Results 1 to 5 of 5
    Nov 2014
    mojo sl rear tire clearance?
    looking for some feedback on what people were/are running in the rear on the mojo sl. I bought a used frame to build up as 26.
    this will be my first fs bike and just trying to get some concrete info. did some searching on this topic and basically found conflicting info but seems 2.4 is the max but sometimes wont work depending on other factors.
    my rims will be stans flow ex.....medium frame...i'm 155lbs.....riding in austin tx so lots of loose over hard and rock gardens/ledges...i'm pretty new to the sport but love to rail corners and need good climbing traction on slick rocks.
    if anyone has specific info of larger volume wide tires that have worked without problems please let me know.
    was considering:
    nobby nic 2.35
    ardent 2.4
    Quote Originally Posted by Coleman22 View Post
    was considering:
    nobby nic 2.35
    ardent 2.4
    I have no rubbing with Kenda Slant Six and Nevegal 2.35 on Derby 40mm Carbon wheels. I did rub on big bumps when I had my Crankbrother XC cobalts wheels on the 2.35.
    Sponge Brain
    Close, but no rubbing with 2.4 Conti MK on Industry Nine Torch Enduro 26 wheels. Conti Mountain King (gen 1) is definitely not a full 2.4" wide tire though.
    meh
    Reputation: clewttu's Avatar
    I had some rubbing with a NN 2.35 on my Mojo C
    I ran Nevegal 2.35, Slant6, and Conti trail king 2.2 on original Flows on mine when I had 26" wheel on the back with no problems...it will take some fairly chunky rubber, but if you cram the largest tire the chainstays will allow, you might get some seat tube rub at bottom out.
  1. Ibis Mojo HD w/ BikeCo Shock Tire Clearance?
    By shenvatele in forum Ibis
    Last Post: 03-26-2015, 08:14 PM
  2. EMD 9 rear tire clearance
    By EclipseRoadie in forum Niner Bikes
    Last Post: 10-20-2013, 12:27 PM
  3. 09 575 rear tire clearance
    By yeti575inCA in forum Yeti
    Last Post: 03-09-2012, 07:23 AM
  4. El Mar Ti rear tire clearance
    By rth009 in forum Salsa
    Last Post: 08-23-2011, 08:32 AM
  5. El Mar rear tire clearance?
    By TroutBum in forum Salsa
    Last Post: 06-27-2011, 05:00 PM
