Results 1 to 19 of 19
    New owner of a Dream Bike...er...Mojo HD
    Well I just bought a new Mojo HD: X-9( 2x10) with a Fox 34 Float( 160mm). I upgraded the cockpit, You can't have VW parts on a Porche. So bye-bye parts bin foam grips ( should be illegal on a 5k bike) and crappy ibis stem and bar. Hello Easton Haven Stem and Haven Carbon Bar, with some Oury lock ons. Also threw on some Xt dual platform pedals.
    So my question to you is: Any recomended suspenison set-ups?
    2. Is the Specialized rear XC race tire even worth using, or should I just scrap it now?
    3. How many rides or miles until the bearings and seals break in?
    4. How do the Ibis wheel sets hold up?
    5. I am f'ing stoked to have finally bought a bike at the top of the food chain!
    Quote Originally Posted by MC SlingBlade View Post
    How about on a veranda?
    If you're going "top of the food chain," why those pedals vs. XTR?
    I beat up my pedals with pedal strikes too much already. I need durable Xt to get me back to the car more than I need insanely light XTR.
    XTR pedals are very durable and not insanely light by any stretch of the imagination.
    If you're constantly enduring pedal strikes, it's time to work on your technique/timing/ratcheting.
    Touché
    Reputation: Yody's Avatar
    Im not a pedal banger, but when you ride a lot and ride hard you still sometimss bash the living **** out of your pedals. Im runnng xtr trails but id be just as happy with the xt. Theyre both similar and quality.
    Reputation: Murchman's Avatar
    XTR pedals are slimmer and therefore will have less pedal strikes. I know this because I have both XTR trail and XT trail pedals.
    Quote Originally Posted by Murchman View Post
    While your statement is accurate and correct. I believe that pedal strikes, in general, are a result of modern big travel suspension design. The frame designers, IMO , lower the bottom bracket height to make the bikes handle/turn better. If you couple that with 5"-6" of travel, the pedal is going to be fairly close to the ground. Add in Northern California Rocky terrain , and you learn to accept pedal strikes. And pick your parts accordingly.
    Reputation: gunnirider's Avatar
    Quote Originally Posted by saidrick View Post
    My Spec rear tire lasted 9 rides. Thought the tires were basically throw a-ways, but had to try them, switched to the old faithful Minon
    Quote Originally Posted by gunnirider View Post
    I suspected as much. I guess I should get the order going for the minion / high roller combo. I think that Ibis picked the tires/foam grips/ and seat collar bolt, to lower the weight of the bike.
    Reputation: skyno's Avatar
    They'll last about 10 rides (about as long as Nobby Nics) if you are riding agressive on rocky terrain - yeah they're light but they can blow out as well if you run tubeless - I recommend Ardents - good traction & hold up amazingly well for the weight - only blew out once going off a 6 ft. drop on to a hard landing
    There's nothing special about "Norcal rocky terrain" that causes pedal strikes. Proper technique/timing/ratcheting will make pedals strikes much less frequent.
    Let me clarify: By rocky, I mean places like Annadel, Oathill,( Sonoma county), Pine mountain( Marin) and Downieville.
    Places like China Camp and Santa Cruz, are not very rocky, and as a result, I don't pedal strike very much in places.
    You two really gonna keep arguing about pedal strikes?
    This is where I post the most and the discussion was decent until you started argung semantics on pedal strikes.
    And who are you supposed to be to judge others, let it go
    not distressed at all, you obviously just wanna argue. I'm not trying to look like a tool and be apart of this thread anymore so goodbye, I'm sure the OP appreciated you ruining his thread.
    Wait for me!
    Reputation: whoopwhoop's Avatar
    Nov 2008
    I've seen you around these parts, your an instigator. Do you even own an Ibis or are you just trolling?
    I am done with this thread. Thanks for the tire responses. I may have "improper " technique, but I am okay with that. The important thing to do is get out and ride.
    Wait for me!
    Nov 2008
    I own two.
    Are you suggesting that someone needs to own an Ibis to discuss pedal strikes in this forum?
    No, I'm saying you troll around the forum picking fights. Your like a stoke removal machine, the guy is excited about his new bike and your just being a d!ckhead.
    SLO Mtn biker!
    Reputation: Zuke's Avatar
    Too bad some troll ran this potentially informative thread off the tracks and over a cliff, leaving half the OP's questions unanswered.
    Reputation: GuruAtma's Avatar
    Thanks. You made me laugh again.
    Is your name Pete?
    功夫大师喜欢骑着他的自行车在山上。
