Results 1 to 33 of 33
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Mojo HDR 650 sizing - did I go too small?
    I have two rides on a new medium HDRb and think the frame may be too small. I'm 5 foot, 9.5 "with a 32" inseam. Stem is 90 deg and rails on saddle are all the way back. Pedaling position (KOP) is OK, but on descents I feel like I'm constantly pushing my rear back behind the saddle far more than to which I am accustomed. On climbs the front end wanders a bit and it takes a lot of concentration to keep the nose planted. I tried a 100mm stem which helped the front end, but I still wasn't very confident descending. A lay-back seatpost is not an option.
    I'm comparing the Mojo sizing on paper to the Bronson, Solo & new Mach 6. Each of those bikes, for a given size, have a significantly longer reach. In fact, the reach of the L Mojo is roughly the same as the reach of those others in M.
    I can't swap the frame since I purchased from Competitive. I'm curious what others my size have done and if Ibis is known to "run small" in general. I have plenty of seattube and standover should I elect to go one size bigger.
    Other than that, this is a great frame with one caveat: rear tire clearance is minimal. A 2.3 Ardent leaves minimal clearance and after only 2 rides the paint in the chainstay yoke has completely eroded away from rocks tossed up by the tire. For kicks, I put a 2.35 Hans Dampf in there and, while it clears dry, there is zero room for error.
    Mar 2013
    All I can say is, I'm getting a medium and I be all of 5'7". Currently I'm riding sml frames from various makers, I see your dilemma, raise you a large with a 60mm stem. ?
    5'9" seems to be the in between height for these frames. I ride a medium and always felt that I should be on a large.
    Started with a 90mm stem. After a couple of years I have shortened my stem to 70mm and have the seat centered and feel good on it. Occasionally I try a longer stem but always go back to the 70mm. I really like the fit of this bike now and probably wouldn't go to a large.
    Remember, that it's not a XC bike but a Trail bike. It handles XC very well so it's easy to want to stretch out on it. Also, if you go shorter in the stem try riding it with the same stack height or a little higher. Most people feel that you need to lower it. Longer and lower is better.
    I'm 5'9" & my brother is 5'10" & we've both been on larges for the last year & love them. But I've seen threads like this before & it seems more like a personal preference than anything else. As more people post, you'll probably see 1/2 the guys say med and the other 1/2 large.
    What width bar are you running? If short, trying running a 750mm wide bar.
    Bodhisattva
    Thanks for the feedback. Good to see I'm not alone. Given that 5'9" is the average male American height, it's odd that that it's a common "tweener" size for Ibis.
    i'm still thinking the medium is too small and that Large with a 70mm stem may be the ticket.
    Quote Originally Posted by The Squeaky Wheel View Post
    That's the size I am running. I am about 5'11"/6'
    I also noticed the needing to get back behind the saddle more on descents too.
    That's just how the HD works, you'll get used to it.
    Bodhisattva
    Quote Originally Posted by saidrick View Post
    Please clarify - you are running a M or L at 5' 11.5" ?
    Also, are others chainstay yokes holding up on the 650? After only 2 rides with an Ardent (not the hugest volume tire) the paint in the chainstay yoke has completely eroded away. Tire clearance is far from optimal, IMO. Otherwise, killer bike.
    Bodhisattva
    My bar is 740mm. Stem 90 x0. bars about even with saddle, maybe a smidge below
    Sorry about the confusion, I am running a size large with a 70 mm stem, at 5'11" /6'
    This size lets me run a 5" dropper, which really helped me with the needing to get behind the saddle part of the HD.
    Now that I am about 15 rides in to the bike it's starting to feel really good, but getting used to this bike does take time.
    Bodhisattva
    I'm hoping this is the heart of it. I've been on 29ers for 5 years exclusively, which tend to have extended cockpits.
    I spoke to Ibis-the guys at the shop my size tend to go medium as well.
    I'm 6' 1/2" and am about to pull the trigger on this bike. Scot at Ibis says I should go with large but it looks a bit too small (I've been riding large SC blurs and now a Tallboy and I've always felt these bikes were a smidgen too small.)
    Any thoughts?
    Quote Originally Posted by cgnreno View Post
    Any thoughts?
    You are also on the borderline in sizing. A lot of people at your height will get an XL with a 50mm stem or the large with a 70mm stem.
    If you can see when/if they have any demo days coming near you.
    This bike does have a little bit shorter top tube and wheel base.
    Reputation: Foxbat's Avatar
    Feb 2006
    When I demoed the HDR, the dealer tried to put me on a medium. It felt tiny and I insisted on a large. With a 60mm stem, the large felt good both climbing and descending. I'm 5'9" with a 31" inseam and I agree that 5'9" puts you in between size medium and large for a lot of bikes out there.
    Bodhisattva
    Quote Originally Posted by Foxbat View Post
    Thanks.
    I've owned a lot of bikes and my TT is always 23-23.5 with around 17" ST. It's never been an issue. The Mojo is the smallest fitting medium I've ever ridden. Looking at the geo more closely, the Mojo large's Reach is about the same as other comparable bikes medium (solo, bronson, mach 6 650). This tends to validate my opinion.
    Levi Early
    Reputation: Levi707's Avatar
    I tossed a leg over both the medium and large this last weekend to get an idea of what I will be ordering. The large felt great with the reach but I was dragging nuts on the standover clearance. The medium ended up having the best standover for me but we moved the saddle all the way back and swapped the stem out for whatever is 10mm longer than what they spec it at normally. It fit spot on for me then. I am 5'9" w a 31" inseam for what it is worth.
    I'm 6' 1/2" on a Large with 70mm stem, 785mm bars, and a dropper post. Get wider bars and a dropper post.
    Reputation: tapcon's Avatar
    May 2013
    I'm 6' and ride a large. After a couple of rides, I was really nervous that I had gotten too small of a frame. The top tube was a good inch shorter than my previous bike (Trek Fuel EX 7 with a 17.5" frame). After pushing the saddle back, lengthening the stem and widening the bars, I felt as though the bike fit much better.
    Whether you're peddling or twisting the wrist...you're still riding on two wheels...and that's good enough for me
    As I stated before, you are going to get about a 50:50 answer. Obviously it comes down to personal preference, but it seems if you believe in the new style of short stems 50mm & wide bars 750 or wider, you'll usually ride one size larger in the Ibis line up than other bike makers.
    Again I'm 5'9" & love my large Mojo HD. My saddle is pushed forward & my stem is 50mm with 770mm wide bars. This bike in my opinion rips & feels like a mini DH bike on the descends, but yet still climbs incredible for a bike so capable on the DHs!
    Aug 2013
    Hey Guys.
    I'm a new member here and this is my first post.
    I'm 6' 1 1/2" and I was anguishing over the Large / X large question for some time...
    All my previous bikes have been XL, or 20.5" measured seat post lengths.
    I was worried that the specified XL Mojo HDR seat post length of 21" might be a touch too much.. I was wrong, the frame is perfect and the actual measurement is closer to 20.5".. The seal / wiper ring on my KS LEV 125mm. dropper post sits approx. 3/4" above the top of the seat binder clamp allowing full leg extension when the post is fully extended...
    I prefer having the seat post sit lower/deeper into the frame as opposed to running the Lev closer to it's maximum extension , which would occur if I had chosen a 19" Large frame...
    I feel that choosing an XL frame places less stress on the carbon fiber material at the seat post area due to less leverage applied by the shorter length of extended seat post......... I also feel that the top tube length of the XL frame works well with my choice of a shorter 70mm. stem...
    I hope the above makes sense...
    Cheers T.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    6'2" on a L with 70mm stem, 750 bars, and the seat pushed forward most of the way.
    Rode an XL for 1.5 years and always felt it was a little big while cornering.
    This is a 26" hd, but I can't imagine geometry is much different between the two.
    Aug 2013
    I'm a bigger guy, and in the past, I've purchased bikes / frames based proportionally to my size.
    We can't dictate what frame size is best for everyone....
    Reputation: jon123's Avatar
    Just to bring another thought on this...aren't you guys going about this the wrong way? putting 80, 90 and 100mm stems on a bike like this seems crazy. It seems to me that's a very road bike way of sizing.
    There's a school of thought that stem length is so important on mountain bikes that you size your frame around a stem, not the other way around.
    I hardly think the move to short stems is a fad. On a bike like the HD a 50mm would DRAMATICALLY increase stability and confidence on the downs while giving up very little everywhere else. It's considered the sweet spot in stem length.
    Many manufacturers have already gone to longer top tubes to accommodate for a short stem, and more are moving that way for their 2014 bikes.
    Ibis has not and their Reach numbers really show it. My vote would be to go a size larger on the HDR.
    Anyway, just a thought.
    Feb 2006
    It is really about personal preferences.
    In this month Mountain Bike Action, Brian Lopes (5 foot 9) says: "I'm riding a size large for my cross-country-type setup, but I also ride a medium for a more agressive all-mountain setup".
    Whether you are aggressive or not, try the M & L sizes and get your feelings!
    Aug 2013
    Quote Originally Posted by jon123 View Post
    Exactly. Very good points Jon.
    I also need the reach of a longer top tube but it was hard to find in most bikes until recently. I bought a 70mm. stem for my XL HDR and may go down to 50mm. if it's comfortable. The Large frame's top tube is under 24" and that's no good for me. The XL is around 24.5 or so and that's more like it...My son is taller than me and I like the top tube length of the new Pivot Mach 6 and may go that route for him. Longer top tube shorter stems, that makes sense to me.
    Feb 2006
    Agreed. I really like the feel of a shorter stem, longer reach setup on my bikes.
    Reputation: pavlov0032's Avatar
    Jan 2014
    I rode Mojo HDR yesterday at Helens in manhattan beach, I'm 6'2", I rode XL frame and it seemed that I rode medium size (thats how small it felt) my ass was constantly at the very back of the saddle it felt extremely un-natural..
    After that I rode Cannondale f29 xl, and frame felt natural and perfect..
    upon looking at geometry It seemed that Ibis Mojo HDR has 24.6" top tube and Cannondale F29 25.2" and the seat tube of HDR is 1 inch longer..
    Reputation: mwandrusz's Avatar
    So just to muddy the waters some more...
    I'm 6' on the dot, i'm riding an XL HDR with 50mm stem and 780mm bars. I came from a L Mojo SL with 50mm stem and 780mm bars that felt way too cramped almost always. i just could not stand having the cranks that far forward in relation to my arse when sitting while pedaling.
    I don't know if it makes a difference, but I'm a big dude, 245 lbs, so I'm not what you'd call a "finesse" rider, the stability and "in the bike" feeling of the XL's longer reach and wheelbase make my choice to go up a size 150% correct, in my case.
    Im a tad below 6 and im riding an XL hd. Have not tried a Large though but the longer TT and shorter stem works great. Nose stays planted diring climbs without the need of the travel adjust and very stable on straight long rocky dh. Really the "in the bike" feeling is what i prefer.
    Only observation is that I cannot fully extend my butt behind the saddle to give more traction at the rear during slow speed techy stuff (stepdown) etc. but i guess its just a matter of getting used to coming from a relativley short TT bike before (Large 5spot with 23.7-8 tt and 50mm stem)a 35-40mm could do the trick? Using 50mm right now. I dont want to loose traction infront thats why Perhaps i have to learn how to distribute my weight propoerly.
    Quote Originally Posted by LGavin View Post
    You using a dropper post?
    Reputation: cmarshack's Avatar
    I am your exact same size and height and I ride a large HD with 50mm stem...it is Perfect!
    I also am the exact size as you and I ride a medium HDR with a 70mm stem and 29 1/2" wide bar. I demoed a large and medium hd and found the medium way more flickable. The demo bike had a 90 mm stem and narrower bars so that's what I ordered. Have since changed out the bar and stem.
    I also found the front end wandered a lot on climbs. Some days more than others but was worse when my arms were tired and could not aggressively pull back on the bars. Just last weekend I lowered my stack height by 5 mm which left two 5 mm rings. I really like it on the climbs and downs.
    Now having said all that sometimes I wonder what a large HDR with a shorty stem would be like.
    Also I put " frame skin" material where you are having rock damage. It works like a charm.
    Ease & Flow Where Ever I Go
    Mwandrusz, yes in using a kronolog right now but planning to get a new Ks lev because it has a shorter collar stack height.
  1. Replies: 1
    Last Post: 06-05-2013, 06:43 PM
  2. Paid SPAM -- Small Mojo SL, XTR, Fox
    By GLIDE in forum Ibis
    Last Post: 01-20-2013, 06:34 PM
  3. EMD 9's now in Extra Small sizing
    By PUBCRAWL in forum Niner Bikes
    Last Post: 01-27-2012, 06:13 AM
  4. small mojo
    By 01tracer in forum Ibis
    Last Post: 04-14-2011, 10:18 AM
  5. Mojo HD small with RC4 coil
    By airzoink in forum Ibis
    Last Post: 03-18-2011, 08:03 AM
