Ok so I'm getting a bit frustrated with the stock FOX on my new HD 140. Having to use too much pressure to keep from blowing through the travel. Will be getting the volume reducer kit. That said I've been thinking about also trying a 7.875x2.25 to get a tad more travel. Soooo before committing to a more expensive shock has anyone used a monarch R? Low compression medium rebound seems to be the recommended tune. Given the mojos pedaling efficiency I see no need for the lockout since I use tail or descend 100% of the time on the fox. Any errors in my thought process?
