Results 1 to 9 of 9
    Oct 2011
    Saint RD with 11-36 and 32t
    I switched from an XTR to Saint rear derailleur on my large HD after hearing it will work with a 36t rear cassette. I'm running a 32t ring in the front (1x10) and when it's on the stand, it shifts perfectly, but when I sit on it and the suspension sags, the pulleys hit the 36t cog. Anyone else have this problem?
    Patrick
    Reputation: philstone's Avatar
    Mar 2011
    You should be able to adjust the deraileur angle. I have the same setup with no issues
    #bleedblackdieevil
    its your b sccrew you need to adjust, it pushes D away from cassette
    also, the new saint needs to be adjusted to ake a 36 cassette, theres a link or something that needs to be added. I got the FR Zee to save th hassle as I was never going to run 11-28 on mu HD
    Oct 2011
    I put the extra piece when I installed it and played around with b-angle. Even with it all the way in it rubs.
    weird, I have the 36 tooth zee rear mech and it works a treat. I run a 22/32 front but I am going to try a 26 front with the 22 because I have one to see what happens. Maybe an idea to post a couple of piccs
    Off the back...
    Reputation: pinkrobe's Avatar
    I have the Zee FR with 32T ring and 11-36. Had to adjust the b-screw, but works well. So quiet !
    @pinkrobeyyc
    #pinkrobeyyc
    Does the new saint with a fr mode converter works with the direct mount hanger?
    Oct 2011
    The zee is made to work with a 36t, the Saint is not but a lot of people do anyways.
    I figured out the problem and had to add a link to the chain and its fine now.
  1. Will new Saint levers work with first gen Saint Calipers?
    By jayjudy13 in forum Downhill - Freeride
    Last Post: 02-14-2013, 05:14 PM
  2. Replies: 0
    Last Post: 07-20-2012, 01:04 PM
  3. Saint it is.....
    By Drth Vadr in forum Downhill - Freeride
    Last Post: 04-24-2012, 08:50 PM
  4. Saint or XTR RD?
    By kjsayers in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-10-2012, 02:16 AM
  5. old saint (m800) lines on new saint (m810) calipers?
    By Evan55 in forum Downhill - Freeride
    Last Post: 08-04-2011, 08:50 AM
