Results 1 to 3 of 3
    Mojo HD Rear Shock size?
    Iím confused. I called Ibis to determine the size of the rear shock I would need on my Mojo HD if I go coil and they said 8.5X2.5. From their website Iím finding 7.875X2.0. Which one is right?
    ďThe rear shock length between eyelets is 7.875" and shaft travel is 2.0". DO NOT deviate from those dimensions, catastrophic failure could result!Ē
    Which one is right?
    T.i.a.
    8.5 x 2.5 is for running with the 160mm limbo chips, and 7.875 x 2.0 is for running with the 140mm limbo chips... so your first decision is how much travel you want to run.
    160mm
