Results 1 to 9 of 9
Thread: Saris Bones RS?
    Saris Bones RS?
    Anyone use one of these for a Mojo? Without a frame adapter?
    meh
    Reputation: clewttu's Avatar
    still gonna need a frame adapter
    Sucks. This may push me toward a hitch system.
    Reputation: Kaba Klaus's Avatar
    I got a Saris as a spare. Don't buy one.Loading and unloading bikes is a real pain. You have to maneouver the bikes over and around the straps. Unless the bike is a simple hard tail with round tubes it will snatch to something somewhere on the Saris.
    If you can, go for the hitch system. It works way better. (Yep, I got a Thule hitch system, too and hence can compare.)
    "Lorem ipsum dolor sit amet, consectetuer adipiscing elit." - And I agree.
    I use the three legged Saris Bones to carry my Mojo SL without a frame adaptor but it is a bit of a pain. What you have to do is slide the bike on in an almost vertical position (nose down) for the frame to clear the notches/straps near the seatpost and then rotate it back to horizontal onto the front notch and then strap it down.
    So it may work with your rack. Hope that the above info helps.
    Dec 2009
    Does this mean my incoming Mojo won't go on my Saris Bones 3 rack?
    meh
    it will with an adapter
    Dec 2009
    Can someone give me a link to the adaptor?
    Think it might be time to go roof rack mount
    meh
