
    2. should I stick with the medium. Besides one reply, most said I should be on the large, but didn't go so far as to say switch. Should I bight the bullet and switch?
    3. Is it an AM thing that when climbing up a switch back I have to time my peddling to avoid hitting my up knee on the bar?
    Ytc
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    lol if you're hitting your knee on your bars you need a large.
    YTC
    YTC is offline
    Its only on switchbacks. My son who rides AM says he has to maneuver his knees when doing switchbacks.
    YTC
    YTC is offline
    Low back pain
    One more thing,
    I've noticed that my low back is urging after long technical descents standing out of the saddle with the seat down. This doesn't seem normal to me. Perhaps I'm hunched over too much on the medium.
    Ytc
    I'm the same height and went for a large HD although I had a med Mojo Classic.
    I run a 50mm stem on the HD and a 70 on the Classic.
    Lowering the rise of the bar or reducing the stack under the stem will make the bike feel longer, so I would try that first. I have long legs and a shortish torso, long arms so I have had to raise the stem to match a high seat. You may be the opposite. Theres very little dif in the length between a med and large prob equivalent to a change from a 70mm stem to a 90 or 50 to 70. Approx 20mm diff in tt length.
    Don't panic, you are on the cusp between the two sizes as I am
    Reputation: mazspeed's Avatar
    Quote Originally Posted by hrdude View Post
    No no no incorrect.
    There really is no correct answer when you are between sizes other than trying the bike out, but if you're 5'10 most people get the Med, but you should always test ride a frame/bike before buying. I have test rode a large recently and bounced around on a few at the factory and I am 5'10 with a 32 inseam and my buddies who have rode my Med all fit better on my Med than a large and these guys are 5'10 and 5'11. Ibis runs big for their sizing according to people at the factory. Try a longer stem on yours.
    Reputation: starship303's Avatar
    Quote Originally Posted by YTC View Post
    One more thing,
    Ytc
    Lower back pain is a sure sign your not positioned correctly (often caused from seat too high or bars too low). Either try raising your bars, lowering your seat, try a setback/offset seatpost, add another 10-20mm to your stem length, or (hate to say it) try a large HD.
    BTW I am 6' on a large HD140 with 150mm forks, 9mm of spacers up to a 70mm stem. I was running my bars fashionably low on my previous trail bike (medium Intense 5.5 EVP, with 70mm stem) when I first set it up and was suffering lower back pain after about an hour. Raising (and widening) the cockpit helped cure this, although the medium Intense was still a little short for me, but i at least was riding pain free!
    Last edited by starship303; 05-28-2012 at 04:28 AM. Reason: bit more clarification
    Lightly salted
    Reputation: fuenstock's Avatar
    1. mystery: seat is sky high but shoved forward and I'm still sitting on the nose of it when hammerin to get my torsos more over the cranks. Explain this phenomenon given the frames a bit small?
    Ytc
    You said this is your first all mountain bike. They usually have a slacker seat tube than lesser travel bikes. Thats why you feel farther behind the cranks. The HD seat tube angle is 71*, compare that to the seat tube angle of your last bike. The higher your seat the more it puts you behind the cranks, so if your seat is to high that will add to the effect.
    Lightly salted
    One more thing,
    Ytc
    Try decending low and loose, centered over the bike with a flat back and elbows out. If your stiff it can cause arm pump and sore back alot of times. Stay loose and let the bike bounce around under you.
    I'm inbetween sizes and always go for the smaller frame. Try lowering your stem stack from 30mm to 20mm or even better try 15mm. You can also rotate your bars a little forward. The lower stack will make the top tube feel slightly longer and rotating the bars forward will open up your chest and force you to ride with elbows out which gives better form and more control on the decents.
    aka dan51
    Mar 2005
    Quote Originally Posted by fuenstock View Post
    71* seat angle is pretty slack too.
    To add to what fuenstock says, changing frame sizes will NOT make any difference where your seat is. It will still be pushed all the way forward on a straight post.
    One of the reasons I wanted to go from XL to a L was because I had the seat pushed all the way forward, making me think it's too big. So I got a L and tried having the seat in a normal position, which killed the climbing ability for me, and caused lower back pain due to being bent over farther than I liked.
    If you go to a L frame, expect the seat to remain in the exact same place, assuming that's a comfortable position for you. Frame size will never dictate fore/aft position of the seat, unless the seat angle changes between frames.
    For my seat height, a change in seat angle of 2* translates into about 3/4" difference in fore/aft seat position.
    Over time riding position has changed for me. In 2004 I rode an Enduro with a 100m stem and setback post and thought it felt great. 6 months ago I built that frame back up for a friend and only felt comfortable with a 70mm stem and seat slid all the way forward on a straight post. Total cockpit length difference was about 2"! I was amazed at how much things have changed for me.
    I would spend a lot of time tweaking with bar height/width, and stem length before moving to a different sized frame.
    That said, I always felt the XL was a tad too big regardless of what I tried. So maybe your gut instinct is the right one, as was mine.
    Good luck figuring out your situation!
    Reputation: Yody's Avatar
    Another vote for.large. List your frame for sell, ride the Bike until it sells.
    You're in the size changing boundry. I'll suggest you not to go higher than 10mm stacking. The higher front end, the smaller the cockpit will feel... and assuming you're on a 160mm fork, you won't need to add anything.
    It's very simple:
    1. Lower the Stem Height, this will increase your reach.
    2. Longer Stem, this will increase your reach.
    3. Setback Post, this will increase your reach.
    4. Larger Frame, this will increase your reach.
    5. Or just ride your current setup and see if you get used to it.
    Quote Originally Posted by canuck_tacoma View Post
    It's very simple:
    succinct and remember there is only about 2/3 of an inch diff between med and large
    YTC
    YTC is offline
    Too sretched out
    When bar is lower, I feel to stretched out across the frame and catching air feels scarier. One of the reasons I went to an AM bike, is to feel comfortable hitting jumps, something I never had stretched out across my epiphany. Wouldn't lowering the bar defeat that purpose?
    Ytc
    Ytc
    If you ride a 100mm fork, yes... but riding a 160mm fork you should have enough room to use no stacking and even a flat bar... In this range, as you lower your shoulders you also lower your hips to keep your balance... then lower your complete center of gravity... then jump confident and turn faster.
    Ytc
    You have a lot of people telling you different things in here that I don't think is helping you much. Contact Hans at Ibis and let him know what you told us. He will set you straight. I personally would go with a longer stem, and not lower the bars at all. This will help you so much more then lower the stem. When I would mess about with both, lowering the stem made things worse on my hands and riding ability, lifting the stem and throwing it out was perfect for my riding style, and I think this will help you so much more. You have a short stem, toss in a 120mm and see how it feels. My guess is that it will solve all your issues.
    If you can, post a pic of the bike.
    Quote Originally Posted by mazspeed View Post
    You have a lot of people telling you different things in here that I don't think is helping you much. Contact Hans at Ibis and let him know what you told us. He will set you straight. I personally would go with a longer stem, and not lower the bars at all. .
    Pretty sure some of us have already told him to put a longer stem on
    2X
    Lightly salted
    Sounds like your just not used to all mountain geometry. You say its to small, but then say you feel to stretched out if you lower the stem stack height. So your able to feel the bike is to small , but also to streched out all on the same size frame? You should really spend some time and play with the setup of the bike before you jump the gun and sell it for a diffrent size.
    There is a lot of good advice on here, but realize fitting is highly individual and is affected by a bunch of stuff.
    Body type
    Riding style
    Flexibility
    Experience
    and on and on...
    You can change everything around and get the contact points in exactly the same place on both sizes and the difference you can actually feel between sizes will be the angle between your center of gravity and the front tire contact patch (where it touches the ground). The shorter medium will put you a little closer than the large. These days with a dropper post, you can even change that angle hugely on steep sections when you drop the seat. You are probably able to ride both / either size but let us know if you end up needing to change size and we'll try to facilitate with minimal if any expense. Let the experimentation begin!
    H
    Quote Originally Posted by Bati View Post
    I tried to use a wide flat bar on my HD to keep the front low, however with my 45mm no rise stem the brake levers would hit the top tube. So a bought a 20mm riser bar and still had to use 10mm of spacers so I don't damage the top tube in a crash.
    Quote Originally Posted by d3toid View Post
    I tried to use a wide flat bar on my HD to keep the front lower with my 45mm no rise stem the brake levers would hit the top tube. So a bought a 20mm riser bar and still had to use 10mm of spacers so I don't damage the top tube in a crash.
    My brakes hit my toptube. Put some clear prtotective tape where they.hit and run the pinch bolt on the brakes just a hair loose, so if you crash they rotate on the bar.
    Yep, saw that.
    120mm Boner Stem? LMAO save that for the road bikes, or unless you're 6'6" and you ride fireroads. What a perfectly good way to ruin a Mojo HD.
    I'm not necessarily one of these newer trendy cats, that just has to have a short stem, but that is a ridiculous bandaid for having a frame the wrong size. Especially since the OP is talking about hitting jumps and riding aggressively.
    100m stem should be max anyone is considering putting on a bike as capable as the HD, with 70mm being pretty ideal. Unless they just are riding XC and wanted a HD instead of a more suitable bike for whatever reason, theres always exceptions to the rule.
    Picture of the bike would be good
    Quote Originally Posted by Yody View Post
    Explain how a 120mm kills an HD? I ride very aggressively and run a 120mm. Please explain how I am worse on the HD.
    All the arguments aside, I would just like to comment on Hans's response.
    Wow, your are amazing. If more people ran a business like you do, consumers would be in such a better place.
    I can only imagine what kind of employer you are and how happy and loyal your employees must be to you.
    Well done and looking forward to placing my order for an Ibis in the next few months.
    Eric
    Well Biked
    Reputation: scepticshock's Avatar
    Jun 2005
    A stem should dial in the weight distribution and handling of a bike, in the same way as the for and aft of the seat should dial in knee /pedal alignment. Moving these too much to try to size a bike up or down is not a good idea. To me, just 1 cm in stem length greatly alters the feel of the bike. I cant imagine stacking on stem length to fix the fit unless I also liked the slower steering. I would only make small adjustments.
    Weight distrubtion and steering response. Hey everyone likes something different amd rides differently. Im not gonna tell you youre wrong but if YOU cant tell me the difference than you shouldnt be making recommendations on fit and stem length. Nothing personal.
    Yes there is a difference, all depends on the rider size and preference. See Hans response, should tell you something right there. I think the right thing to do is experiment with the bike first and not "ride till you sell".
    Contact Hans is the best you can do.
    IMO you're between sizes so you can get used to your current setup with small modification like mazspeed say.
    Good Luck!
    YTC
    YTC is offline
    How do I post pic from my iPhone.
    Not sure, you should be able to upload to a picture hosting site like photobucket or something like that. They have mobile ways to do uploading.
    Reputation: Trackho's Avatar
    I had the same question. Im 6" inseam is 34", arms are 36"--so Im pretty long armed, theres a name for a wingspan thats greater than your height (besides gorilla).
    Anyway Ive been riding a Large SL for the past year, generally it feels cramped with a straight seatpost 725mm bars and a 100mm stem. BUT-I got a specialized command post backlight dropper which has a 20mm rear off set. My knees now line up better with the middle of peddles and theres more room--I have a 70mm stem Ill play with, but Im guessing 80mm will be the answer.
    So theres another datapoint
    YTC
    YTC is offline
    Hey Hans,
    That reply was really awesome! Sometimes, as a busy man with a lot of responsibility, people don't get how the fit of my bike is really of great importance to me, so your support really makes a difference.
    HavIng my tire patch that close to me has been a bit freaky on the heavy stuff; my forehead, btw, is right over the stem cap/stem. Also, having so much forward weight, pulling my fork up on hairy jumps requires too much rider accuracy/input so now I'm just wimping out as I did on my epiphany. Is there really a 30mm spacer rule, or can I bump up my bar til it's comfortable? I've been trying an 8mm stem but have found it to be too long both for stretched out too forward reasons and i want more direct steering input, so I'm going back to 70 which felt right. I splurged for the 750mm carbon havoc bar which claims a 20 rise, but it may be too low. Is it better to stick with it and raze the spacer stack or maintain the 30mm spacers and get a higher rise bar? I know it was a lot of questions but I promise to be a good desciple if you stick with me. I'm a 44 year old husband with 8 kids who loves to rip but I can't afford to risk a bad fall; at least if was equipment related!
    Thanks again,
    Ytc
    I just got back into mountain biking. And I should have test rode a Large and XL. I purchased a Large SL. Bike shop had me on a 100mm stem. During steep climbs, find the front end lifts too easily. Then tried a 90mm, a bit less lift of front end. Now on a 80mm. But I'm sitting more upright. Seems Like the cockpit is cramp. During the 3 stem swap i had 3 of the skinny spacers below the stem. I tried reversing the stock Ibis 90mm stem. But it puts too much pressure on my wrist. And it made the steering real quick and twitchy. And on long rides, my back ache. The handle bar is ibis HD bar
    Its not an HD. Wish it was. didn't mean to hi jack your thread.
    YTC
    YTC is offline
    Is there anybody out there?
    I really wanna play with adding more spacers if I don't need to honor the 30mm principal.
    Ytc
    Mar 2005
    30mm principal isn't some law. Tall people run tons of spacers all the time. As long as you have the proper preload in the headset and the stem properly clamped, the steerer tube and headtube can take the stress. If it can't, I sure wouldn't trust this bike riding like Lopes does. The huge numbers of spacers is strictly an issue when your friends make fun of you. If you can deal with that...go for it
    My question is what fork are you running? After riding a 170mm RS, I would not go shorter on this bike. I think a 180mm fork would actually feel really good on this bike cause the BB stays high in it's travel when pedaling.
    I'm the same size as you and feel a Med is a hair small, but a large is a hair big. I run the seat back from center, probably 20mm, and a 70mm stem with 10mm spacer and 720mm bars and don't hit my knees unless I'm doing something wrong. Wider bars you will hit more often with your knees in tight climbing switchbacks, but many people shift their weight too far forward during climbs just because they are exaggerating their body position more than they need to. Do you have freakishly long femurs and short arms?
    BTW - Hans is an awesome company owner to get on here and respond as he has
    Well Biked
    Jun 2005
    Yeah, don't worry about spacers. Its mostly a looks thing. I run 20mm, and sometimes a tad more.
    I found the 180 Talas fixed that low front end feeling for me. I like the bike much more with it. Even more then the 170 Lyrik. I am probably between a large and XL, because I have long legs, but stand 6' tall. I still need to run a lot of post.
    Also with the 180 lowered I still don't clip rocks much when climbing.
    Fox warns against using more than 30mm of spacers.
    Ytc
    The picture is terrible, but from the looks the nose of the seat is pointed too far down.
    YTC
    YTC is offline
    Do u know where that warning can be found? I'd like to see it.
    YTC
    YTC is offline
    My body's pretty in proportion and the 70mm feels great. Just dealing with the spacer stack now which is maxed out (according to popular opinion) at 30mm and I would love to be able to raise it a bit feel a bit more upright which seems to lesson the margin of error when pulling up to launch or huck. Also, I wanna minimize my bar length to the ultimate width for stability in hard core situations and to stop slamming my pinky into trees. Now it's down to 740 from 750. Should I keep going?
    Dropshot Champ!
    so when are you getting the large?
    lol
    YTC
    YTC is offline
    Hey! Trying to give the medium a chance as Hans and others suggested. Do you think I'm blowing it? I ride in Israel where things are very tight and stupid technical/hairball. The compact medium does suit its purpose. Just trying to get comfortable with my bars so low and the front tire patch so tight.
    These forums are fun. Wish everyone would keep chiming in. It's like reading a MTB mag only it's alive and on the bike and subjects you need covered. What happened to everyone who graciously spoke up including Hans? You guys rock! I guess threads get old. I have to learn this thread culture.
    Ytc
    Hi Mate
    just re-looked through your posts and I have a couple of cheap suggestions.
    Rather than running 30mm spaces under the stem- risky and looks crap frankly, try running a set of bars with a bigger rise. There is a fashion to going low rise or flat but its personal.
    Secondly if you find that lower feels like too much reach, then try a 50mm stem.
    Thirdly make sure your saddle is in the correct position and when you sit on it the middle (or is it front) of your knee drops through the axle of you pedal. Pedals and cranks should be horizontal to the ground.
    I am the same height as you as stated previously and have long legs and short torso. I rode a med Classic mojo for 3 years with 50/70mm stem. Could have done with an offset post but wasn't going to spend that much on a new dropper.
    My opinion, for us mere mortals, is that it can often take a season (or longer) to get a bike really dialled. And ironically we are often moving them on and getting something newer and shiny and never realising the full potential of our existing rig.
    Many bike shops help with fit. Most apply road bike rules which is pretty dumb but some really know their stuff about mountainbikes.
    Lastly, on any given weekend, I bump into loads of riders that have their forks far too soft, that may be contributing to the feeling you have on the trail. Rough rule of thumb fork are maybe 20/25% sag compared to rear 30/35. Makes sense as your weight naturally pushes forward as the terrain steepens on descents.
    Recap
    less spacers, shorter stem, saddle position and handle bar rise. All that could take you a dozen rides to work through
    Have fun
    Quote Originally Posted by nzl62 View Post
    Hi Mate
    Recap
    Have fun
    Great advice. I think a med is going to be fine, you just have to play with it a bit and find the parts that work for you.
    Jan 2011
    I found a stem calculator really helpful!
    Stem Comparison Tool | yojimg.net
    YTC
    YTC is offline
    Didn't understand how to use it not what's its intended goal is.
    Jan 2011
    If you input the Ibis angle, I.E 67 degrees, then input your current stem length/rise, this will appear as red.
    Then, with research on current stem options of length and rise, input into the blue data, you should be able to get an idea what could be the best option for you!
    In my case on my previous bike, i wanted the same height stem but much closer reach to lessen back ache and get weight over the rear more easily. Using the calculator I could work out that my then 80mm stem with x degree rise was equivalent to an exact height using a Hope 50mm stem with 25 degree rise.
    Does that help at all??
    May 2010
    i'm 6' and ride the large and it is just a smidge larger than what I am used to. I had a medium enduro prior to the hd and that felt a smidge too small.
    YTC
    YTC is offline
    Great news!
    Something unprecedented. Here in the Holy Land of Israel, they pulled-off getting me a large HD to demo. It'll be ready on the 18th. In the meantime, I'll do e erything I can to make the medium work for me. Ytc
    Feb 2007
    A reputable bike shop should (a) include a bike fit by a qualified bike fitter for that kind of dough, and (b) stand behind what they sold you (ie, if they sold you the wrong size, they should swap you to the correct size, unless you insisted on the wrong size in which case they should have told you they think it's the wrong size).
    That being said, everyone is different. Different body dimensions, different riding styles. You can't go solely on height when it comes to sizing...which is why the bike fit is so important.
    I'm 5'10" with 32" inseam. Called Ibis. They recommended a Large for me.
    YTC
    YTC is offline
    Crazy at 5'10.5" they put me on a medium although I have a 30" inseam.
    Ytc
    Ytc
    Yeah Hans told me at 5'10 with a 32 inseam a Med is correct for me, and it is.
  67. #67
    Are you running a setback seatpost, is your seat centered on the rails
  68. #68
    No, why would I? Yes the seat is centered.
  69. #69
    Reputation: philstone's Avatar
    Mar 2011
    I was getting worried I'd ordered the wrong size - I'm just under 6' and 32" inside leg, but having ridden it over the weekend the medium is perfect to me.. Its only slightly shorter than my On-One Carbon456 I came from and feels much better... (Running a standard Special Blend at the moment..)
  70. #70
    meh
    Reputation: clewttu's Avatar
    5'11" and 32" inseam on a large with a 70mm stem, have ridden a medium and def wasnt the right fit for me without a setback or too long of a stem...everyone likes something different
  71. #71
    Jan 2011
    Just over 6'0 here with 35 inseam. Large was touch cramped on rare occasions with 70mm stem. Seat post was ridiculously high!!
    Got an XL with 50mm stem and it's perfect. Big bike though and not as nimble in tight switch backs as I hoped it would be. Always a compromise I guess!
  72. #72
    6'4" on an XL HD 140... it feels a lot bigger than my Stumpy FSR in L, but I think it is the right size for me. I just need to adjust some things.
    When I bought the Stumpy FSR, I subscribed to the 'smaller bikes are more nimble' school of thought, and that is true... but eventually I realized I was compromising with a cramped cockpit. Riding an XL Giant Reign out west for a week convinced me my next bike should be an XL.
  73. #73
    - Sounds like you are a L. 6n6 bikes can be tricky to size and often the general guidlines will size small (has to do with shortening of effective TT to "net" TT because of combination of long inseam and slack set tubes.)
    - I have direct experience fitting myself and others on the HD and happy to help you if you pm and then call me (faster than typing). Basically fit needs to be done on the bike (in a fit stand or friend holding it) in this order:
    set seat height, rear and front sag, seat for aft for knee/spindle offset, choose bar width, stem and stack for back/arm angle (near 90) and seat/bar drop. This will show the trade off for stem length vs frame effective TT and determine your centroid of mass and centroid relative to the tire contact points. Your style and preferences for climbing, descending and jumping (as well as use of adjustable seatpost and travel adjust fork) will also affect where you want your centroid to be.
    - As a data point SC, IBIS, LBS and the CC fit calculator (not too bad but doesn't calculate specific to seat tube angle) all sized me as L but my sizing method said XL. I went and tested a L and XL Nomad (same trail trading off two bikes with a friend, reriding climbs and descents) and confirmed XL for me. When I picked up my XL HD from LBS we did a fit in the stand and the LBS owner agreed I am an XL. I am 6'0", 34.5"ish inseam, 6'2.5"ish wingspan and ride a 2011 XL HD 160 c/w Talas 160 (since I have switched to Talas 180), 1.5cm knee to spindle offset, 90ish deg back to arm angle, 2 cm ish seat to bar drop with reverb on max high for climbing, 60 x 0 stem, approx 40mm stack, haven carbon low rise bar
  74. #74
    08 Master DH World champ'
    Reputation: ED young master's Avatar
    This old one looks dead ...
    However YTC, I hope you've finally got a Large frame ? Seems like an evidence to me, mainly if you consider this article about the Forward geometry !!! Mondraker Introduces Forward Geometry: Are You Ready for a 10 mm Stem? - Bike Rumor
    Don't let your fears stand in the way of your dreams ...
    05 DH French champ'
    08 DH World champ'
    10 DH Euro champ'
