Results 1 to 77 of 77
    Ripley paint damage: water bottle and cable routing
    I just want to point a couple of things out to Ripley owners and builders.
    First, just because a water bottle and cage fits into the upper mounts with room to spare does not mean it is suitable in that location. The suspension swing arm moves in the water bottle's direction. Have a look at the paint damage to my brand new Ripley after the first ride. This is from a plastic Lezyne mount and standard plastic bottle. The bottle was not in contact with the paint, but the swing arm bashing into it caused damage not only to the swing arm but somehow to the seat tube as well!
    Second, be sure that you, or your LBS, install the derailleur cables in a crossed pattern into the internal cable routes, with adequate slack. If they are too short and go into the onside route, then there will be enough friction on the cable stops to cause some ugly paint damage there as well.Ripley paint damage: water bottle and cable routing-cable-routing.jpgRipley paint damage: water bottle and cable routing-bottle-mount.jpg
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Not all bottle cages are created equal. I had an issue similar to your with a specialized stumpy years ago. I had to try a few cages until I found one with the mounting holes offset enough to not cause contact. Bummer about your scratches.
    Lightly salted
    Reputation: fuenstock's Avatar
    Are you using Lenz side mount cage? I just installed one on my Ripley but have not ridden it yet. Ill have to check fit by letting air out of shock and bottom it out to check clearance.
    Reputation: kiwisimon's Avatar
    Oh man that sucks. Thanks for the warnings and don't let a few scratches take away the fun of the ride. How did the bike perform?
    Reputation: simenf's Avatar
    Nov 2008
    Oh, s sorry to see that. Looks fixable with paint and polish. Get in touch with Ibis. THose bottlecages....
    Personally, don't like the internal routing on that bike. It doesn't add anything to it. Ibis, put the cables on the top tube.
    Quote Originally Posted by canuck_tacoma View Post
    You're absolutely right, the current internal route is dreadful and complicated, a true nightmare, I prefer thousand times on the top tube.
    Quote Originally Posted by Pat-G View Post
    I agree completely - the cable routing on the Ripley is a train wreck. Hard to believe such an important detail was so poorly executed in the design. I contacted Ibis regarding steer tube damage from the cables, and they're sending a igus bushing to protect the steer tube. Nice band aid. Is there really no thought being put into a more comprehensive solution???
    Nice bike, but for the $$ and the time spent waiting for this frame, I expected greater attention to detail.
    Going to wait for Rev. B on this one. Can't be too hard to change the mold. I don't see what internal routing gets you on this frame at all. The cables are still all over the place at the shock mount. It's hardly "clean."
    It's the axle
    Reputation: Gregg K's Avatar
    Another potential Ibis customer here waiting for external cable routing before purchasing.
    I also contacted them about just running on the top tube, and was not satisfied with their answer.
    edit- Problem Solvers would work for routing. But I don't want holes in my frame for h2o infiltration. I know, I know...water gets in anyways. Not on my Mojo. Dry as a bone.
    Note to self: 85% of FTP for 20 min.
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    everyone *****ed and moaned about external routing and begggged for internal on the last frames. I don't think they're gunna change it.
    aka dan51
    Mar 2005
    Quote Originally Posted by redmr2_man View Post
    Can't please everyone...
    Too slack.
    Too steep.
    Too heavy.
    Chainstays too long.
    Water bottle in inconvenient place.
    Water bottle scratching frame.
    Can't run big enough tires.
    Doesn't have internal cable routing.
    Has internal cable routing.
    Press in BB.
    Too much travel.
    Not enough travel.
    Not a real 650.
    Not enough color choices.
    Something is scratched.
    Takes too long to ship.
    Takes too long to develop.
    ...did I miss any?
    Nobody ever *****es about customer service though!
    Quote Originally Posted by d-bug View Post
    Too slack.
    Too steep.
    Too heavy.
    Press in BB.
    Too much travel.
    Not enough travel.
    Not a real 650.
    ...did I miss any?
    Oh I dunno...I could probably ***ch a bit about Ibis CS.
    Ibis stating in this forum that the Ripley can easily fit a Hans Dampf in the rear, then responding to my concern that the tire rubbed the seat stay with a statement that "we didn't expect anybody to run such a big heavy tire".
    I and my shop raised concern about the front shifter not playing well with the E-13 setup. Ibis told my shop they were doing it wrong, told them to make sure the shifter was set up for double (i.e. screw turned to "2") and then coming out a month later with a page showing everyone how they need to setup their shifter as a triple to get it to work right.
    Ibis saying they haven't had any issue with the cable routing causing interference with the steer tube, but following up a couple months later by sending a plastic bushing to protect the steer tube. But only if you ask for it.
    Shall I go on?
    It's a nice bike, but the attention to detail at this price point is appalling, and rather than be honest about the shortfalls and getting out in front of issues, Ibis plays defense.
    I love the fact that Ibis is a small company that gives everyone a lot of attention, but at some point, you can be too small, and the fact that it took so long to get the Ripley out, and it's still pretty buggy, is evidence that maybe Ibis is a little too small. I've wanted a Ripley since the first time I saw a picture of the Interbike proto. I've since bought two other bikes in the trail 29er category, because the Ripley wasn't available. Now that it's available, I still wouldn't buy a Ripley yet, even though I still want one.
    I'll admit that I might be more OCD than most, but things like cable routing and silent operation (and not having your bike knock paint off of itself) are a big deal when it comes to ownership experience. This is a top flight frame at a top flight price, and it is totally fair to have high expectations for it. There are companies out there getting these details right.
    screamer
    Reputation: budgie's Avatar
    Did anyone see the reports about chemical weapons attack in Damascus? Pretty horrifying. The UN & NATO powers have some really tough decisions ahead of them. All in all, the Arab Spring has taken a very nasty turn in the past month.
    On heavy rotation: White Lung: Deep Fantasy
    Quote Originally Posted by hillharman View Post
    I hope they revise it...really want to buy this bike.
    That cable setup is more than an eye sore, it actually interferes with performance, and the durability of the bike.
    Too Much Fun
    Reputation: benja55's Avatar
    Aug 2005
    Quote Originally Posted by budgie View Post
    That's definitely true, and its awful.
    That said, I'm not certain the Ripley cable routing can be directly blamed for it.
    - -benja- -
    The MTB Lab
    Reputation: pastajet's Avatar
    Been riding my Ripley for 2 months now. Superb bike, and an incredible climber, and I have been riding it everywhere, bike parks, technical terrain, ugly rock gardens, etc., and it does just fine, though occasionally tight switchbacks and tight maneuvers can be difficult, and on super gnarly terrain the 120/140 setup means you need to choose your lines more carefully. My poor HD has been relegated to the basement.
    Some findings:
    1) Maxxis Minion DHF 2.5 with carcass 2.35", knob width 2.55" - depending on the rim used, tire pressure and mud or wet debris being encountered, they can scrape the right side clevis. Currently running some WTB 2.3 Vigilante, a better fit but still tight by the clevis. On full on compression of the suspension (when I let the air out of the shock), right on the bottom out bumper, it barely buzzes the seattube, though I found it hard to replicate in real world conditions.
    2) Running a 3-speed front derailleur with 2-speed shifter on the E-13 2x10, and it is giving me fits to get it to run perfectly
    3) The internal routing was a pain to set up, and I'd prefer a normal top tube version, but it's working, when I pulled the fork out it had some subtle wear on the steerer, so I added some protection tape to keep the wear to a minimum, no wear for me on the insertion holes
    4) Running a King Ti water bottle cage, and no issues at all
    Quote Originally Posted by mgs4410 View Post
    Those are good tips and I'll add this info as well:
    Regarding fitting a cage to the top of the Ripley down tube; at the shop we're using Arundel cages
    ArundelBike - Sideloader & Other SideLoader Bottle Cage
    and there is no interference at full travel. Most cages use a bolt hole location and cage location close to that of the Arundle. We sell the Arundel side loader cages on our website and they are also in many bike shops. Side entry cages are recommended.
    Regarding the paint damage on the head tube casing holes, we have seen a couple of frames like that and it seems to be due to the prep before painting and there being some filler near the edge of the holes. The filler is not strong enough to resist the pressure along the edge and can get chipped. We've asked that they eliminate the use of filler in that area to avoid chipping.
    Please contact Ibis for help with replacing this frame or working out some compensation for the issue.
    The Ibis service contact info is in a sticky thread at the top of the page, or email warranty@ibiscycles.com.
    Hans
    Just to explain ourselves, we have run external cables forever but the shape of the TT s on the bikes are really nice and they do look better with internal routing. We were practically getting death threats if we didn't run them internal on our next bike. (not joking)
    It IS harder to set up at first, and we have done an illustrated guide and a video
    http://www.ibiscycles.com/downloads/..._05_Ripley.pdf
    Ripley 29 Cable Routing Tips & Tricks - YouTube
    that goes through how to set them up, but many of the bikes I see out in the world are not set up per the specs and are not working well. I understand the frustration.
    The routing can work very well. Here are the main points to check. The illustration in the first link shows this the best, so check that. Here it is written out as well:
    1. cross the cables in front of the head tube.
    2. There needs to be one zip tie that tightly clamps all the casings together just after they exit the top tube, just above the forward part of the shock.
    Some of the casings move with the suspension and some do not. This locks them together so they do not slide in and out of the top tube or gradually ratchet the casing one way or the other. Many bikes I've seen do not have this zip tie. We are working on getting the word out about this set up detail. We may even make a little cable bundle clamp and include them / provide at no charge to existing owners. It's key to proper functioning.
    3. the two casings that connect with the swingarm (rear brake and rear derailleur) need one zip tie about mid span between the clevis guide and tube tube exit. This keeps them moving straight up and down together, not allowing them to bow out sideways or get out of sync. Sometimes the routing works OK without it, but one tie placed there makes it work every time.
    4. If running a FD the casing should go inboard of the clevis and should get loosely zip tied to the RD clevis zip tie. This holds it clear of the clevis so it does not wear on the paint and carbon.
    Hope this helps you all get more enjoyment out of your Ripleys,
    Hans
    :thumbsup:
    Attached Thumbnails Attached Thumbnails Ripley paint damage: water bottle and cable routing-imag0002.jpg
    Ripley paint damage: water bottle and cable routing-imag0003.jpg
    Ripley paint damage: water bottle and cable routing-imag0004.jpg
    Ripley paint damage: water bottle and cable routing-imag0005.jpg
    Reputation: rollinrob's Avatar
    Quote Originally Posted by hanssc View Post
    Hans
    NOw thats good customer service. I wish I could afford a Ripley, it on my very short list of bikes to buy within the next year and seeing deeds like this make me want to pack my lunch everyday and pinch pennies so I can get one. WTG IBIS!!
    Quote Originally Posted by mtnwater View Post
    There is a permanent solution for the steerer shield in the works that will be shipping with all bikes and provided at no charge to all Ripley owners.
    We did not realize the potential for the casing to wear on the steerer until the Bike Radar test. (It's not consistent and some of our bikes here with hundreds of hours on them have minimal marks, barely scratching the ano, similar to where the headset contacts the steerer etc, but in some cases the casing can wear a groove into the steerer and that could weaken the steerer enough to be a problem eventually.)
    We have been testing various approaches to determine the best one and then getting tooling and parts made. We will have a nice little stainless steel shield that drops onto the steerer and protects it in case the casing rubs against it. The material is close to what our stainless chain suck plates are made of and should last a lifetime. We will put the part on the web store at no charge and put the word out to everyone officially in about 2-3 weeks.
    Hans
    Quote Originally Posted by pastajet View Post
    Hi Brian,
    Here's an explanation and set up tricks that should help.
    For those who are wondering why we did this..
    Optimal anti-squat and suspension performance on the Ripley occurs with around a 30 - 34t chainring.
    The fact that the 29" wheels cover more ground in one revolution effectively increases the gearing, so a 34 rides more like a 37t or so on a 26" bike. In other words you do not need as high of gears when running a 29" wheel, so we designed it to be optimized around a gear that's appropriate for the wheel size. The Ripley is one of the first 29rs that uses this approach.
    There are currently no 2x cranksets available from Shimano or Sram that have the optimal gearing for 29" and the 100% anti-squat on the Ripley in a useful gear. The triples work great however with a 32 middle ring being right in there. You just don't need the 42T chainring unless you often get going REALLY fast.
    E-13 made a great solution for this with a 2x crank with bash. It is actually a 3x crank arm, that is the 2x are in position 1 and 2 and the bash is in position 3.
    In order to match the shape of the crank and the throw of the FD and shifters, you need to run a 3x FD and sometimes 3x shifters.
    The FD needs to be clamped higher, related to the bash ring on the E-13 crank as if it were a normal chainring. Not adjusted lower close to the middle ring. (please see the PDF below)
    Not simple, but it works great. This is a case of the details being important and difficult to communicate to everyone.
    Once you ride the bike, most people are astonished at how well it accelerates and climbs, so we think it's worth the trouble. The bike component companies will catch up with this in the next year or two and the crank and FD selection with appropriate gearing will improve.
    We made this to explain. If you are setting up a bike, please check it out:
    http://www.ibiscycles.com/downloads/...n_Edit_2.1.pdf
    Hans
    Loving The Ripley
    Well I am a happy Ripley owner, I like the cable routing and didn't have too much trouble putting it together. I think it looks clean. I was helping a friend with a Trek road frame and it was much harder to deal with, I was fishing for the housings in the frame. The bike has been solid and I have been riding it like I stole it.
    Reputation: getbusyliving's Avatar
    Too slack.
    Too steep.
    Too heavy.
    Press in BB.
    Too much travel.
    Not enough travel.
    Not a real 650.
    ...did I miss any?
    Agreed...can't please everyone. Having a forum like this is very valuable for communicating issues and fixes. And smart companies like Ibis listen and make adjustments.
    But we all know that forums draw mostly negative issues, which can leave a very skewed impression compared to reality. For every few people having issues/complaints (some very justified, some less so), there are hundreds of us out there having too much fun to post anything---just quietly and blissfully shredding, and loving everything about our bikes.
    Quote Originally Posted by MTBMILES View Post
    I just put my Ripley together, too, and didn't have problems with the cable routing. It was really easy to thread the cables through as suggested in the Ibis guidelines. I did have trouble with the cable tie trick - I couldn't keep the cable ties separated by an inch and oriented in opposite directions when I put the cables back through that little hole inside the frame. But it all seems to have worked well. And it does look clean.
    Hans,
    Thanks for these tips. I need to check to make sure I have the zip ties correctly - especially zip tie for the FD. That's the only place I get any cable rubbing now - sounds like I can get rid of that! Cool!
    Quote Originally Posted by getbusyliving View Post
    I disagree.........there are a lot of threads and reviews in this forum that are very positive.
    Having a place to share an issue, vent, and collaboratively come up with a solution is not negative....It's constructive.
    Just to explain ourselves, we have run external cables forever but the shape of the TT s on the bikes are really nice and they do look better with internal routing. We were practically getting death threats if we didn't run them internal on our next bike. (not joking).......
    Hans
    Thanks for the detailed reply on why you chose the internal routing.
    I demoed a Ripley the other day for about 4 hours and rode it like I stole it. It blew me away. It was just that good. Except for one serious issue; there was a notchy feeling to the rear suspension when compressed. This was being caused by the cables. I went over it with the shop and they had installed the zip ties internally and had the internal cable tied to the external cable just above the shock. It was so notchy you could feel it in the bars. Do you know what was causing that?
    Ok folks. what i do like about ibis is if they do have a problem or issue they admit it and find a solution.
    As a customer there is nothing worse than a company that are in denial about problems.
    thanks for being open hanssc.
    I have no idea really, but a couple of thoughts:
    1. the leverage of the suspension is so high, you rarely feel anything is wrong even if one of the bearings is corroded or very rough. The forces are overwhelming for any of the resistance that is offered up by typical issues in the suspension. I don't offhand know how the cables would generate that sound unless they were getting caught on something and then breaking free suddenly, but that would be easy to see and correct I think.
    2. Myself and others have had a similar observation and chased it to the clutch on the rear derailleur. It is strong enough and lets go suddenly enough in some cases to be felt and heard through the entire bike. This is more likely with SRAM 11 speed stuff.
    3. In order to chase such a thing down, I usually let most of the air out of the rear shock and slowly compress the suspension, carefully watching and listening for the culprit. It should become apparent what it is. Hopefully it will be easy to see.
    Hans
    If you are running Sram this is a known issue with their RD's.
    Hans
    It was the Shop's Bike so I didn't do a full look...just a quick look. It seemed like the cable going into the top tube was catching as it was being pushed in upon compression. This was about an inch or so in. Felt like it was catching on something inside the top tube.
    You were saying the cable shouldn't push in to the frame? As it was to be tightly ziptied to the external cable? If I remember the external cable was the rear brake and the internal was the rear derailleur.
    It was an XX1 setup.
    MSH
    MSH is offline
    Reputation: MSH's Avatar
    Jun 2005
    2. There needs to be one zip tie that tightly clamps all the casings together just after they exit the top tube, just above the forward part of the shock......
    This made a huge difference for me. Couldn't figure out what the slapping noise was on rough descents. I thought it may have been the KS Lev cable hitting the frame but that wasn't it. Went back over the cable routing instructions last week and added the ziptie. Problem solved! I ended up adding the second ziptie that Hans recommends closer to the seat tube for the brake line and rear drl housing this morning before my ride.
    This is my first go at an Ibis and I couldn't be more happy. The excellent customer service and the fact that they stay very active on this board answering questions/helping folks work through issues/etc reminds me of Turner. These are the types of companies I like to support and tend to stay loyal to.
    Quote Originally Posted by MSH View Post
    This made a huge difference for me. Couldn't figure out what the slapping noise was on rough descents. I thought it may have been the KS Lev cable hitting the frame but that wasn't it. Went back over the cable routing instructions last week and added the ziptie. .
    I think this was the problem with the Ripley I rode, the cable was being forced back into the toptube when the shock compressed. This caused a notchy feeling that was quite noticeable.
    Just curious where does the slack go when the shock compresses? Do the cables just bend/arc away from the shock towards the toptube?
    The RD clutch mechanism was most likely the source.
    H
    Reputation: CactusJackSlade's Avatar
    I am constantly amazed at the PERSONAL responses given from Hans.... how many other companies take the time to be current and timely on forums like this. THIS is also a part of customer service.
    This is one of the reasons I will always keep coming back to Ibis.... and of course for their great bikes. One month on the Ripley now and loving it!
    Thank you Han's/Ibis :-)
    Largest NorCal XC Race Series
    http://www.bicyclingevents.com
    http://www.UavTechReview.com
    Best in the West!
    Good job!
    H
    Ok... We were so sure it was the cables, but the RD does make sense. I will pass it on next time I'm in the shop...Thanks.
    I never noticed the XX1 RD clutch release point on my hardtail, but the Ripley is so smooth over rough that I can now feel it releasing.
    Not a bad thing, just interesting.
    A couple potential solutions
    First, on the cable routing, I haven't had any paint issues - and I've ridden the bike a fair amount - but I did cable it slightly differently that most people do. I ran the rear der housing outside the frame to follow the rear brake line...it just cleans things up a bit (although, with two der's / two brakes / dropper post it's a bit chaotic...love the simplicity of the cabling on my ss / no dropper and the DJ bikes my kids ride).
    I also use these little connectors (avid sends them with their brakesets...ask you local shop)...they have a clamp for two cables and a little swivel mechanism...they seem to keep the lines from bouncing around.
    Lastly, I moved the LEV adjuster to the back by the shock.
    Pics attached for reference.
    On the bottle cage, I'm using a Lezyne side loader with no interference on my med frame.
    Attached Thumbnails Attached Thumbnails Ripley paint damage: water bottle and cable routing-ripley-lev-adjuster.jpg
    Ripley paint damage: water bottle and cable routing-ripley-cable-routing.jpg
    Quote Originally Posted by riderup View Post
    Looks pretty good...wonder if some black spiral wrap around the bundle over the shock would look good? May be more trouble than its worth.
    How are you liking the 29r Weirwolfs? Loving mine on the HD.
    thought about that...it's not too unpleasant to look at as it is...and since the barrel adjuster is there I'd want to keep it accessible. (I also used regular black shimano SIS housing for the LEV instead of their weird carbon weave-look stuff just to keep all the cabling consistent)
    I like the Weirwolfs...there's a tad of rub on the rear clevis but not bad. good, consistent, tire in what I've ridden them in so far...running as low as 20psi in them but usually am up around 24psi (I'm 180ish lbs)
    I don't know about that, look at the cable routing issue Niner had and the cracking frames.
    OG Ripley v2
    Carver 420 TI
    Hans,
    I've looked at this but can't quite envision how the cable tie is supposed to work. Do you have a picture of the correct set up?
    Reputation: manchvegas's Avatar
    Mar 2011
    I've had my ripley built up for a couple months few things I've noticed as well...
    1- water bottle cage works, but you have to use a small bottle an move it up as far as the mounting holes allow. I compressed my suspension before riding it with the bottle in, an could see right away it hit.
    2- my LBS did the cable routing correct an it still sucked in the top tube to the point I turned my bars too hard at one point an the cable sucked in so much while I was riding that it kinked my housing. I've since put a ziptie as it enters the top tube an no more problem
    3- haven't taked apart to see any damage on the steer tube. But as soon as ibis releases the bushing I will use it.
    4- no front der. issues as I'm running 1x10 with wolftooth chainring.. coupled with a xtr shadow plus, not one dropped chain, ever, over some serious descents etc..
    Over all the bike is great an climbs like no other.. My HD has been sitting as well..
    Full time rider part time racer...
    See my adventures here..
    https://www.instagram.com/projectnortheast/
    Quote Originally Posted by agoura_biker View Post
    Hans,
    Went to take a photo of my cable routing for you and had to laugh when I realized that I don't have a FD. Forgot about that.. Photo coming. Later.
    H
    H
    Ha! Thanks for the thought! I look forward to seeing it later.
    Hans,
    You had to show a white one....
    Nov 2008
    Hans,
    You are gonna drive everybody nuts now...
    Quote Originally Posted by simenf View Post
    Hans,
    Sorry 'bout that ; ) It's just the first frame made of it's size and is in white primer.
    H
    Excellent! Thanks for the photo, it helps a lot.
    Nor­wegr
    Reputation: Vegard's Avatar
    Ripley paint damage: water bottle and cable routing-p8290048-001.jpg
    Something like that looks like a better solution for the routing than the currenty way of doing it on the Ripley. Considering all the engineering that went into the Ripley I'm surprised they didn't adress it.
    That being said I'm still interested in one.
    Nov 2008
    I agree with the BMC-solution. Avoids the narrow angles and interference with the steerer tube, gives more options for routing and room for more cables. If it can be executed well on a Ripley I don't know.
    simenf - brainwashed by the big wheel mafia.
    Liking that too....the Cables entering the headtube make me think of a mazda Miata front end. Kind of face like.
    It's the axle
    If I were on the design team I would shy away from the BMC approach. It's not as elegant. It's a more costly design with several extra parts in inventory, as well as assembly. I'm making the assumption that the Ripley design works without that added stainless collar.
    Design is always a give and take game. Internal routing eliminates inserting cable attachment points. I still think Ibis could have done this differently.
    I just don't like holes in my frames.
    Having said that, I still totally love the Ripley. My previous comments have all been out of love.
    Also- how much of the cable routing is actually internal? About 12 inches. It hardly makes sense, to me at least. And I do like the whole concept of tucking the cables away.
    Too Much Fun
    Aug 2005
    Quote Originally Posted by Gregg K View Post
    Yeah, that's kind of how I feel; internal routing is not something that I've been missing all my life. I've had external routing on the HD pretty damn dialed for my needs, with dropper etc, and I just don't ever thing "Yeah, this bike would be better with internal cable routing..."
    - -benja- -
    Better?
    Ripley paint damage: water bottle and cable routing-giant-2013-xtc-cable-routing-3.jpg
    vs.
    Dec 2011
    yes, much better!
    Hans,
    I have the notchy noise on my Ripley - it makes the bike vibrate all the way to the handlebars. We chased it to the RD (xx1). Any idea about how can I fix it?
    Please see:
    https://www.dropbox.com/s/wsxsa9fe8a...2015.03.09.mov
    https://www.dropbox.com/s/l88oi0d9q4...2015.02.14.mov
    Thank you,
    Feb 2013
    This has been discussed in another post on this forum. It seems that some of the xx1 rear derailleurs don't have enough lube in the clutch mechanism. Leq posted a link to the bicycling Australia article on how to rectify this.
    SRAM Type 2 Overhaul | Bicycling Australia
    Quote Originally Posted by tlechnow View Post
    Thanks tlechnow!
    Hans
    I had this same exact issue on my TBc and it drove me nuts. My LBS called sram and less then a week later I had a new derailleur. Problem was resolved.
    Knowing what version derailleur you have - The 1st gen XX1 derailleurs (the ones with the harsh clutch) used a black anodized B screw that was often getting stripped. In the latest version (updated clutch) they switched to a stainless screw. At least this is the info my LBS passed on to me. Hope it helps.
    Jul 2013
    I have cabled routing issues since the first ride on my Ripley - at this point, the bike has been recabled three times (in a month). The latest version crossed the front cables and included the zip tie at the exit point - this morning's ride had constant cable suck back into the frame toward the rear and again pinched the RD cable. Anyone come up with a good way to stop this - clearly a design flaw that needs to be addressed by IBIS.
  67. #67
    Quote Originally Posted by gmduncan View Post
    Is one of the cables fixed, like that for a dropper or a FD? If the zip tie is tight and one or more of the casings are not attached to the swingarm, the casings as a group should not migrate either direction. That's the key.
    This should help.
    H
  68. #68
    Feb 2013
    I am running xx1, so I only have a rear derailleur cable and the rear brake line and have had zero issues so far. In fact, this is the first frame I have ever owned where none of the cables ever even rub the frame in any way.
    I followed the instructional video on youtube (I think that's where it was anyway).
  69. #69
    no issues for me
    I've also had no issues with cables on mine.
    As I've pictured / described before, I did the routing slightly differently than most have, but that shouldn't change the outcome.
    my rear der cable runs around the outside (not through) the frame and follows the rear brake line (zip tied together) then comes together, just above the rear shock, with the front der and dropper post lines...all 4 of them are zipped together.
  70. #70
    Lightly salted
    Can you post some pictures of your routing? Would make it easier to give a possible solution if we can see how your routed.
    When I built my Ripley I routed cables exactly as Ibis recommends and have had zero cable issues at all. In fact this is the quietest bike I have ever owned.. No cable rub, no cable slap, no creaking.
    I think 2 of the most important steps are to keep the cables only as long as needed so you have a clean look and minimum chance of rub. Even more important are the 3 zip ties after the cables exit the top tube at the forward shock mount. 1 zip tie an inch after exiting top tube on all cables, 2nd zip tie center of air can and 3rd middle of shaft. These zip ties need to be very tight, I used pliers to pull ties as tight as I could. My zip ties are so tight it is not possible for the cables to move independent of each other. This keeps my cables from being able to move in or out of the top tube.
    Heres 2 pictures of my routing. 1st picture shows the 3 zip ties above the shock that I was talking about.
  71. #71
    That looks really good, nice and clean. I have had zero problems as well, but mine doesn't look quite as good as yours.
  72. #72
    Reputation: Liquidmantis's Avatar
    That looks really good, nice and dirty.
    Fixed for accuracy.
  73. #73
    Jul 2013
    Really appreciate all the replies and pictures - went to work on this and think I have it. The key was the three zips over the shock and anchoring to a fixed. Great ride on a great bike yesterday and no cable movement. Thanks again
  74. #74
    Apr 2013
    I've been riding my Ripley now for two months and a little under 800km in that time. I have to say that the bike is amazing. Climbing, descending, accelerating, everything. I don't think Ill ever need another bike!
    The only thing that I have found I am not 100% happy with is the way my cables, especially my rear derailleur cable keeps moving back. The bike was set up by a long time Ibis mechanic and owner of Sunnyside Sports in Bend, Oregon; so I know the job was done well as per the book - however the cable keeps getting 'sucked in' towards the rear. That's the only way I know how to describe it.
    I've still been mucking about with a few other tricks, when I sort one out that works I'll post some images.
    Exx
  75. #75
    Jan 2016
    Ibis Ripley Small Frame Cable Challange
    For those like me, that have a small frame Ripley, managing the cables over the rear shock is a real challange, specially if the shock is the Cane Creek DB InLine like mine. Withe the help of some aftermarket cable guides and a plastic wrap and of course the Ibis Cable Dice it was accomplished.......attached some photos for your reference.
    Attached Thumbnails Attached Thumbnails Ripley paint damage: water bottle and cable routing-2014-ibis-ripley-29-finished-7-.jpg
    Ripley paint damage: water bottle and cable routing-2014-ibis-ripley-29-finished-8-.jpg
    Ripley paint damage: water bottle and cable routing-2014-ibis-ripley-29-finished-9-.jpg
    Ripley paint damage: water bottle and cable routing-2014-ibis-ripley-29-finished-10-.jpg
  76. #76
    Oct 2010
    Can you specify the aftermarket cable guides you used?
  77. #77
    Jan 2016
    Alligator Cable Guide: they get attached with a zip tie. I used 2 of them, side by side with one zip tie holding both, then I attached the rear brake housing and dropper post housing to them. Prior to this, I first used ones that have glue, but the cable tension peel them off the frame. So I have to use something with a zip tie (unfortunately, because the zip tie does not look good over the frame)
  1. HD with water bottle?
    By agleck7 in forum Ibis
    Last Post: 06-19-2013, 02:16 PM
  2. Paint damage Trek Elite 9.7
    By Trekelite in forum General Discussion
    Last Post: 05-14-2013, 05:56 PM
  3. flood water damage
    By dimm0k in forum General Discussion
    Last Post: 11-05-2012, 09:23 PM
  4. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
  5. The dreadful problem of paint damage..
    By Frobenius in forum Bike and Frame discussion
    Last Post: 01-30-2011, 10:23 AM
Members who have read this thread: 8
