Results 1 to 6 of 6
    OriginalDonk
    Reputation: OriginalDonk's Avatar
    New Cane Creek Double Barrel Air CS (Climb Switch)
    Looks like Cane Creek just announced their new Cane Creek Double Barrel Air CS (Climb Switch). It sounds like they've added a lever to flip that will provide platform via LSC and LSR for extended climbs. Sounds to me like one of the two complaints I've heard about the CCDBA, the absence of a lock out, might be addressed here.
    "With the new CS version of the DB Cane Creek have added another two low speed damping circuits, bringing the overall total up from four to six. The four previous circuits (LSC, LSR, HSC & HSR) work in exactly the same way as before, but they are now joined by an extra LSC and LSR which are engaged via the new ‘CS’. With the switch turned off your shock works exactly like a non-CS shock, but when you switch it on it engages the two new circuits, which in turn increases both the low speed compression and low speed rebound damping."
    Info here:
    Cane Creek release their new Double Barrel CS rear shock | Dirt
    Oct 2010
    Now come the question of retrofitting... Any info if it will be possible to get the CS on normal DB air ?
    Mtb Guide
    Sep 2012
    Choices just get harder, awesome!
    Oct 2007
    Won't be possible. From CC:
    "The DB-Air CS is a completely different damper from the DB-Air, and it isn't possible to retrofit or upgrade to the CS platform. The DB-Air CS is a new shock separate from the DB-Air."
    May 2012
    Quote Originally Posted by m1neral View Post
    shit but why not a year earlier
    Reputation: davemk's Avatar
    Jan 2009
    Better question is will Ibis switch the HDR shock upgrade over to a CCDBa-CS?
    "Less yappin' more braapin" - IFHT
  1. a little oil came out my cane creek double barrel
    By david8613 in forum Shocks and Suspension
    Last Post: 04-22-2014, 08:25 AM
  2. Cane Creek Double Barrel AIR
    By Iggz in forum Downhill - Freeride
    Last Post: 02-21-2014, 08:39 PM
  3. Cane Creek double barrel service
    By kingair in forum Shocks and Suspension
    Last Post: 04-09-2013, 06:47 AM
  4. Cane Creek Double Barrel air on a M.57?
    By Rei_Ikari in forum Pivot Cycles
    Last Post: 10-25-2011, 05:33 AM
  5. Cane Creek Double Barrel on a Mojo
    By stroodle in forum Ibis
    Last Post: 05-21-2011, 02:06 PM
