Results 1 to 10 of 10
    Reputation: trap121's Avatar
    Mar 2011
    Moj SL crankset size??
    Can someone tell me what size fits the SL? Im about to order a new crankset.
    Dec 2008
    The bottom bracket for the SL is a standard BSA threaded 68mm. Your cranks must work with that BB.
    Mar 2011
    So the 170mm, 175mm options I'm seeing are the length of the crank arms?
    Yes those are the lengths.
    Do the 175's unless you're a really small person.
    Mar 2011
    I'm 5'5, would the 170mm be better? Is .1 of an inch really gonna make that big of a difference?
    Jenson has a sweet deal on the 175 but don't have the 170's.
    Bike is size small.
    [QUOTE=trap121;10098757]I'm 5'5, would the 170mm be better? Is .1 of an inch really gonna make that big of a difference?
    Trap,
    There are many theories, but the truth does not matter much if you use 170 or 175mm, buy sweet deal
    I need a new name
    Quote Originally Posted by trap121 View Post
    Bike is size small.
    Blue Sky Cycling also has a sweet deal on some 170mm XT's. Ordered some for my wife last night. She's 5'2" and doesn't like my 175s. IMO you'd be happier with 170s but probably would be fine with the 175 as well.
    i ride bikes
    Mar 2011
    How do I measure my current crank arms? Is it from the center of the pedal to the center of the crank or is it end to end?
    Reputation: skellz's Avatar
    center to center.. most have the size stamped on the inside . i just put some 180's on mine
    Ibis Hd3 2016-Boost frame
    2002? MountainCycle San Andreas
