Results 1 to 21 of 21
    Reputation: GuruAtma's Avatar
    Mojo Complete Bike Weights
    First of all, Ibis communications is great. I sent an email to Ibis at 10:00 at night and had a reply before 8am the following morning. From the owner himself.
    I asked about the weights of their complete bike builds. I thought the info might be useful (and I'd like to see if you have the same build and have similar weights). I assume these weights are without pedals:
    Here are some actual weights we just compiled. Real bikes sitting in our shop:
    Mojo w/WTF-XTR kit: approx. 10.7 kilo
    Mojo w/WTF-XX kit: approx. 10.6 kilo
    Mojo w/XT kit: approx. 11.3 kilo
    Mojo w/X9 kit: approx. 11.8 kilo
    Mojo w/SLX kit: approx. 12.0 kilo
    subtract 300g for Mojo SL
    These are all either L or M bikes. The weight difference between the two is small, so we say approximately. Also the bikes will vary frame to frame a little bit, a result of the manufacturing process.
    It was also nice to know that he's fairly flexible about mixing parts from different build kits.
    功夫大师喜欢骑着他的自行车在山上。
    Antagonist
    Reputation: spill's Avatar
    My large SL XT build with m770s attached, CB Iodines and Nevegals, and an RPL came in right under 25 pounds the day I brought it home. Everything else was right off the parts pick list.
    Reputation: rossp's Avatar
    Mar 2005
    While I love my mojo I am a little skeptical about some of the stock weights....happy to be wrong though!!
    Need advice on Mojo SL purchase
    My medium SL weighs in at 13.03kg (weighed in bike shop yesterday)
    Mojo medium SL
    Cane Creek IS110 headset
    2010 Manitou Minute 140 20 mm TA
    Wheels - CK hubs with Flow rims and 2.2 Rubber Queens run tubeless
    X0 shifters
    X0 medium cage rear mech
    XTR front mech
    Chris King BB
    Raceface Deus crankset
    SRAM PG990 cassette
    KMC X9 SL chain
    Time carbon pedals
    Gravity Dropper mulit 1:4 seat post with remote
    Sunline V-One OS 745 mm bar
    Gore ride on cables
    Formula K24 disc brakes
    I guess I could forgo the GD seat post and put on lighter wheels and out the Easton carbon bar back on to drop it below 13.0 kg.
    Oct 2007
    Quote Originally Posted by dreednya
    Mojo medium SL
    X0 shifters
    XTR front mech
    Chris King BB
    SRAM PG990 cassette
    KMC X9 SL chain
    Time carbon pedals
    Sunline V1 737mm bar
    Gore ride on cables
    That sounds a touch heavy to me, there is always some difference in the scales! My build is below, pretty similar to yours!!
    Mojo Large, Ti bolt kit
    2009 Magura Thor 140 20 mm TA
    Wheels -Hope hubs with Flow rims and 2.4/ 2.2 Rubber Queens run tubeless
    X0 shifters
    XTR front mech
    Chris King BB
    XT crankset
    SRAM PG990 cassette
    SRAM ?? chain
    Crank Brother Candy SL pedals
    Easton EA90 seat post
    Easton EA90 bar
    Magura Marta SL disc brakes
    A hair over 12kg
    ____________________
    Ibis Tranny 2009
    Ibis Mojo 2008
    Litespeed Pisgar 2004
    Pinnarello Dogma FP2006
    I reckon the carbon bar and seat post make up a lot of the difference. But I wouldn't change the GD as I got to used to riding with it on my previous bike[ Heckler] and the terrain here in Wales [UK] warrants it. Definitely pedals light
    That also includes front crud guard plus Steve Peat front fender type guard.
    Unpredictable
    Reputation: Ridnparadise's Avatar
    Mine started at circa 12kg - large Mojo with XT, TALAS 32 RLC 9mm QR, RP 23, Race Face Next SP and bars, Mavic 717/XT hubs, 2.0 H Pythons and Avid J 7.
    Now it is maybe 13.4kg with CB 75 mm remote dropper seat post and tubeless 2.35 High Rollers. Next move will be more solid wheels rather than new fork, 15mm TA etc. Although the frame will handle bigger forks and more solid axles, I am going to PUSH (eqiv) the fork and maybe go to 150/130/100mm using my current 140mm TALAS 2008. The local LBS can do the conversion. I think stiffer wheels will provide a big improvement and a cheaper one than as my current XT hubs are in great shape.
    Next weight maybe 14kg with greater rotating mass, but the bike is far too good for a light build. Don't think light for your Ibis Mojo. Think what you want to do with it. Chances are with a heavier build you will be able to do more fun things winh the one bike you need (OK - I) need in your life
    Reputation: Black RONIN's Avatar
    27lbs/12.3kg (pedals on) AM build. It was 25lbs/11,4kg (pedal on) before rebuilding, and I must say the bike is a whole different animal now, way better for everything - ok, a bit, only abit really, heavier to push uphill, but that is a compromise I'm taking with no regret. Mojos are meant to be build tough, now I see.
    Mojo XL with XX kit, R1 brakes, american classic with stan's, time pedals = 25.06 lbs.
    Reputation: CactusJackSlade's Avatar
    22.95 lbs
    Medium SL
    Lefty Carbon 130pbr (saved me a pound - and much stiffer than my Fox)
    XTR build
    Stans wheels
    4Ti Eggbeaters
    Just swapped out a bunch of bolts to Ti which dropped it down under the 23lb mark, still waiting for the Ti frame bolt kit.
    I'm thinking I can get to 22lbs even with my Stans race wheels, SCRUB rotors and race tires...
    Attached Thumbnails Attached Thumbnails Mojo Complete Bike Weights-blk-blue.jpg
    Largest NorCal XC Race Series
    http://www.bicyclingevents.com
    http://www.UavTechReview.com
    Best in the West!
    frame: MOJO XL - green
    fork: Fox Talas 32 RLC
    full XTR (derailleurs, shifters, cranks, pedals), XT(chain, cassette)
    brakes: Magura Louise Carbon+HOPE floating rotors
    handlebarsbars: RF Atlas OS + RF G&E grips
    stem: RF Atlas 70mm + Hope Hed Doctor
    seatpost: RF Deus XC + SI SLR XC
    wheels: HOPE PRO II+ZTR ARCH+Sapim Laser
    tires: Schwalbe NN 2,1"
    weight 11,84 kg
    My Build
    Medium 2009 SL Frame
    2009 Fox Float 140 RLC
    Crank Brothers Cobalt Wheels
    Maxxis Ignitor Front tire
    Schwalbe Fat Albert rear tire
    XT Crankset
    Crankbrother Candy Ti Pedals
    SRAM XO Rear Derailleur
    SRAM XO shifters
    Shimano XTR Front Derailleur
    Crankbrothers Joplin R Seatpost
    Avid Elixir CR brakes
    Easton Monkeylite Handlebar
    Thomson Elite Stem
    Grand Total of 28.20 LBS
    My final build:
    Mojo SL size L
    XT front, rear, cranks, shifters
    CC 110 headset
    easton carbon bars and seat post
    wtb rocket saddle
    ibis stem
    formula r1 brakes
    easton haven wheels
    kenda el moco tires
    xtr pedals
    total weight: 25.5 lbs, 11.56 kilo
    功夫大师喜欢骑着他的自行车在山上。
    where can i save weight?
    Dec 2008
    First of all, you've got a heavy seat post, so you will never be able to achieve some of the weights posted in this thread. The tires seem to be pretty heavy and the Thomson stem is not especially light (although it's very a nice piece of equipment).
    Quote Originally Posted by gfung00
    Heavy tires can add a good pound or more to your bike. Are you running big tires or tubeless? Maybe getting some smaller Nobby Nicks or Rocket Rons will contribute to get down the weight. Also look for the Ignitors 2.1 Exception series, they are quite light. Your stem is just a bit heavy, but hardly you'll get the strengh/weight ratio you have on a Thomson on another stem. I'm using it and mine weighs around 180g.
    On the seatpost, it's heavy, but damn it's handy! Only swap it if you think having a regular seatpost will do for you. I use the Joplin on my bikes, and I cope with the extra weight in favor of the telescopic seatpost. But yeah, another half pound is shaved if you go Thomson.
    I'll go a bit off topic here, but one big upgrade you may want to get in the future is the fork. Soon Fox will ship the newest Floats and TALAS 32 with 15QR. Weight-wise they are pretty the same as yours, but they will improve stiffness and steering precision. The 15QR is a big improvement over the simple QR. I know you asked about weight but your bike already has all the good stuff, you can go crazy light, but them maybe you'd be missing the point on your bike. Check the tires first. They may be what is giving your bike the extra pound. The rest is just fine.
    My setup at 27 lbs:
    Mojo SL medium white
    Fox Float RLC 15QR 150mm
    ZTR FLOW/ HOPE PRO2/ DT COMP spokes
    Hope QR skewer rear
    Thomson stem and seatpost
    Ritchey WCS handlebar
    Elixir CR brakeset
    Hope float rotors 183/160 with Shimano 180 PM adapter front
    Noir crankset
    X-0 triggers and rear D.
    PC-991 hollowpin chain
    PG-990 cassette
    XT front D.
    Crank brothers Acid 2 pedals
    Cane Creek 110 headset
    SDG Bel Air Saddle
    Lizard Skins Peaty lock on grips
    Schwalbe Nobby Nicks EVO 2.2 with light tubes
    Cateye Wireless computer
    Will test a set of Cobalts next week and see as they do compared to my current burly hoops. The weight will probably drop to 26 lbs. Will probably get a XT cassette over the SRAM too.
    aka übermensch
    Reputation: Triple T's Avatar
    I'll play
    08 Med SL Matte Clear
    Started life as an XT build, DT Swiss shock, Fox Float RLC, etc. Weighed somewhere in the vicinity of 25-27 lbs. Can't really remember.
    Current build-
    Med SL Matte Clear with blue links and seatpost clamp
    Easton MonkeyLite XC bars
    Sram X0 trigger shifters
    Alligator i-links
    Lizard Skin Peaty lock on grips with blue ODI Lock Jaws
    Hope Race X2 brakes (160 front-140 rear floating rotors)
    Ibis Stem
    Cane Creek 110 IS headset
    DT Swiss XMC 130 15QR fork
    Crank Bros Cobalt Wheels (15mm adaptor front/DT Swiss quick release skewer rear)
    2010 Schwalbe Nobby Nic 2.1 UST
    Thomson Elite seatpost
    Selle Italia SLR XC gel flow saddle
    DT Swiss shock
    XT front derailleur
    X0 rear derailleur
    Chris King bottom bracket
    XTR cranks
    XTR cassette
    XTR chain
    Crank Bros Smarty pedals
    Current weight: 23.83 lbs.
    08 Ibis Mojo SL
    09 Ibis Tranny SingleSpeed
    Reputation: alexb650's Avatar
    07 Mojo (L)
    Fox Float 140 rl
    Crossmax SLR (2.1 nevegals tubeless)
    Ibis stem and bars
    xt brakes with dual control shifters/levers
    Noir crankset
    SDG Ibeam seat and post
    lx front dérailleur
    xtr rear dérailleur
    xtr cassette and chain
    Shimano m520 pedals
    26.27 lbs
    any suggestions on losing a couple pounds?
    Dec 2008
    Switch pedals (check out the new Egg Beaters), perhaps a lighter seat and post and an Easton carbon handlebar should lose you some weight.
    Quote Originally Posted by Crossmaxx
    ahhhh, the pedals. Kinda one of those things you forget about. The seat and post have been bugging me for a while but i can't decide if I want to go carbon and shed weight or go up in weight with an adjustable. Decisions, decisions.
