Results 1 to 14 of 14
    Ripley pedal strikes
    Anyone having an issue with pedal strikes on the Ripley?
    I have had more of these with a few rides on the Ripley than I had with about 8-10 different bikes in 15+ years of mtn biking.
    Sep 2013
    Not at all. The only one I had, was pedalling over a small roller, but that was my dumb mistake because I had the pedal at 6 o'clock (when I should have had it level).
    I definitely got more pedal strikes on my old 92 Merlin.
    No problem with mine. Of course, I'm using a Pike 140mm fork so the bottom bracket is higher than it would be with a 120mm fork. I've had a couple of pedal strikes over the past 10 months, probably fewer than before. I think the DW link suspension keeps the bike higher in its travel, especially when climbing over rocky terrain. Also, I'm running about 30% sag, so that's pretty soft.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    I get them. Lower BB than my HD, so I just need to adjust for that and all will be well again.
    I'll happily take a few pedal strikes for the enhanced handling of the lower BB. Though I don't ride much in places where a higher BB is a benefit.
    Oct 2011
    I rode a med demo with 175mm crank arms and had a couple strikes then saw a lot of comments about the low bb height and pedal strikes. So I had mine built up with 170mm crank arms. My previous bike had 170s so I didn't think it would make a ride difference for me. My pedal strikes have been a non factor with the 170 arms. I did get some riding Gooseberry a couple weeks ago but no more then anyone else I was riding with. Only 5mm but I did it hoping to prevent the strikes. I know the bb is low and have been working my pedaling technique for it.
    Reputation: IntenseJim's Avatar
    Quote Originally Posted by cas-pa2 View Post
    Nope. Fewer than my last 29er.
    Yes with 120mm fork, more than my Tallboy with 100mm fork.
    I have a 120mm fork and haven't noticed any increase in pedal strikes!
    Quote Originally Posted by donkeyrider View Post
    donkeyrider, compared to what?
    The MTB Lab
    Reputation: pastajet's Avatar
    Yes, I get pedals strikes. The low slung Santa Cruz geometry, local rocky Colorado terrain and lot's of sag can cause issues. I even use a 140 fork and have big monster tires.
    Quote Originally Posted by rockinrod42 View Post
    Jet 9 RDO, Mojo SL, Cannondale Flash (26"). I'm running a small frame with 170mm XX1 cranks. Hope this helps. I've ridden my Ripley at the Breck Epic and Cape Epic without any problems.
    For most, pedal strikes are inevitable with the Ripley if you ride in rocky terrain or terrain with roots. I rarely got pedal strikes on my Mojo and only occasionally on my Jet 9 RDO. I get pedal strikes more often on the Ripley, though I am learning to time my pedaling and lean to avoid most.
    Make sure you don't leave your CTD Fox shock in the Downhill setting for all of your riding. I get a lot of pedal strikes if I have inadvertently done that. Once I flip it into "Trail" the problem goes away.
    Quote Originally Posted by Julie View Post
    Good to know. Thank you!
  1. Mukluk 3 & Pedal Strikes
    By jimithng23 in forum Fat bikes
    Last Post: 01-04-2014, 10:55 PM
  2. Pedal strikes and chainring/bashguard strikes = frame damage?
    By Varaxis in forum Bike and Frame discussion
    Last Post: 09-25-2013, 12:45 AM
  3. Pedal strikes! Wth is going on here!?
    By SoWal_MTBer in forum General Discussion
    Last Post: 05-11-2013, 05:30 PM
  4. tallboy LTc pedal strikes
    By goodmojo in forum Santa Cruz
    Last Post: 02-11-2013, 04:10 PM
  5. XTR Pedal Strikes To The Shin
    By Cusco in forum 29er Bikes
    Last Post: 01-05-2013, 05:39 PM
