Results 1 to 35 of 35
Thread: New Bits...
    Too Much Fun
    Reputation: benja55's Avatar
    Aug 2005
    Good job! New Bits...
    I just noticed some new lil nuggetts of newness up on the Ibis Store Site...
    Mostly of interest to Ripley riders, but the front der cover is handy to all...
    - -benja- -
    Reputation: DrewBird's Avatar
    Yep, I got my GnarCore a couple days ago as part of a new swing arm (Ibis CS is amazing!) It was easy to install and fit the bike great with reassuringly tight tolerances. Here are some details for anyone interested:
    GnarCore and ti bolt on a scale:
    Original core and alloy bolt on a scale:
    Ti bolt (top) and alloy bolt shown together:
    GnarCore(L) and original core. Note a bit more material around threads and slightly greater overall wall thickness.
    I've got a ripley from november, is the new lower eccentric necessary? I haven't had any issues with mine at all and own a torque wrench and don't over tighten anything
    Then you should be fine, but according to their newsletter it also makes for a 10% stiffer rear end, and it's only $35
    You definitely don't need it, everything will work fine as is. Installation is easy but does require removal of the rear swing arm (which means removing chain, cranks, rear der., rear brake caliper etc.) so it takes a little effort. I'd recommend waiting until you're doing an overhaul anyway and then installing one.
    Anyone try that cable dice yet? I'm having annoying cable issues in that area around the shock. When the rear compresses, the RD and rear brake cable push out to the right, and depending on the situation, sometimes hits the inside of my right leg.
    meh
    Reputation: clewttu's Avatar
    Seems like the cable dice would rattle around pretty bad. I dont have a Ripley, so not sure, just going by looks...or does it attach to the frame?
    Quote Originally Posted by clewttu View Post
    It has been silent on my bike and the rest of our test bikes. It doesn't move around like you'd guess. It's very solidly held in place once clamped to the casings.
    H
    Sep 2013
    Methinks I will be ordering one of those dice and a Gnarcore very soon. Hah, and as always I'll probably have to be tempted by some other goodies at the same time
    Reputation: trevorrr's Avatar
    New Bits...
    Do I have the Gnarcore? My frame arrived at the LBS in Calgary on Jan 24th or 27th and the lower looks like this:
    Trevorrr,
    Yes, you do.
    H
    New Bits...
    Quote Originally Posted by hanssc View Post
    Trevorrr,
    Yes, you do.
    H
    Sweet
    Mar 2006
    No good You should have named this thread "New Bits :madman:"
    After 4 months of trying to get rid of the creaks and clicks from the bike, I decided that enough was enough, and returned my creaking Ripley back to the local Ibis dealer.
    The Ripley was a joy to ride, but it's mechanical imperfections are totally unacceptable at this price level.
    Ibis - do your homework before you release a bike to the market, not after.
    Quote Originally Posted by quisp View Post
    Did you set up the cables exactly as Ibis recommended, zip ties inside frame and all?
    Did you lube your eccentrics?
    Did you contact Ibis about the issue?
    After doing all three of these things, Ibis sent me a new rear swing arm on the off chance that there was an issue with bearing alignment (actually, they saw a post on this board complaining of creaking and contacted me, AMAZING CS). Having installed it and set my cables up the way they recommend, which my shop had not done when building the bike, my Ripley is now silent.
    Personally I think it's awesome that Ibis works with its customers to fix these issues, by releasing things like cable dice and the GnarCore. Could you imagine Specialized or Trek doing something like this? And yes both companies--hell, ALL companies--have released bikes that have some issues. Unless it's a safety thing, big companies just say "well, we'll fix that in next year's model, be sure to buy a new frame then." That's not the Ibis approach, and I greatly prefer their way of handling this.
    Feb 2005
    Lets not forget that Ibis DID do their homework and opted to NOT release the Ripley asap. They could have still made a killing and opted to change the design down the road. Instead, they missed out on sales and waited for the correct design.
    Check out the Ripley preview in Bike Magazine:
    Initial testing with the bushings went quite well—for a good, long while actually—until Ibis racer, Evan Plews, was racing a sloppy 100-mile endurance race in Georgia and the bushing system got gunked with mud and went tits up. Evan finished the race, but the contamination thoroughly the bushings. Ibis realized they needed to rethink the bushing project. In essence, they found that there wasn’t enough room for both the required bushing material and adequate seals in their particular eccentric configuration.
    There were other changes, including rear travel and geometry...
    Nearly every full-suspension bike (at any price point) has issues with internal cable routing...
    New Bits...
    My Ripley has had a few creaks, but I found them in the cassette, stem, seat post and rear derailleur and not the BB. The cables have been good and I think it looks clean with the cable routing. It's too easy to give up, the bike is great!
    Quote Originally Posted by Pelly_NH View Post
    This isn't true at all. Some bikes don't have internal routing at all, and of the ones that do, the problems the Ripley had were particularly bad, from the odd place the cables enter, to the sawing through the steerer tube, no stealth dropper routing (which is the most useful internal routing), to the problems the die is designed to fix.
    Mar 2006
    My english is far from perfect but i will try to explain:
    1. Cables were installed correctly.
    2. Eccentrics were checked, cleaned and lubed more then once.
    3. A word for all the guys that try to fix these problems on their own: You paid thousands of dollars on a top brand carbon fiber bike - It should not creak. It's a new bike! You are supposed to ride it, not to tear the eccentrics apart every month to keep it silent.
    4. A lot of my riding buddies ride carbon bikes from other brands. Their bikes are silent.
    5. I spent WAY too much time trying to solve my Ripley's creaks, mainly because I loved how it rides.
    6. I visited the local Ibis dealer more then 10 times during those 4 months.
    7. First it was the steerer guards (2 versions – the plastic one was torn inside the headtube), then came the new clevis bolt, and now the new eccentric core. "new bits"...nice name for parts that should have been inside the frame on the first place!
    8. After 4 months, Ibis kindly offered me a new frame. Since I went thru enough trouble with the bike, I decided to return the frame and get my money back.
    9. All those posts about ibis having a very good customer service are true. But when I buy a new top of the line bike I don't expect to deal with customer service at all.
    You should consider yourself lucky that you bought it from a company (and probably the only one) that accepts returns based on the complaint of noise...
    Edited: because my last post may have been a bit harsh.
    meh
    He did say they have great customer service, he just wasnt happy with the frame...
    Mar 2006
    Dear Zeppman, please read my post again. I don't have anything aginst Ibis or its customer service. From the "creaking ripley" threads in this furom I learned this problem has effected a lot of Ripley owners, and i thought it's important for poeple to know about my experience. Thats all. i retunred the frame because i spent too much time and effort on solving its problems, from the cable routing to the eccentrics and other stuff. I have been buying and riding bikes for 20 years, i never had such a bad luck with a bike. Maybe that's what's this is all about, bad luck...
    Feb 2013
    I hear ya quisp. It sucks when you fork out a lot of cash for a bike and it isn't perfectly quiet. For the most part, I have had pretty good luck with bikes over the last 27 years I've been riding. I did have a Superfly 100 though that I dropped some hard earned money on that was noisy (it had a few creaks) and had durability issues (2 cracked swing arms and 1 cracked main frame) in a 2 year time frame. Trek just kept sending me swingarms that would break, no noticeable improvement, until I finally unloaded it last year. I saw on the Pivot forum (was considering a 429c for a bit) that some of those bikes had creaking issues as well. I like the fact that Ibis supports their bikes with reasonable upgrades (cable dice, beefier eccentric, etc). Lots of other manufacturers just make you live with bike you have until you buy a new one.
    Sucks about your experience though.
    Sep 2013
    I ordered a Gnarcore and a Cable Dice (while I am at it, I grabbed some Ibis grips and pair of Ibis pub glasses... good for having a lager while fitting the gnarcore and cable dice )
    I'll be stopping by Ibis tomorrow to pick up the new Gnarcore. Don't have any issues, but thought it would be a nice upgrade.
    Ibis's customer service is the best I've seen so far. Just an awesome product backed by outstanding service. Thank you!
    Sep 2013
    Quote Originally Posted by bassn View Post
    Actually, I might pop down to Ibis and get them to install it for me. Oh wait.... That would be at least 13 hours 40 minutes flying time for me. NZ is a helluva way away from Santa Cruz
    I've had my Ripley for going on a year and it has some random creeks and groans, but they have not been frame related. Mostly XX1 derailuer, seatpost chainring bolts.
    All bikes make noise and you have to maintain them to keep them quite. The carbon transmitts the noise so its hard to pinpoint.
    I had an issue with the shock pin and Ibis CS went way out of their way to help. Best CS in the business. They will help you until the problem is addressed.
    I have the cable dice installed on the Ripley and I would highly recommend it. Initially I was concerned with the block banging around, but not a single sound. It's money well spend for as little as it cost. Here's an attached picture of the how the cable sits with the dice installed. Sooo much better than the zip tie method.
    Sep 2013
    That looks good, and it is good to hear it is quiet. I'm looking forward to mine arriving
    I'm curious about the X Fusion shock. How do you find it on the Ripley? That is an upgrade I have been considering.
    Quote Originally Posted by mcam View Post
    In the next month I'll be riding both the Microlite and Pushed RP23 to see which ones stays on. The Microlite has a custom tune on it specifically for the Ripley, and the Pushed shock was tuned to exactly my style of riding...we'll see.
    Let us know how the shock swap goes, I'm curious about the microlite too & I'm sure I'm not alone!
    I'll start a new thread.
    Reputation: D_Man's Avatar
    New Bits...
    What is the weight savings between the two?
    Mar 2012
    Hey bassn, any feedback on how the microlite and push'd CTD compare?
    New Bits...
    Quote Originally Posted by Hayakawasaki View Post
    Sorry for the late reply, but I must have missed this.
    Up until a couple of days ago I've been riding my Pushed RP23. Definitely a huge upgrade when compare to stock. It actually took me a while to dial in everything, but finally got there. If I were to complain about something it would be the minimal difference between fully open and propedal. But, since I typically ride with both the fork and shock fully open, not an issue.
    Over the past month I've been fighting a creak (RP23) in the upper shock mount. I've tried just about everything to remedy this creak, but after about an hour of riding it would come back. Over this long weekend I decided to throw the Microlite on and give it a whirl at both Demo and UC. These are the 2 most common trails where I ride. Wow, was I impressed! IMO this was by far a plusher feeling shock, and without any creaks. It took everything my ability could throw at it, and never flinched. I actually nailed a PR coming down a well know trail called Braille, which was pretty beat up for this time of the year. We even got held up by 2 groups of riders. In short, it pedaled very well and felt buttery smooth on the down...very happy!
    We'll find out how well the smaller body shock will handle the longer descents of Downieville. Hopefully that will be next week.
    Oh, did I mention that I'll be getting a killer deal on the new Cane Creek Inline when it's released .
    Mar 2012
    Thanks for that update. I put in a pre-order with Cane Creek for the DBInline so hopefully that is available sooner rather than later. Otherwise it sounds like the Microlite might be a good option.
  1. Kibbles and Bits
    By KRob in forum Nevada
    Last Post: 12-10-2013, 06:43 PM
  2. Best Bits for 2012
    By BigwheelsRbest in forum Videos and POV Cameras
    Last Post: 01-01-2013, 08:57 AM
  3. anyone want some trance x bits?
    By giant_in_a_trance in forum Giant
    Last Post: 11-29-2012, 06:37 AM
  4. On the scrounge for bits....
    By deesta in forum Lights DIY - Do It Yourself
    Last Post: 08-23-2012, 10:37 AM
  5. How to use up some old bits??
    Last Post: 05-07-2012, 02:08 AM
