Results 1 to 7 of 7
    MRP G2 SL chain guide on Mojo SL
    Hi Guys im wanting to set my Mojo SL as 1x10, can anybody tell me if the MRP G2 SL guide will fit on the Mojo SL? Do I have to modifiy around where the lower link sits?
    Anybody got photos to share on the above?
    Reputation: Magsrgod's Avatar
    I just went through this. You need to order the Ibis specific g2 sl and you need to get a new axle for the lower pivot on the front triangle. It's around 15 bucks for it.
    Thanks for the quick feedback, I have received the MRP G2 SL guide from Ibis, do I have to modifiy it?, In the packaging it came with several washers and a small bolt, does this fit to the lower link or are I missing another bolt?
    http://store.ibiscycles.com/shared/S...unt2=419013619
    You need one of these, the small bolt you got will screw into this, this new axle makes it so the back plane of the g2 will be flush against the pivot
    you dont need to modify anything. The washer that came with the mrp are to be used in your chainring bolts.
    I'm looking at running a 1x10 on my SL with the same chainguide. My question is if I can get away with running it with my 2x10 crankset? I sure don't like running big/big and am worried that the chainline is going to be problimatic when running in the big cog for extended periods. Any feedback from anyone who has this set up would be great. Also will the MRP G2 SL even work with this chainline? Thanks.
    It will not work with a 2x10 setup, though there are chain guides that will run a 2x10 setup
