Results 1 to 9 of 9
    Reputation: mojo_man's Avatar
    Replacing the linkage bearings
    I have purchased the Enduro bearings for my SL-R for a change as I usually buy the whole linkage including bearings. I intend doing the job myself as I feel I’m mechanically competent in other areas that it can’t be that hard a job.
    I have lots of tools including a Park Tools headset press. (bit overkill I think?) Could anyone help me by suggesting the correct tool or tools I will need to do the job of removing and replacing the bearings correctly.
    In an idea world I’m looking for a step by step guide or recorded a video doing the job.
    Thanks in advance!
    Superstar sell the tool the UK that is shown in this video.
    Bearing extracting assembling tool---PATENTED---For Bike - YouTube
    All I really need to know is the size of the tool to fit the SL-R's links?
    Size options are:
    608 (ุ22ืุ8)
    6800 (ุ19ืุ10)
    688 (ุ16ืุ8)
    698 (ุ19ืุ8)
    6000 (ุ26ืุ10)
    6001 (ุ28ืุ12)
    6900 (ุ22ืุ10)
    6901 (ุ24ืุ12)
    6902 (ุ28ืุ15)
    6002 (ุ32ืุ15)
    6003 (ุ35ืุ17)
    6903 (ุ30ืุ17)
    Reputation: sohnice's Avatar
    ... and if we just ...
    Quote Originally Posted by mojo_man View Post
    Size options are:
    608 (ุ22ืุ8)
    6800 (ุ19ืุ10)
    688 (ุ16ืุ8)
    698 (ุ19ืุ8)
    6000 (ุ26ืุ10)
    6001 (ุ28ืุ12)
    6900 (ุ22ืุ10)
    6901 (ุ24ืุ12)
    6902 (ุ28ืุ15)
    6002 (ุ32ืุ15)
    6003 (ุ35ืุ17)
    6903 (ุ30ืุ17)
    Is stated on pdf page 16.
    HERE
    Thanks for that, much appreciated.
    Its on page 30 and for those who want to know the answer without looking its:
    For the Mojo, SL & SL-R:
    • Lower link front = 6902
    • Lower link back = 6900
    • Upper link = 608
    The HD has different fittings.
    Nice... much slicker than my ghetto socket set method
    EDIT: Bummer.... their website says no shipping to USA due to insurance...
    More Torque
    Reputation: Diesel~'s Avatar
    This thread is pretty much the granddaddy. I added some photos a few years back, and have used the same principles on the Mojo.
    -D
    Just got this tool, havn't used it yet but the quality is very good.
    RapidRacerProducts Bearing Press & Extraction Tool | Buy Online | ChainReactionCycles.com
    http://www.rapidracerproducts.com/BP...ng%20Press.pdf
    Kit Number: Bearing Name / Inner Bore (mm) / Outer Diameter (mm)
    • Kit 1: 688 2RS / 8 / 16
    • Kit 2: 698 2RS / 8 / 19
    • Kit 3: 608 2RS/608-E 2RS / 8 / 22
    • Kit 4: 6800 2RS/61800 2RS / 10 / 19
    • Kit 5: 6900 2RS/61900 2RS /10 / 22
    • Kit 6: 6000 2RS / 10 / 26
    • Kit 7: 6901 2RS/61901 2RS / 12 / 24
    • Kit 8: 6001 2RS / 12 / 28
    • Kit 9: 63802/6802 2RS/61802 2RS / 15 /24
    • Kit 10: 1526 2RS / 15 / 26
    • Kit 11: 6902 2RS/6902-E 2RS/61902 2 / 15 / 28
    • Kit 12: 6002 2RS / 15 / 32
    • Kit 13: 6803 2RS/61803 2RS / 17 / 26
    • Kit 14: 6903 2RS-E2RS/61903-E 2RS / 17 /30
    • Kit 15: 6003 2RS / 17 / 35
    • Kit 16: 6804 2RS/61803 2RS / 20 / 32
    I need to order my bearings............where did you get yours?
    Canuck Tacoma, I ordered from RWS.
    I tried going to a commercial bearing shop to pick up a couple sets but they couldn't source the angular contact ones.
    I have "ghetto-illy" removed and replaced mine with a piece of threaded rod, washers, two bolts and different sized sockets. Worked fine.
    The only issue was that one that I replaced in the lower link was not a tight fit. I read that someone else had run into the same issue and Ibis recommended loc-tite to keep it solid.
