    Ripley Fork Options
    So the bike shop says my Large Ripley Frame is in, but my G2 120 mm fork is not expected until end of May. Don't really want to wait until the end of May, but want to make sure I get the most out of this bike and am pretty dead set on the 51 mm offset. I am having problems finding other alternatives to the Fox fork. Any recommendations?
    MSH
    MSH is online now
    Reputation: MSH's Avatar
    Jun 2005
    Quote Originally Posted by sch17517 View Post
    Be aware that the travel listed is incorrect. It's a 100mm not a 120mm. I've done a ton of research on it, talked to Sram, etc, etc. If you call Cambria and have them give you the actual RS part # it is most likely 00.4018.238.003, which is 100mm G2/51mm offset. Check BTI website and you will see there is only one G2 offset 29 SID RCT3 which is the 100mm version
    Reputation: Ramjm_2000's Avatar
    Jan 2005
    X Fusion Slide RL2? If its as good as the velvet would be pretty sweet! Tunable travel to boot! Looks like tons of good deals on ebay right now!
  1. Fork options for my ASR-C
    By tonyinatlanta in forum Yeti
    Last Post: 05-22-2012, 10:35 PM
  2. New Fork Options
    By jafstl38 in forum Diamondback
    Last Post: 04-22-2012, 07:53 PM
  3. Which fork for the Ripley?
    By simenf in forum Ibis
    Last Post: 02-17-2012, 12:25 PM
  4. fork options
    By BCoulter in forum Beginner's Corner
    Last Post: 09-02-2011, 09:38 AM
  5. 1.5 fork options
    By Grip in forum Cannondale
    Last Post: 01-10-2011, 02:41 AM
