Results 1 to 2 of 2
    okay/safe to get rid of seatpost clamp?
    I'm not one to adjust the post once I set and forget. Is it okay to put a seatpost binder bolt on the mojo without cramping/crimping/hurting the seattube?
    Quote Originally Posted by danK
    The binder off the Silk carbon works fine and saves 50 ! grams.
    Drop us a line if you want one info@ibiscycles.com
    Hans
