Results 1 to 11 of 11
    Reputation: cchough's Avatar
    Mojo cable routing question
    I'm having a bit of a cable routing issue. My cables are routed as per Ibis instructions but where the rear brake and derailluer cables go around the seatpost, the cable bow out and rub my lugs. I solved the problem using a zip-tie behind the seatpost to pull the cables inward. My demo Mojo, set up by Ibis, had a section of inner tube doing the same job as my zip-tie. Anyone have a really elegant solution?
    Thanks,
    Sycip Unleaded 650B
    Sycip Ti Gravel
    Pivot Mach 5.5 - in progress
    flow where ever you go
    Reputation: noshortcuts's Avatar
    With out seeing it, I can only imagine that shortening it will help. My leg rarely touches cable on the left and never touches on the right. I ran the cable fairly tight but no tricks were needed to keep it from bowing out. When the rear is active, it bows more up than out I believe.
    Reputation: Davide's Avatar
    Velcro Cable Tie
    Quote Originally Posted by cchough
    Thanks,
    I put a velcro cable tie to keep the der cable in place. It is a very clean solution. (I thought I had the "problem" because the continuous cable routing I use in the rear, I did not think the bowing out was possible using the rear stops). II don't have the problem with the rear disk tha t is routed under the front der.
    I had the same issues. I shortened my rear der. cable housing so that it is basically tight between the stops when the bike is unweighted(is that a word?). The brake line I cut too short by accident but it still bows out under the seat instead of somewhere else...needs to slide maybe. I dream about internal cable routing.
    A bicycle will take you to fantastic places....if you let it.
    Ibis fan since '08 now rolling on the big wheeled Ripley.
    I saw noshortcuts' post and I went out to the garage to take a picture of the cable routing but naturally, when I cut the zip-tie, the cables didn't bow out at all. They seem to bow more up than out. It might be that the zip-tie "molded" the cable housing into a better position. Davide, in case this "solution" is temporary, where did you get those velcro zip-ties? I'm concerned that the plastic zip-ties will eventually cut into the cable housing.
    Yeah, internal routing would be muy sexy but I aways felt like the internal routing on my old Klein created a lot of drag on the cable. If Ibis could route the cable under the top tube with straight internal routing through the seatpost and the support just above the shock mount, that might be straight enough to avoid any odd kinks. Having said that, I'm pretty dang happy with my Mojo as is.
    Sycip Unleaded 650B
    Sycip Ti Gravel
    Quote Originally Posted by Davide
    Davide, where did you find the velcro cable tie?
    Thanks,
    Sycip Unleaded 650B
    Sycip Ti Gravel
    Thanks,
    You can find them in a bunch of places but I got them here http://cableorganizer.com/wire-wrap/
    http://cableorganizer.com has a lot of neat products, the side entry braided sleeve is what I use to cover the cables on the top tube
    have fun!
    The cables only bow out when you are sitting on the bike. I wonder if the I-link cable system might work better? Or maybe I'll try to loosen the cable tie on the brake line so it can move there.
    Cool, thanks for the pointer. The plastic zip-tie works well enough but the plastic XTR cable housing looks prone to damage so I think the velcro/fabric ties are the way to go.
    Thanks,
    Sycip Unleaded 650B
    Sycip Ti Gravel
    I had some ghost shifting issues so I replaced the housings at the rear deraileur with one piece from the back of the top tube to the rear der. I haven't thrash tested it yet but I'll let you know Monday how it worked out.
    jceahodges
    Reputation: jceahodges's Avatar
    Idea! Another option...
    I just built up my Mojo and was looking for other ideas to loosely connect the disc brake hose and rear derailleur in order to keep them from bowing out too much. First, I kept both of them as short as possible and secondly, I found an old nylon key chain that was about 2.5-3" long and had a small loop on either end. I fed the rear derailleur cable thru one of the loops and had my teenage daughter to unsew the other loop, insert the brake hose and re-sew the other loop. That's it... and it works great! Take a look at the image and it'll make more sense. I adapted a nylon key chain, but any piece of nylon and a sewing kit will work wonders. Hope this helps.
