Results 1 to 3 of 3
    Reputation: mojo_man's Avatar
    MRP Lopes SL Chain Guide
    Anyone running one of these?
    Iíve read the description a few times and Iím still not sure if I need to buy the adapter to fit this to my SL or if it will bolt straight on?
    MRP Lopes SL Chain Guide -- Ibis Cycles Online Store
    Itís that or go for the Mini G2 with bash but not sure how easy adapting that would be.
    Any photos of them fitted would be helpful with any changes that were needed.
    Reputation: evdog's Avatar
    Interested to hear as well. I have been running an E-13 on my SL. It has been great, until the lower arm strikes a rock, then I am taking off the crank and loosening the BB to re-position it. I'm getting fast at that, however!
    I assume this MRP could be run with an external bash guard mounted to the crank arms?
    I ran the Lopes SL on my HD, it's lightweight and quite. If you're clean and smooth you don't need a taco bash. If you want to use the "link bolt" set up than you have to buy the link/Bolt adapter - in the store.
    Otherwise, install your guide by: 1. Clean bb cup face, bb shell face and lopes guide with brake cleaner. 2. Reinstall and torque to 40NM. If it still slips you would have broken the lower guide off if installed with a bolt.
    Good Luck
  1. Lopes guide pulley bearing failure
    By JimEG in forum Ibis
    Last Post: 04-16-2013, 05:27 PM
  2. LOPES chain guide w/ 36T BASH GUARD..
    By qkenuf4u in forum Ibis
    Last Post: 07-28-2011, 12:47 PM
  3. rohloff chain guide or other guide options???
    By nicolian in forum Nicolai
    Last Post: 05-22-2011, 02:06 PM
  4. Replies: 4
    Last Post: 01-10-2011, 01:11 PM
  5. Chain Guide / Roller Guide & Bash Guard
    By double_a in forum Downhill - Freeride
    Last Post: 01-10-2005, 12:27 PM
