is integrated headset that bad?
Since I got my Ibis and that was late 2009, I have replaced my headset 3 times already. The cane creek is3 if im not mistaken. Should I buy the expensive once or does chris king carry an integrated headset? What's your take on this guys?
->wrong info given here-<. If you are replacing it that much, have someone who know what to look for check it out.
incorrect, the mojo uses an integrated, which is neither zero stack or a CK inset
get a cane creek 110is, has better sealing than the is3 (mines going on 4 years), many people in wetter climates have had issues with the is3 if i recall correctly
The IS-3 isn't really a bad headset, just the bearings are a little low quality.
And since the lower bearing takes nearly 90% of the loading and is in the position
to be most affected by mud and water flung up by the front tyre. You really only need
to replace the lower bearing with a good stainless steel one or if you have money a
ceramic one.
Have a look here for some examples.
HEADSET BEARINGS FROM REAL WORLD CYCLING
I'll second the 110is. Going strong 4+ years. Swap top for bottom once in a while so the upper bearing gets a bit of abuse.
Another hint that I forgot is to use some waterproofing grease on the outside of the sealed bearing, just to give some extra protection.
I have had my IS-3 since 2007 in my Mojo-C. I replaced the original lower bearing that was rusted and notchy in late 2008 with an ss model and haven't touched it since then. I really can't understand how the bearing became so rusty since where I ride was having one of the worst droughts in recorded history and I'm very lazy about washing my bike.
ceramic one.
I know the bearings are really bad. anyway, thanks for the link I may have to purchase an extra bearing cuz I know the one that I have will break eventually. One question though both upper and lower bearings are the same I mean the dimensions?
mojo c/sl headset
Yep, both bearings are the same in the is-3.
Same here, went with the CC 110is on my build.
I have the IS-3. It's about a year & a half old. Bottom was feeling notchy after Snake#2, so I pulled the seals, washed it out and greased it up. Right as rain. Clean it out now and then, keep fresh grease packed in, and it'll run a long time.
Can any of you guys give me some advice on finding the size of my current headset so i can get a new one?
Ibis Webstore
You can order one from the Ibis Webstore or at least see what you need.
- You may not post replies
- You may not edit your posts
Forum Rules
