Results 1 to 6 of 6
    Mojo HD lower link shaft - specification
    Hi all,
    does anyone know what the specification is of the bolt that screws into the shaft that holds the lower link onto the front triangle on a mojo HD?
    I've sheared mine, and need a replacement, but the UK distributor is out of stock.
    So I was just going to buy a generic bolt but I need to know the thread type and size etc.
    You could order a new one from the Ibis web store;
    http://store.ibiscycles.com/lower-li...front-p31.aspx
    I had a quick look at the spare I keep for my mojo and it looks like a metric 10x0.8 thread
    but I'll need to get into the workshop to check for sure.
    Thanks for your input on this.
    I dont think it is a metric thread, because I tried a few different metric bolts and none of them will fit.
    I cant order from the ibis webstore as I'm in the UK, and I need this bolt rapidly.
    I'm guessing that it'll be a UNF thread type, but need to know for sure so I can get the right part
    It is not a standard metric thread it has a very fine pitch, hence the 0.8.
    My metric gauge only has 10x1.5/1.25/1.0 so I can't really tell for sure what the pitch is. Using a caliper it measure 0.6mm. Sorry I can't be of more help.
    Thanks for trying, I appreciate it.
    I have emailed IBIS, so will update here with teh answer when Iget it.
  1. Replies: 27
    Last Post: 08-09-2013, 10:59 PM
  2. Chain getting stuck on Mojo HD lower link.
    By canuck_tacoma in forum Ibis
    Last Post: 05-25-2012, 01:05 PM
  3. Rotate/Turn lower shaft? - Manitou Swinger 3-way
    By BStrummin in forum Shocks and Suspension
    Last Post: 04-23-2012, 04:13 PM
  4. Replies: 1
    Last Post: 07-09-2011, 04:34 AM
  5. Replies: 0
    Last Post: 01-24-2011, 08:20 PM
