    Monarch Plus RC3 Bushing Kit for HD.
    Hi guys, I have done a few searches but nothings come up except tunes and stroke. I am just building up a HD and have a Monarch Plus RC3 to go with some new Pikes, but i cant find any info on bushings/mountings and neither Sram or 2pure (UK Ibis dist) cant/wont help.
    Is there a specific mounting kit required for the Monarch and if so can anyone post a link or give me the sizes of what bushes i will require to get it fitted correctly.
    Thanks in advance.
    Use the Fox bushings, they're the same.
    Lightly salted
    Reputation: fuenstock's Avatar
    I copied this direct from Ibis website. All info you need is on their site. If you can't find sram reducers, fox works just as good.
    Genuine replacement Fox shock hardware for your Mojo Carbon, Mojo SL, Mojo HD, or Mojo SL-R.
    Front specs are 21.8mm wide an 8mm through-hole, and the rear is a 40mm wide with an 8mm through-hole.
    Thanks guys, appreciated.
  1. Yes I know... Monarch RC3 vs Monarch Pluc RC3 vs Vivid air on a NomadC
    By sir_crackien in forum Shocks and Suspension
    Last Post: 02-05-2013, 08:50 AM
  2. monarch plus bushing removal for rwc bearing
    By slideways666 in forum Shocks and Suspension
    Last Post: 04-20-2012, 05:46 PM
  3. RS Monarch, Monarch Plus, Vivid tune diagram
    By Breal604 in forum Shocks and Suspension
    Last Post: 11-05-2011, 05:15 PM
  4. Replies: 7
    Last Post: 06-25-2011, 06:57 PM
  5. Jamis XCR bushing reducers for RS Monarch
    By mmcverry in forum Jamis
    Last Post: 04-30-2011, 03:50 PM
