Results 1 to 12 of 12
    Rotor upgrade for HD
    I have a stock X9 HD with 160/180 Rotors and Formula RC brakes. Stopping power is not so good. Thinking that bigger rotors might be the cheapest fix. From my understanding, I can move the 180 rotors and its adaptor back and then all I need to do is buy a 205 rotors and the corresponding adaptor for the front. Sound right?
    If anyone happens to have product numbers for the things I need, that would be great. Otherwise, I'm sure I can take the extra five minutes to figure it out myself....
    HJH
    HJH is offline
    Yes, you can move rotor and adaptor from fromt to rear. Then buy proper rotor and adaptor to front.
    I don't think this will solve the problem. I'm running with 180/160 mm rotors and I have plenty of braking power. Might say too much. Maybe you should check pads first if they are not OK...
    check your pads, I have The Ones 180/180 and the power is very good. Occaisionally not and it tends to be glazed pads.
    I didn't like the stock formula brakes at all.
    Went with the Shimano XT785 and Icetech rotors, I'm way happier.
    Cumbria, England.
    Reputation: D45yth's Avatar
    Jan 2009
    OP - If they've got the original organic pads, change them to sintered...I was much happier with my R1's when I did this.
    - The seasons blow away, but the love is just the same -
    www.derbyrims.com
    Reputation: derby's Avatar
    Bigger rotors will add power and reduce or eliminate fade from heat, but they are heavier.
    As suggested, if not using "sintered" type semi-metalic pads, try that first. Clean your rotors with rubbing alcohol before swapping pad material, or brands, give them a few rides to break in if noisy. Organic pads are usually quieter.
    Your Formula calipers are plenty.
    And yes, the fork post-mount adapter for a larger rotor from the fork can be used for the same rotor size in the rear.
    I'm not too worried about heavier rotors. Sounds like they'll make me stronger. However, I will try cleaning my rotors and potentially changing pads, first. Thanks for the advice.
    I took a ride on my buddy's carbon nomad the other day and found his brakes to be AMAZING in comparison to mine. He has XTs. So i didn't mind mine until I knew what I was missing....
    Ride or Die!
    Reputation: CasinoKiD's Avatar
    Quote Originally Posted by circlesuponcircles View Post
    I switched from Magura Martas to the new XT's on my HD. The XT's are amazing brakes and the price is right too.
    They have been on sale a lot lately, picked mine up for $120 a wheel.
    Reputation: Murchman's Avatar
    The new XT are amazing
    Reputation: gunnirider's Avatar
    I did the rotor upgrade then switched back to the 180/160. So I have the necessary 200 rotor, adapter and rear adapter laying around if you'd like to buy them.
