Results 1 to 2 of 2
    Jan 2013
    Mojo SL, blown Fox RP2. 2014 Float X?
    This weekend I was riding hard the Mojo Sl Special blend, and apparently somehow moved the lockout lever while descending. Later I found my shock leaking oil, with the lever stuck between the descend and propedal option. I managed to move it to propedal, but can't move it back out. Also the rebound dial is stuck. I can ride the bike and the shock compresses all right, but rebound is crazy fast!
    Obviously this wa my fault, but the question is: can I fit the 2014 Float X? I see that they sell it in 7.875 x 2.00". but I'm not sure since Ibis doesn't include it in any build.
    Should I just send it for a rebuild at a Fox service center or upgrade it to the Float CTD offered in the newer SL's?
    If you are going to keep the RP2 send it to Push and not Fox. Personally I would be looking at the Monarch Plus over the Float X just because it is proven. Not a fan of buying first year production stuff especially with all of the changes Fox has been making lately.
  1. 2014 fox float 29
    By SHIFTY1 in forum Shocks and Suspension
    Last Post: 07-10-2013, 03:40 PM
  2. 2014 Fox 36 Float - black or white?
    By Hugoc in forum Shocks and Suspension
    Last Post: 06-11-2013, 07:44 AM
  3. Fox float rp23 with boost valve blown?
    By BMSrider in forum Shocks and Suspension
    Last Post: 06-05-2013, 11:18 AM
  4. anything change for 2014 36 float?
    By sanjosedre in forum Downhill - Freeride
    Last Post: 04-28-2013, 02:00 PM
  5. 2014 Fox 40 Float RC2 & DHX RC4
    By daisycutter in forum Downhill - Freeride
    Last Post: 03-29-2013, 09:13 AM
