I just want to point a couple of things out to Ripley owners and builders.
First, just because a water bottle and cage fits into the upper mounts with room to spare does not mean it is suitable in that location. The suspension swing arm moves in the water bottle's direction. Have a look at the paint damage to my brand new Ripley after the first ride. This is from a plastic Lezyne mount and standard plastic bottle. The bottle was not in contact with the paint, but the swing arm bashing into it caused damage not only to the swing arm but somehow to the seat tube as well!
Second, be sure that you, or your LBS, install the derailleur cables in a crossed pattern into the internal cable routes, with adequate slack. If they are too short and go into the onside route, then there will be enough friction on the cable stops to cause some ugly paint damage there as well.
