Results 1 to 13 of 13
    Dec 2005
    Ohlins CCDB on a Mojo SL?
    sorry if this has been covered. will an Ohlins CCDB fit on the Ibis Mojos?
    thanks
    San Diego County
    Reputation: Duzitall's Avatar
    I have no clue about the double barrel but
    I thank you for your avatar
    Quote Originally Posted by turnerbikes View Post
    Of course the easiest way to fix this is to go for a hike.
    DT
    Dec 2005
    Quote Originally Posted by Duzitall
    thanks! i probably need to change her up, but it still looks good. i am a motocrosser too
    no one knows about the shock? i am fearing the worse
    i hope there are not clearance issues.
    San Diego County
    I'll give ya another bump
    so Hans will see your question. Maybe Ibis has tried one on for size.
    DT
    Db
    not a clue on that.
    Hans
    Dec 2005
    Quote Originally Posted by hanssc
    not a clue on that.
    Hans
    hmmmm
    who would know? whether or not i can use the ohlins will play a role in frame selection. i am more than happy to contact cane creek, but will they even know?
    i saved the money to be put on the list for a new mojo sl but i need to clarify this first...
    www.derbyrims.com
    Reputation: derby's Avatar
    Quote Originally Posted by mx_599
    hmmmm
    Don’t know for sure about the CCDB, but there’s plenty of room for a common sized shock with external reservoir. Sounds like a great shock. I sure want to try one.
    Dec 2005
    Quote Originally Posted by derby
    okay, thanks!
    yeah, that was my only concern, the reservoir. that is comforting to know. well, someone needs to help me figure this out.
    i will call ibis and CC.
    if i buy a mojo sl frame now, does anyone know the approximate wait? are we talking march or later?
    thanks
    Fitting the CCDB
    Hello again,
    Edit: new info from Cane Creek:
    We have tried to mount a Double Barrel on a Mojo and it does not fit. There is not enough room for our spring clip on the shaft end of the shock to clear the linkage. This is because we don't have a rebound control in the shaft end eyelet, like other shock manufactures.
    We are working a new spring clip that would allow more clearance. We hope to have this on line in the about 45 days. We could build a sample for you then.
    Regarding lead times for the SL frame it depends on the dealer. Some dealers have all the deliveries pre-sold and some will have them available to sell when they arrive.
    Cheers!
    Hans
    not so super...
    Reputation: SSINGA's Avatar
    IMO...the CCDB would be worth the wait.
    Nothing to see here.
    Dec 2005
    Quote Originally Posted by SSINGA
    definitely, next month...
    We are working a new spring clip that would allow more clearance. We hope to have this on line in the about 45 days. We could build a sample for you then.[/B]
    Is the shock ready?? This is really interesting product!
    Dec 2005
    Quote Originally Posted by mtok77
    i just sent malcolm an email he should respond today. they were still waiting for the redesigned "spring clip". that was a couple weeks ago. see what he has to say this time....
