Mojo Chainline?
Anyone got any ideas on what the chainline should be on the Mojo?
Any info appreciated before I order my cranks and Bottom bracket.
Thanks in advance.
Sorry, don't know what the chainline is.....but if you buy Shimano cranks, you'll put 2 spacers on the driveside and 1 spacer on the other.
Probably gonna get some Middleburn RS8 cranks with an ISIS bottom bracket. Just need to make sure I get the correct axle length so I don't screw up the chainline.
Middleburn say these cranks will give a 48mm chainline on a 113mm axle.
My existing bike an Orange 5, has a 50mm chainline. Easily sorted out with the spacers on the hollowtech BB (as you say, ddraewwg)
If I remember right, there is an old post somewhere back that touched on this issue perfectly. Hans posted the info I think you are looking for. It might be called chain allignment(?)
Good luck and welcome to the Ibisian family!
Doing a search on "chainline" in the Ibis forum finds much on this subject. Looks like 49 - 50 mm from BB center to middle ring center is within spec per Ibis and Shimano for the external bearing BB's. A 48mm chainline should work I'd imagine with Isis BB (there is room for the rings to clear for sure) and be a little smoother in the lower cogs.
See this link:
Mojo chainline.
As a heavier rider near 200 lbs I never got more than 1 year and often less time from the best Isis BB's from Raceface and FSA. My FSA MegaExo external bearing BB is now 1.5 years old and giving no signs of dying anytime soon.
I love bicycle technology . They can make a bike so durable regardless the weather.
Oh yeah talkin bout technology. Do your fork sealing has cracks? Cause my RS Recon seals start to develop cracks. I wonder if this is normal or what?
07 Giant Anthem 2 (Int'l Edition) | omartan.co.cc
Im a MOJO Fanboy
Wheelhot, am I missing something?
Huh? Which of my post are you referring to?
Im a MOJO Fanboy
erm! The one above?
Well, I mean a bicycle has been designed to suit all conditions, from sunny day, mud and snow and yet they still can make it lightweight and abuseable.
My RS Recon fork seals has started to develop cracks. So I wonder if this is a normal thing or what?
Im a MOJO Fanboy
- You may not post replies
- You may not edit your posts
Forum Rules
