Results 1 to 11 of 11
    Reputation: Ramjm_2000's Avatar
    Jan 2005
    New Rear Triangle Carbon Layup
    Hans/Scot
    Can you guys tell us if the new 27.5 rear triangle is going to be the same layup as the HD rear or the HDR? Same estimated weight/strength? Thanks
    JR
    Hi Ramjm_2000,
    The HD retrofit rear triangle will be the same layup as the HDR.
    The weight will about the same as the current HD rear triangles since the weight savings on the HDR is primarily from the front triangle.
    Jan 2005
    Thanks Todd!
    BB height
    and how will the new triangle run in terms of BB height?
    will it run any lower than the standard HD BB height?
    Quote Originally Posted by ianthom View Post
    Hi ianthom,
    The HD retrofit rear triangle will not affect the BB height.
    maybe the wrong time to ask since I already ordered one of the retro swingarms instead of going to an HDR...but will the HD with the retro arm have a different bb height than an HDR (in comparable travel modes)?
    Quote Originally Posted by riderup View Post
    Hi riderup,
    The BB height will be the same using the HD retrofit rear triangle in both travel modes as the original HD swing arm.
    Todd
    is that different from the HDR or same as the HDR?
    Hi riderup,
    The BB height for the HD is different than the HDR.
    The BB height for the HDR W/ 26" is 13.8
    The BB height for the HDR W/ 27.5" is 13.5
    The BB height for the HD W/ 26" @160 is 13.8
    The BB height for the HD W/ 26" @140 is 13.5
    The BB height for the HD W/ 27.5" @140 is ~ 14.25
    The difference in BB height between the HDR W/27.5 and the HD W/27.5
    comes from the front shock mounting chips which are model specific.
    These numbers are all dependent on what tire/fork combination you are using.
    Jan 2005
    Todd those numbers look off to me. My HD 140 with a Velvet 140 had a BB height closer to 13.5 with Schwalbe RR 2.25/NN 2.35 mix in 27.5. With my sweep its still under 14". What fork and tires is that measured with?
    Eld
    Eld is offline
    Jan 2014
    Well, since 650b is almost exactly 1" bigger than 26" you should get 0.5" higher BB when using same size+brand tire and same AC fork.
    Personally I prefer when companies spec BB-drop in relation to wheel center, it's a much more comparable measurement.
  1. SB95a---Has rear triangle always been Carbon???
    By FirefighterMTN in forum Yeti
    Last Post: 11-18-2013, 11:53 AM
  2. Replies: 2
    Last Post: 12-11-2012, 10:10 PM
  3. Rear Carbon Triangle Dilema
    By torque29er in forum Specialized
    Last Post: 01-22-2012, 10:42 PM
  4. How much abuse can Carbon rear triangle take?
    By rookie nick in forum All Mountain
    Last Post: 12-24-2011, 07:26 AM
  5. Replies: 7
    Last Post: 07-05-2011, 08:01 PM
