Results 1 to 3 of 3
    Oct 2012
    Mojo SL headset help please!
    After getting some very helpful advice about 2nd hand Mojo's on here, in the end I decided to buy a new Special Blend because 2nd hand prices were not much cheaper.
    My Special Blend should be arriving tomorrow and the first mod I'm going to do is replace the X-Fusion forks with a set of Pace RC41 Fighters. My problem is I can't figure out what headset I need as the Pace forks are a standard 1 1/8" steerer tube and the X-Fusions are tapered.
    Can I just fit a reducer to the lower headset to run the Pace forks or do I need to replace the whole lower cup? I have seen in the Ibis set-up guide that you can fit a headset reducer but can't seem to find one.
    Help! cheers
    Quote Originally Posted by 1210tech View Post
    Help! cheers
    Donīt worry, the SL uses fork with 1 1/8 steerer tube & headset 1 1/8 , you can use the same headset.
    Oct 2012
    Quote Originally Posted by Pat-G View Post
    Oh, so the X-Fusion Velvet fork that the Special Blend comes with isn't a tapered steerer tube? Result if thats the case
