Results 1 to 3 of 3
    Oct 2007
    Rear shock bolt hardware question
    Hey, I've got a 2010 Ibis Mojo SL. I just had the rear dt swiss shock rebuilt. I'm bolting the shock back onto the frame. My question is does the bolt for bottom piston side of the shock have a nut or any hardware to assemble once you thread the bolt through the triangle, through the mounting hardware on the shock and into the threads on the triangle on the other side?
    Does it just thread in and tighten down with no nut\hardware and that is it? I swore I put all the bolt assembly pieces in one spot while broken down. Now on assembly it looks like something is missing.
    Thanks for any help.
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    it should go bolt > triangle > shock reducer bushing > shock > shock reducer bushing > triangle.
    No nut on the other side.
    Cheers.
    Oct 2007
    Ok, great. I guess I had my mind centered on the pivot bolt assembly and how they assemble. Thanks
