Results 1 to 3 of 3
    mojo hd insert bonding failure
    I finally discovered why I had play in the lower link on my hd. It turns out the 'tube' in the frame where the lower link bolts to/through had become unbonded from the frame and was free to rotate and move latterally,hence causing a load of play.
    I suspect it failed because the lower link bearings siezed and I didn't notice .
    Anyway, I have bonded the tube back into place with some araldite and it seems ok so far.
    But I was wondering if anyone else had this problem, and how did you fix it?
    I had that issue with an early Mojo C and Ibis took care of it.....despite being beyond the warranty, they offered a replacement front tri at no cost, or for a little $ a complete new SL frame.
    Sep 2012
    Call Ibis-- They will advise what to do... They are the great and will make sure your ride is safe and if there is a problem-- get it corrected...
  1. 2012 Shimano XT insert question
    By Ctraut5 in forum Brake Time
    Last Post: 11-11-2012, 07:10 PM
  2. Oh no. Nipple insert ripped out of Mavic 823 rim.
    By lelebebbel in forum Downhill - Freeride
    Last Post: 07-11-2012, 02:52 PM
  3. Replies: 3
    Last Post: 02-21-2012, 07:42 AM
  4. CYA insert - to - bb30
    By emassa15 in forum Niner Bikes
    Last Post: 03-11-2011, 09:24 AM
  5. Replies: 0
    Last Post: 02-09-2011, 09:19 AM
