Results 1 to 13 of 13
    Reputation: manchvegas's Avatar
    Mar 2011
    ripley compatible with an angleset? hans?
    Been on my ripley for about a month or so now I have it set up with a 140mm x-fusion trace fork which is pretty awesome.. but have been toying with the idea of an angleset.. Would like to maybe play around with a slacker HA.. or am I pushing the bike to it's limits? I have ridden alot of the same all mountain type of trails with my HD, an now with the ripley.. an on everything, I'm just blowing all my old times on my HD out of the water with the ripley.. Has anyone tried it? or does ibis not recommend it? as I see a few people running the 150mm pikes..
    Full time rider part time racer...
    See my adventures here..
    https://www.instagram.com/projectnortheast/
    sbd
    sbd is offline
    If you're smoking all of your old times then why mess with sucess?
    Mar 2011
    eh, was just looking at something a little slacker for those really steep trails I find myself on every once in a while
    It will fit and you can compare it.
    It will likely be better on the very steep downs, I don't know if you will like it the rest of the time, that depends on a lot of things, riding style, position on the bike, what you're used to etc.
    H
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Manchvegas, did you ever get an angleset for your Ripley? I'm considering one for mine and am looking for feedback.
    Mar 2011
    No i didnt. Ive kindof embraced the ripley as my great all around bike mostly xc oriented etc.. as i love how fast it is.. but when i wanna ride steep lines and huck myself off stuff i just grab my carbine i built up. I think the ripley has pretty perfect trail geo as is. I think the thing that scares me most when.i do try steep stuff with it is the lack of braking power because of the tiny tires ya have to run so you dont buzz the seat tube
    Sent from my LG-LS980 using Tapatalk
    aka dan51
    Mar 2005
    That was my original thinking; but the more I ride it, the more places I want to ride it. I'm either walking or scared shitless on stuff I don't think twice on when riding the HD. Aside from those few moments, the bike is fantastic.
    To go CC angleset requires an EC upper headset, which would raise my bar height. I tried running the bike at 140, but the bar height was higher than my liking, even with the stem inverted and no spacers below it. Hence the desire for an angleset.
    Mar 2011
    I run a 70mm ibis stem wih i think 7 degree rise inverted with bontrager rythym carbon bars which have maybe a 10mm rise with a 140mm x fusion trace and i like it alot.
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    Quote Originally Posted by d-bug View Post
    somethings gotta give. Your bike felt really xc (my hardtail "felt" slacker). Is the a2c on that xfusion fork super short or something? I've been on a dozen ripleys and yours just felt...off. No offense or anything, just definitely felt over-the-bars-ish, even just around a parking lot.
    Toss a pike on there!
    A-C on Trance is shorter than the 34 Fox, but not as short as a 32 Fox if the numbers on the spec sheets are accurate.
    Lightly salted
    Reputation: fuenstock's Avatar
    If your thinking of an angelset go with Works components. Compared to the cane reek angel sets I've tried it's been less trouble. No clicking or popping sounds.
    I have a -1 works on my hdr which is the same one needed for the ripley. It does have an external upper cup which is pretty tall.
    aka dan51
    Mar 2005
    Quote Originally Posted by fuenstock View Post
    Thanks, that 15mm tall stack height is about 10mm more than I'd want to go.
    I suppose if I get desperate I can swap out the fork to a 1 1/8 and be able to use the ZS headsets.
    Dec 2012
    I put on a -1 Angleset and 140 pike 51 offset front . Handling still fast , bike feel still nimble and fast on singletrack . But I highly recommend flat bar to lower down the cock pit for steep climbing . Totally rewarded on technical fast descent .no regret on this setting . This bike definitely born for tight flowy singletrack . Even faster and smoother than my previous HDR 650b.
  1. Ripley compatible forks
    By hanssc in forum Ibis
    Last Post: 06-04-2014, 09:21 AM
  2. Ripley questions for Ibis (Hans?)
    By Rone Turner in forum Ibis
    Last Post: 05-28-2013, 09:38 AM
  3. Replies: 2
    Last Post: 04-03-2013, 11:16 AM
  4. Replies: 2
    Last Post: 03-19-2013, 09:56 PM
  5. 2012 Remedy 9.9 compatible with Angleset?
    By OneEyedHito in forum Trek
    Last Post: 03-03-2012, 05:02 PM
